- 24
- 2005-5-6
发表于 2005-6-2 13:24:48
来自 广西桂林
Re:二次开发问题
可用VBA来编程,我编了个小程序,你可直接使用,或在这基础上修改.
注意:本程序只适用于单行文本实体.
Sub TEXT_ADD_VALUE()
Dim SSetObj As AcadSelectionSet
Dim MyText As AcadText
Dim nStep As Integer
On Error Resume Next
Set SSetObj = ThisDrawing.SelectionSets.Add("TEXTS")
If Err.Number <> 0 Then
Set SSetObj = ThisDrawing.SelectionSets("TEXTS")
End If
ThisDrawing.Utility.Prompt "请选择文本..."
SSetObj.SelectOnScreen
nStep = ThisDrawing.Utility.GetInteger("请输入增量值<0>:")
If nStep = 0 Then Exit Sub
Dim i As Integer, j As Integer
For i = 0 To SSetObj.Count - 1
If SSetObj(i).ObjectName = "AcDbText" Then
Set MyText = SSetObj(i)
MyText.TextString = Val(MyText.TextString) + nStep
j = j + 1
End If
Next
ThisDrawing.Utility.Prompt "运行成功,已修改" & j & "个文本."
End Sub |
