- 2011-5-26
黄版主,久仰大名,小弟现在用ansys做一个桥梁橡胶支座的模型,橡胶支座里面有7层钢板,钢板和橡胶之间经过硫化固结粘接在一起,模拟其在10mpa压强下的竖向变形,考虑到橡胶和受力的对称性,把一半橡胶支座的剖面给建出来,由于我只是做平面单元所以我橡胶材料我用PLANE182,钢板用plane42,模型按照毫米建模,橡胶的mooney-rivilin参数c10=0.747,C01=0.187,d=0.0001,然后泊松比取0.4998.钢板的弹性模量是E=2.01e5mpa,泊松比是v=0.3,考虑到钢板和橡胶之间经过硫化固结粘接在一起,所以采用公用节点的建模方式,但是出现了大变形不收敛情况。错误提示是:
One or more elements have become highly distorted. Excessive
distortion of elements is usually a symptom indicating the need for
corrective action elsewhere. Try incrementing the load more slowly
(increase the number of substeps or decrease the time step size). You
may need to improve your mesh to obtain elements with better aspect
ratios. Also consider the behavior of materials, contact pairs,
and/or constraint equations. If this message appears in the first
iteration of first substep, be sure to perform element shape checking
后来我把c10和c01放大100倍,才出现与实验结果稍微相符合的结果。我再把橡胶退化成线弹性材料。用plane42单元去模拟,把弹模取为3.08MPA,依然是出现上面的问题。后来我索性把实验实测的抗压弹模E=303.8MPA输进去,发现其y方向变形量跟试验数据很吻合。现在我搞不清到底是怎么回事,我想这样建模是不是不能模拟橡胶支座的力学性能。 |
