- 5
- 2004-7-13
楼主 |
发表于 2006-1-4 15:58:25
来自 广东佛山
Re:[原创]应用CFD模块求解温度场
命令流(未经许可勿转载www.simwe.com):
!ANSYS初始化
/units,si
/COM, FLOTRAN CFD
/UIS,MSGPOP,3
!结构参数初始化
*SET,MAX_VALUE,1E+8
*SET,MIN_VALUE,1E-8
*SET,FLUID_XMAX,0.405
*SET,FLUID_YMAX,2.7
*SET,DIS_GROUND,0.5
*SET,SOLID_HEIGHT,1
*SET,SOLID_ENDINS,0.05
*SET,COLUMN_ROUT,0.1
*SET,SOLID_RIN,0.115
*SET,SOLID_ROUT,0.135
*SET,SOLID_INSIN,0.004
*SET,SOLID_INSOUT,0.004
*SET,DOWN_MESH_NUM,53
*SET,DOWN_TIMES,0.079096351
*SET,RIGHT_MESH_NUM,42
*SET,RIGHT_TIMES,0.135281602
*SET,UP_MESH_NUM,70
*SET,UP_TIMES,0.034509476
*SET,HGEN_COLUMN,800
*SET,HGEN_SOLID,150000
/PREP7
!定义单元类型及单元属性设置
ET,1,FLUID141
KEYOPT,1,1,0
KEYOPT,1,3,1
KEYOPT,1,4,0
!定义材料导热系数
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,KXX,2,,30
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,KXX,3,,300
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,KXX,4,,0.3
!建立流体模型
RECTNG,0,FLUID_XMAX,0,FLUID_YMAX,
RECTNG,0,COLUMN_ROUT,0,FLUID_YMAX,
RECTNG,SOLID_RIN,SOLID_ROUT,0,FLUID_YMAX,
RECTNG,(SOLID_RIN+SOLID_INSIN),(SOLID_ROUT-SOLID_INSOUT),0,FLUID_YMAX,
RECTNG,0,FLUID_XMAX,DIS_GROUND,(DIS_GROUND+SOLID_HEIGHT),
RECTNG,0,FLUID_XMAX,(DIS_GROUND+SOLID_ENDINS),(DIS_GROUND+SOLID_HEIGHT-SOLID_ENDINS),
ALLSEL,ALL
AOVLAP,ALL
!删除内部面
ALLSEL,ALL
ASEL,S,LOC,X,(SOLID_RIN+SOLID_INSIN),(SOLID_ROUT-SOLID_INSOUT)
ASEL,R,LOC,Y,(DIS_GROUND+SOLID_ENDINS),(DIS_GROUND+SOLID_HEIGHT-SOLID_ENDINS)
ADELE,ALL
ALLSEL,ALL
CM,FLUID_WHOLE,AREA
!网格设置
ALLSEL,ALL
CM,ALL_LINES,LINE
LESIZE,ALL_LINES,0.01, , , , , , ,1
LSEL,S,LOC,X,COLUMN_ROUT,SOLID_ROUT
LSEL,U,LOC,X,(COLUMN_ROUT-MIN_VALUE),(COLUMN_ROUT+MIN_VALUE)
LSEL,U,LOC,X,(SOLID_RIN-MIN_VALUE),(SOLID_RIN+MIN_VALUE)
LSEL,U,LOC,X,(SOLID_ROUT-MIN_VALUE),(SOLID_ROUT+MIN_VALUE)
LSEL,U,LOC,X,(SOLID_RIN+SOLID_INSIN-MIN_VALUE),(SOLID_RIN+SOLID_INSIN+MIN_VALUE)
LSEL,U,LOC,X,(SOLID_ROUT-SOLID_INSOUT-MIN_VALUE),(SOLID_ROUT-SOLID_INSOUT+MIN_VALUE)
