- 1
- 2011-2-28
不知switch用法是否错了
switch_1 = ui_switch_create(form_id,"switch_callback",0.2,y_loc,1,"球队",true)
item1 = ui_item_create(switch_1,"sw_1","Aubum vs. Alabama",false)
item2 = ui_item_create(switch_1,"sw_2","Wisconsin vs. Sippenry Rock",false)
item3 = ui_item_create(switch_1,"sw_3","FSU vs. Florida",false)
后面调用
FUNCTION switch_callback(item_name)
STRING item_name[]
switch (item_name)
case("sw_1")
dump item_name
ui_wid_set(db_1,"label","Aubum")
ui_wid_set(db_2,"label","Alabama")
case("sw_2")
ui_wid_set(db_1,"label","Wisconsin")
ui_wid_set(db_2,"label","Sippenry Rock")
case("sw_3")
ui_wid_set(db_1,"label","FSU")
ui_wid_set(db_2,"label","Florida")
end switch
end function
编译能通过,但选中switch按钮,显示$# (PCL) Too many arguments to function |
