建完模进行计算后出现如下错误,请高手帮忙分析下是什么原因,谢谢 +--------------------------------------------------------------------+
| ********* WARNING ********* |
| No control surfaces have been found for the domain interface |
| Default Fluid Fluid Interface |
| If you expect this to occur, please set the expert parameter |
| 'ggi permit no intersection=t' to work around this message. |
| Possible setup errors leading to this situation are: |
| 1. An incorrect axis of rotation for a rotating domain or domain |
| interface. |
| 2. A frame change model is used in which there is unequal pitch |
| shapes, or circumferential orientation, but the Pitch Change |
| model is set to None. |
| 3. The transient rotor stator model is used when the geometry |
| does not span 360 degrees and the Pitch Change model is set to |
| None. |
| An error has occurred in cfx5solve: |
| The ANSYS CFX partitioner has terminated without writing a |
| partitioning information file. |