CM,LINES_LOCAL,LINE
LESIZE,LINES_LOCAL,0.002,,,,,,,1
CMSEL,S,LINES_LOCAL
LSEL,R,LENGTH,,0,0.005
CM,LINES_SHORTEST,LINE
LESIZE,LINES_SHORTEST,0.0007,,,,,,,1
ALLSEL,ALL
LSEL,S,LOC,Y,0,DIS_GROUND
LSEL,U,LOC,Y,(0-MIN_VALUE),(0+MIN_VALUE)
LSEL,U,LOC,Y,(DIS_GROUND-MIN_VALUE),(DIS_GROUND+MIN_VALUE)
CM,LINES_DOWN,LINE
LESIZE,LINES_DOWN,,,DOWN_MESH_NUM,DOWN_TIMES,,,,1
ALLSEL,ALL
LSEL,S,LOC,X,SOLID_ROUT,FLUID_XMAX
LSEL,U,LOC,X,(FLUID_XMAX-MIN_VALUE),(FLUID_XMAX+MIN_VALUE)
CM,LINES_RIGHT,LINE
LESIZE,LINES_RIGHT,,,RIGHT_MESH_NUM,RIGHT_TIMES,,,,1
ALLSEL,ALL
LSEL,S,LOC,Y,(DIS_GROUND+SOLID_HEIGHT),FLUID_YMAX
LSEL,U,LOC,Y,(DIS_GROUND+SOLID_HEIGHT-MIN_VALUE),(DIS_GROUND+SOLID_HEIGHT+MIN_VALUE)
LSEL,U,LOC,Y,(FLUID_YMAX-MIN_VALUE),(FLUID_YMAX+MIN_VALUE)
CM,LINES_UP,LINE
LESIZE,LINES_UP,,,UP_MESH_NUM,UP_TIMES,,,,1
ALLSEL,ALL
!指定材料属性
ALLSEL,ALL
ASEL,S,LOC,X,0,COLUMN_ROUT
ASEL,R,LOC,Y,DIS_GROUND,(DIS_GROUND+SOLID_HEIGHT)
AATT,2
ALLSEL,ALL
ASEL,S,LOC,X,SOLID_RIN,SOLID_ROUT
AATT,4
!网格划分
ALLSEL,ALL
AMESH,ALL
!流体建模完毕
!建立固体模型
RECTNG, .119, .121, .55, .648,
RECTNG, .119, .121, .65025, .74825,
RECTNG, .119, .121, .7505, .8485,
RECTNG, .119, .121, .85075, .94875,
RECTNG, .119, .121, .951, 1.049,
RECTNG, .119, .121, 1.05125, 1.14925,
RECTNG, .119, .121, 1.1515, 1.2495,
RECTNG, .119, .121, 1.25175, 1.34975,
RECTNG, .119, .121, 1.352, 1.45,
RECTNG, .1215, .1235, .55, .648,
RECTNG, .1215, .1235, .65025, .74825,
RECTNG, .1215, .1235, .7505, .8485,
RECTNG, .1215, .1235, .85075, .94875,
RECTNG, .1215, .1235, .951, 1.049,
RECTNG, .1215, .1235, 1.05125, 1.14925,
RECTNG, .1215, .1235, 1.1515, 1.2495,
RECTNG, .1215, .1235, 1.25175, 1.34975,
RECTNG, .1215, .1235, 1.352, 1.45,
RECTNG, .124, .126, .55, .648,
RECTNG, .124, .126, .65025, .74825,
RECTNG, .124, .126, .7505, .8485,
RECTNG, .124, .126, .85075, .94875,
RECTNG, .124, .126, .951, 1.049,
