- 34
- 2009-9-1
大家好!
现有个疑惑请教各位。请不吝指教~~谢谢。
在《Thin Plates and Shells——Theory,Analysis,and Applications(Ventsel,Krauthammer,2001)》第10章有这么一段关于薄、厚壳的定义,
There are two different classes of shells: thick shells and thin shells. A shell is called thin if the maximum value of the ratio h/R (where R is the radius of curvature
of the middle surface) can be neglected in comparison with unity. For an engineering accuracy, a shell may be regarded as thin if the following condition is satisfied:
示意图如附图所示。
我的问题是,如果壳的厚度h与中面的最小曲率半径R是同个数量级,比如有一块长、宽为100mm×100mm,1mm厚的钢板,在工具的力作用下同时产生双向弯曲,弯曲后的中面曲率半径与料厚同个数量级,
那么此时,钢板应该作为薄壳处理还是厚壳处理?
除了上述薄、厚壳的界定之外,壳体的整体外形尺寸与壳体内变形区的曲率半径的数量级是否对薄、厚壳的界定有直接的影响?
