我想在一个0.2*0.2*0.785的PZT柱上加10000N的力,加载后提示
[img]file:///C:/Documents%20and%20Settings/Administrator/Application%20Data/Tencent/Users/114386338/QQ/WinTemp/RichOle/H)JUXUNJT%7D)%7DR]6[%7BNCW$@1.jpg[/img]
我选择其它节点都是这样,请问问题出在哪?求老师指点一下。下面是session editor:
/NOPR ! Suppress printing of UNDO process
/PMACRO ! Echo following commands to log
FINISH ! Make sure we are at BEGIN level
/CLEAR,NOSTART ! Clear model since no SAVE found
! WE SUGGEST YOU REMOVE THIS LINE AND THE FOLLOWING STARTUP LINES
/input,menust,tmp,'',,,,,,,,,,,,,,,,1
/GRA,POWER
/GST,ON
/PLO,INFO,3
/GRO,CURL,ON
/CPLANE,1
/REPLOT,RESIZE
WPSTYLE,,,,,,,,0
/PREP7
ET,1,SOLID5,9
KEYOPT,1,1,3
KEYOPT,1,3,0
KEYOPT,1,5,0
ET,2,MESH200
KEYOPT,2,1,6
KEYOPT,2,2,0
TB,ANEL,1,1,21,0
TBTEMP,0
TBDATA,,1.32e11,7.1e10,7.3e10,,,
TBDATA,,1.32e11,7.3e10,,,,1.15e11
TBDATA,,,,,3e10,,
TBDATA,,2.6e10,,2.6e10,,,
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,1,,7600
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,PERX,1,,7.124e-9
MPDATA,PERY,1,,7.124e-9
MPDATA,PERZ,1,,5.841e-9
TB,PIEZ,1,,,0
TBMODIF,1,1,
TBMODIF,1,2,
TBMODIF,1,3,-4.1
TBMODIF,2,1,
TBMODIF,2,2,
TBMODIF,2,3,-4.1
TBMODIF,3,1,
TBMODIF,3,2,
TBMODIF,3,3,14.1
TBMODIF,4,1,
TBMODIF,4,2,
TBMODIF,4,3,
TBMODIF,5,1,
TBMODIF,5,2,10.5
TBMODIF,5,3,
TBMODIF,6,1,10.5
TBMODIF,6,2,
TBMODIF,6,3,
BLOCK,-0.1,0.1,-0.1,0.1,0,0.785,
TYPE, 2
MAT, 1
REAL,
ESYS, 0
SECNUM,
LSEL,S,LOC,Z,0
FLST,5,4,4,ORDE,2
FITEM,5,1
FITEM,5,-4
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1,0.01, , , , , , ,1
MSHAPE,0,2D
MSHKEY,1
FLST,5,6,5,ORDE,2
FITEM,5,1
FITEM,5,-6
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
LSEL,S,LOC,Z,0.785
FLST,5,4,4,ORDE,2
FITEM,5,5
FITEM,5,-8
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
/VIEW,1,1,2,3
/ANG,1
/REP,FAST
MSHKEY,0
FLST,5,6,5,ORDE,2
FITEM,5,1
FITEM,5,-6
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
ACLEAR,_Y1
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
FINISH
/SOL
ANTYPE,0
/RGB,INDEX,100,100,100, 0
/RGB,INDEX, 80, 80, 80,13
/RGB,INDEX, 60, 60, 60,14
/RGB,INDEX, 0, 0, 0,15
/REPLOT
/VIEW,1,,,1
/ANG,1
/REP,FAST
/VIEW,1,1,2,3
/ANG,1
/REP,FAST
/VIEW,1,,,-1
/ANG,1
/REP,FAST
/VIEW,1,,1
/ANG,1
/REP,FAST
/VIEW,1,1
/ANG,1
/REP,FAST
/REPLOT,RESIZE
NSEL,S,LOC,Z,0
FLST,2,441,1,ORDE,2
FITEM,2,1
FITEM,2,-441
/GO
D,P51X, , , , , ,UZ, , , , ,
FINISH
/PREP7
FLST,4,441,1,ORDE,2
FITEM,4,1
FITEM,4,-441
CP,1,VOLT,P51X
FINISH
/SOL
FLST,2,441,1,ORDE,2
FITEM,2,1
FITEM,2,-441
/GO
D,P51X,VOLT,0
NSEL,S,LOC,Z,0.785
FLST,2,441,1,ORDE,2
FITEM,2,442
FITEM,2,-882
/GO
FINISH
/PREP7
FLST,4,441,1,ORDE,2
FITEM,4,442
FITEM,4,-882
CP,2,VOLT,P51X
FINISH
/SOL
FLST,2,441,1,ORDE,2
FITEM,2,442
FITEM,2,-882
/GO
D,P51X,VOLT,0
/DIST,1,0.924021086472,1
/REP,FAST
/REP,FAST
/DIST,1,1.08222638492,1
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
/REP,FAST
ASEL,S,LOC,Y,0.1
FLST,2,1,5,ORDE,1
FITEM,2,4
/GO
NSEL,S,LOC,Y,0.1
FLST,2,273,1,ORDE,8
FITEM,2,1
FITEM,2,22
FITEM,2,-41
FITEM,2,463
FITEM,2,483
FITEM,2,-502
FITEM,2,1114
FITEM,2,-1344
/GO
SF,P51X,PRES,10000
NSEL,S,LOC,Z,0.785
FLST,2,441,1,ORDE,2
FITEM,2,442
FITEM,2,-882
/GO
SF,P51X,PRES,10000
/VIEW,1,1,2,3
/ANG,1
/REP,FAST
/VIEW,1,,,1
/ANG,1
/REP,FAST
/VIEW,1,1,2,3
/ANG,1
/REP,FAST
/VIEW,1,1
/ANG,1
/REP,FAST
/VIEW,1,1
/ANG,1
/REP,FAST
/VIEW,1,,1
/ANG,1
/REP,FAST
/VIEW,1,,,-1
/ANG,1
/REP,FAST
/VIEW,1,1
/ANG,1
/REP,FAST
/VIEW,1,1
/ANG,1
/REP,FAST
/VIEW,1,,,1
/ANG,1
/REP,FAST
FLST,2,441,1,ORDE,2
FITEM,2,442
FITEM,2,-882
/GO
SF,P51X,PRES,10000
FINISH
/PREP7
ETDEL,2
FINISH
/SOL
FLST,2,441,1,ORDE,2
FITEM,2,442
FITEM,2,-882
/GO
SF,P51X,PRES,10000
ALLSEL,ALL
FLST,2,1762,1,ORDE,2
FITEM,2,1
FITEM,2,-1762
/GO
SF,P51X,PRES,10000
)/GOP ! Resume printing after UNDO process
)! We suggest a save at this point |