RECTNG, .124, .126, 1.05125, 1.14925,
RECTNG, .124, .126, 1.1515, 1.2495,
RECTNG, .124, .126, 1.25175, 1.34975,
RECTNG, .124, .126, 1.352, 1.45,
RECTNG, .1265, .1285, .55, .648,
RECTNG, .1265, .1285, .65025, .74825,
RECTNG, .1265, .1285, .7505, .8485,
RECTNG, .1265, .1285, .85075, .94875,
RECTNG, .1265, .1285, .951, 1.049,
RECTNG, .1265, .1285, 1.05125, 1.14925,
RECTNG, .1265, .1285, 1.1515, 1.2495,
RECTNG, .1265, .1285, 1.25175, 1.34975,
RECTNG, .1265, .1285, 1.352, 1.45,
RECTNG, .129, .131, .55, .648,
RECTNG, .129, .131, .65025, .74825,
RECTNG, .129, .131, .7505, .8485,
RECTNG, .129, .131, .85075, .94875,
RECTNG, .129, .131, .951, 1.049,
RECTNG, .129, .131, 1.05125, 1.14925,
RECTNG, .129, .131, 1.1515, 1.2495,
RECTNG, .129, .131, 1.25175, 1.34975,
RECTNG, .129, .131, 1.352, 1.45,
ALLSEL,ALL
CMSEL,U,FLUID_WHOLE
CM,SOLID_LEAD,AREA
RECTNG, .119, .131, .55, 1.45,
RECTNG, .121, .1215, .55, 1.45,
RECTNG, .1235, .124, .55, 1.45,
RECTNG, .126, .1265, .55, 1.45,
RECTNG, .1285, .129, .55, 1.45,
RECTNG, .119, .131, .648, .65025,
RECTNG, .119, .131, .74825, .7505,
RECTNG, .119, .131, .8485, .85075,
RECTNG, .119, .131, .94875, .951,
RECTNG, .119, .131, 1.049, 1.05125,
RECTNG, .119, .131, 1.14925, 1.1515,
RECTNG, .119, .131, 1.2495, 1.25175,
RECTNG, .119, .131, 1.34975, 1.352,
ALLSEL,ALL
CMSEL,U,FLUID_WHOLE
AOVLAP,ALL
ALLSEL,ALL
CMSEL,U,FLUID_WHOLE
CM,SOLID,AREA
!网格设置
ALLSEL,ALL
CMSEL,U,FLUID_WHOLE
ALLSEL,BELOW,AREA
CM,ALLLINES_SOLID,LINE
LESIZE,ALLLINES_SOLID,0.005,,,,,,,1
!指定材料属性
AATT,4
ALLSEL,ALL
CMSEL,S,SOLID_LEAD
AATT,3
!网格划分
ALLSEL,ALL
CMSEL,U,FLUID_WHOLE
AMESH,ALL
!固体建模完毕
FINI
ALLSEL,ALL
/SOLU
!施加边界条件
NSEL,S,LOC,X,0
CM,SYM_NODES,NODE
D,SYM_NODES,VX,0
NSEL,S,LOC,X,FLUID_XMAX
CM,OUTER_NODES,NODE
D,OUTER_NODES,PRES,0
D,ALL,,20,,,,TEMP,,,,,
NSEL,S,LOC,Y,0
CM,DOWN_NODES,NOD
D,DOWN_NODES,VX,0
D,DOWN_NODES,VY,0
NSEL,S,LOC,Y,FLUID_YMAX
CM,UP_NODES,NODE
D,UP_NODES,PRES,0
ALLSEL,ALL
!施加辐射边界条件
ASEL,S,MAT,,2
ASEL,A,MAT,,4
LSEL,S,EXT
CM,RADIATION_LINES,LINE
LSEL,R,LOC,Y,(DIS_GROUND-MIN_VALUE),(DIS_GROUND+MIN_VALUE)
CM,RAD_DOWN_LINES,LINE
SFL,RAD_DOWN_LINES,RAD,0.9,,20
ALLSEL,ALL
CMSEL,S,RADIATION_LINES
LSEL,R,LOC,X,(SOLID_ROUT-MIN_VALUE),(SOLID_ROUT+MIN_VALUE)
CM,RAD_RIGHT_LINES,LINE
SFL,RAD_RIGHT_LINES,RAD,0.9,,20
ALLSEL,ALL
LSEL,R,LOC,Y,(DIS_GROUND+SOLID_HEIGHT-MIN_VALUE),(DIS_GROUND+SOLID_HEIGHT+MIN_VALUE)
CM,RAD_UP1_LINES,LINE
SFL,RAD_UP1_LINES,RAD,0.9,,20
ALLSEL,ALL
LSEL,R,LOC,X,(COLUMN_ROUT-MIN_VALUE),(COLUMN_ROUT+MIN_VALUE)
SFL,ALL,RDSF,0.9,,-1,
LSEL,R,LOC,X,(SOLID_RIN-MIN_VALUE),(SOLID_RIN+MIN_VALUE)
!施加体积生热率
ALLSEL,ALL
ASEL,S,MAT,,2
BFA,ALL,HGEN,HGEN_COLUMN
ALLSEL,ALL
CMSEL,S,SOLID_LEAD
BFA,ALL,HGEN,HGEN_SOLID
!边界条件施加完毕
FINI
ALLSEL,ALL
/PREP7
!耦合结点
CMSEL,S,FLUID_WHOLE
ALLSEL,BELOW,AREA
NSEL,S,EXT
NSEL,U,LOC,X,0
NSEL,U,LOC,Y,0
NSEL,U,LOC,X,FLUID_XMAX
NSEL,U,LOC,Y,FLUID_YMAX
NSEL,R,LOC,X,SOLID_RIN,SOLID_ROUT
CM,FLUID_SOLID_CPNODES,NODE
*GET,FLUID_SOLID_CPNUM,NODE,,COUNT,,,,
*GET,NUMLOW_FLUID_SOLID_CPNODES,NODE,,NUM,MIN,,,
*DIM,ARRAY_FLUID_SOLID_CPNODES,ARRAY,FLUID_SOLID_CPNUM,3,1,,,
*SET,TEMP_NODE_NUM,NUMLOW_FLUID_SOLID_CPNODES
*SET,ARRAY_FLUID_SOLID_CPNODES(1,1,1),TEMP_NODE_NUM
*SET,ARRAY_FLUID_SOLID_CPNODES(1,2,1),NX(TEMP_NODE_NUM)
*SET,ARRAY_FLUID_SOLID_CPNODES(1,3,1),NY(TEMP_NODE_NUM)
*DO,I,2,FLUID_SOLID_CPNUM
*SET,ARRAY_FLUID_SOLID_CPNODES(I,1,1),NDNEXT(TEMP_NODE_NUM)
*SET,ARRAY_FLUID_SOLID_CPNODES(I,2,1),NX(NDNEXT(TEMP_NODE_NUM))
*SET,ARRAY_FLUID_SOLID_CPNODES(I,3,1),NY(NDNEXT(TEMP_NODE_NUM))
*SET,TEMP_NODE_NUM,NDNEXT(TEMP_NODE_NUM)
*ENDDO
ALLSEL,ALL
CMSEL,U,FLUID_WHOLE
ALLSEL,BELOW,AREA
NSEL,S,EXT
CM,SOLID_SOLID_CPNODES,NODE
*GET,SOLID_SOLID_CPNUM,NODE,,COUNT,,,,
*GET,NUMLOW_SOLID_SOLID_CPNODES,NODE,,NUM,MIN,,,
*DIM,ARRAY_SOLID_SOLID_CPNODES,ARRAY,SOLID_SOLID_CPNUM,3,1,,,
*SET,TEMP_NODE_NUM,NUMLOW_SOLID_SOLID_CPNODES
*SET,ARRAY_SOLID_SOLID_CPNODES(1,1,1),TEMP_NODE_NUM
*SET,ARRAY_SOLID_SOLID_CPNODES(1,2,1),NX(TEMP_NODE_NUM)
*SET,ARRAY_SOLID_SOLID_CPNODES(1,3,1),NY(TEMP_NODE_NUM)
*DO,I,2,SOLID_SOLID_CPNUM
*SET,ARRAY_SOLID_SOLID_CPNODES(I,1,1),NDNEXT(TEMP_NODE_NUM)
*SET,ARRAY_SOLID_SOLID_CPNODES(I,2,1),NX(NDNEXT(TEMP_NODE_NUM))
*SET,ARRAY_SOLID_SOLID_CPNODES(I,3,1),NY(NDNEXT(TEMP_NODE_NUM))
*ENDDO
*DIM,TEMP_ROW,ARRAY,1,2,1,,,
*SET,N,1
*DO,I,1,FLUID_SOLID_CPNUM
*SET,TEMP_ROW(1,2,1),1E+8
*DO,J,1,SOLID_SOLID_CPNUM
*IF,ARRAY_FLUID_SOLID_CPNODES(I,2,1),EQ,ARRAY_SOLID_SOLID_CPNODES(J,2,1),THEN
*IF,ABS(ARRAY_FLUID_SOLID_CPNODES(I,3,1)-ARRAY_SOLID_SOLID_CPNODES(J,3,1)),LT,TEMP_ROW(1,2,1),THEN
*SET,TEMP_ROW(1,1,1),ARRAY_SOLID_SOLID_CPNODES(J,1,1)
*SET,TEMP_ROW(1,2,1),ABS(ARRAY_FLUID_SOLID_CPNODES(I,3,1)-ARRAY_SOLID_SOLID_CPNODES(J,3,1))
*ENDIF
*ELSEIF,ARRAY_FLUID_SOLID_CPNODES(I,3,1),EQ,ARRAY_SOLID_SOLID_CPNODES(J,3,1),THEN
*IF,ABS(ARRAY_FLUID_SOLID_CPNODES(I,2,1)-ARRAY_SOLID_SOLID_CPNODES(J,2,1)),LT,TEMP_ROW(1,2,1),THEN
*SET,TEMP_ROW(1,2,1),ABS(ARRAY_FLUID_SOLID_CPNODES(I,2,1)-ARRAY_SOLID_SOLID_CPNODES(J,2,1))
*ENDIF
*ENDIF
*ENDDO
ALLSEL,ALL
NSEL,S,,,ARRAY_FLUID_SOLID_CPNODES(I,1,1)
NSEL,A,,,TEMP_ROW(1,1,1)
CP,N,ALL,ALL
N=N+7
*ENDDO
!结点耦合完毕
ALLSEL,ALL
FINI
!设置参考温度为摄氏温度
/PREP7
TOFFST,273
FINI
/SOL
!热分析
FLDATA1,SOLU,TEMP,1
!每20步分析计算一次,每10步记录结果一次
FLDATA2,ITER,EXEC,20,
FLDATA2,ITER,OVER,10,
FLDATA2,ITER,APPE,10,
!设置空气属性
FLDATA12,PROP,DENS,4
FLDATA13,VARY,DENS,1
FLDATA12,PROP,VISC,4
FLDATA13,VARY,VISC,0
FLDATA12,PROP,COND,4
FLDATA13,VARY,COND,0
FLDATA12,PROP,SPHT,4
FLDATA13,VARY,SPHT,0
FLDATA7,PROT,DENS,AIR-SI
FLDATA7,PROT,VISC,AIR-SI
FLDATA7,PROT,COND,AIR-SI
FLDATA7,PROT,SPHT,AIR-SI
!重力加速度
ACEL,0,9.81,0,
FINI
/AUX12
!设置辐射参数
STEF,0.567E-07
!Auto Legend
/PLOPTS,INFO,2
ALLSEL,ALL
FINI
!建模完毕 |
