- 8
- 2006-2-20
楼主 |
发表于 2007-8-30 13:18:03
来自 湖南长沙
Date: 08/27/2007 Time: 07:23:50
Executing with local workstation license
___________________________________________________
| Livermore Software Technology Corporation |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Version: 970 beta Date: 10/20/2004 |
| Revision: 5860 Time: 23:40:32 |
| Features enabled in this version: |
| Distributed Memory Parallel |
| Licensed to: Great Computer Center, Hunan Unive |
| Platform : IBM Workstation (PWR3 64Bits) |
| OS Level : AIX 5.1 |
| Hostname : n02 |
| Precision : Single precision (I4R4) |
| Unauthorized use infringes LSTC copyrights |
Input file: feiji51.k
The native file format : 32-bit big endian
Memory size from command line: 200000000
on UNIX computers note the following change:
ctrl-c interrupts ls-dyna and prompts for a sense switch.
type the desired sense switch: sw1., sw2., etc. to continue
the execution. ls-dyna will respond as explained in the users manual
type response
sw1. a restart file is written and ls-dyna terminates.
sw2. ls-dyna responds with time and cycle numbers.
sw3. a restart file is written and ls-dyna continues calculations.
sw4. a plot state is written and ls-dyna continues calculations.
sw5. ls-dyna enters interactive graphics phase.
swa. ls-dyna flushes all output i/o buffers.
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Explicit Finite Element code. *
* the validity, accuracy, or applicability of any results *
* obtained from this system. The user must verify his own *
* results. *
* LSTC endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LSTC through your site focus. *
* Copyright (C) 1990-2004 *
* by Livermore Software Technology Corp. (LSTC) *
* All rights reserved *
Initial reading of file
Performing Decomposition -- Phase 1
Performing Recursive Coordinate Bisection (RCB)
Performing Decomposition -- Phase 2
Warning: Soft constraint unsupported on sliding interface type 9
soft constraint turned off for sliding interface 7
soft constraint turned off for sliding interface 8
soft constraint turned off for sliding interface 9
soft constraint turned off for sliding interface 10
soft constraint turned off for sliding interface 11
soft constraint turned off for sliding interface 12
soft constraint turned off for sliding interface 13
soft constraint turned off for sliding interface 14
Performing Decomposition -- Phase 3
input of data is completed
slave stiffness of sliding interface 15 is scaled by 7.52985E-02
master stiffness of sliding interface 15 is scaled by 1.32805E+01
slave stiffness of sliding interface 16 is scaled by 7.52537E-02
master stiffness of sliding interface 16 is scaled by 1.32884E+01
initial kinetic energy = .98542163E+03
The LS-DYNA time step size should not exceed .466E-03
to avoid contact instabilities. If the step size is
bigger then scale the penalty of the offending surface.
initialization completed
Initial penetration for SI 7 .00000
Initial penetration for SI 8 .00000
Initial penetration for SI 9 1.05108
Initial penetration for SI 10 2.80402
Initial penetration for SI 11 1.05108
Initial penetration for SI 12 2.80402
Initial penetration for SI 13 .00000
Initial penetration for SI 14 .00000
dt of cycle 1 is controlled by shell element 163663
time........................... 0.00000E+00
time step...................... 2.06037E-03
kinetic energy................. 9.85434E+02
internal energy................ 4.00000E-20
spring and damper energy....... 4.00000E-20
hourglass energy .............. 0.00000E+00
system damping energy.......... 0.00000E+00
sliding interface energy....... 0.00000E+00
external work.................. 0.00000E+00
eroded kinetic energy.......... 0.00000E+00
eroded internal energy......... 0.00000E+00
total energy................... 9.85434E+02
total energy / initial energy.. 1.00000E+00
energy ratio w/o eroded energy. 1.00000E+00
global x velocity.............. 8.28956E-02
global y velocity.............. 0.00000E+00
global z velocity.............. -1.24251E-02
cpu time per zone cycle............ 1212 nanoseconds
average cpu time per zone cycle.... 1212 nanoseconds
average clock time per zone cycle.. 0 nanoseconds
estimated total cpu time = 165048 sec ( 45 hrs 50 mins)
estimated cpu time to complete = 165019 sec ( 45 hrs 50 mins)
estimated total clock time = 0 sec ( 0 hrs 0 mins)
estimated clock time to complete = 0 sec ( 0 hrs 0 mins)
1 t 0.0000E+00 dt 2.06E-03 flush i/o buffers
1 t 0.0000E+00 dt 2.06E-03 write d3plot file
4854 t 9.9990E+00 dt 2.06E-03 write d3plot file
5000 t 1.0300E+01 dt 2.06E-03 flush i/o buffers
9708 t 2.0000E+01 dt 2.06E-03 write d3plot file
10000 t 2.0602E+01 dt 2.06E-03 flush i/o buffers
14561 t 2.9999E+01 dt 2.06E-03 write d3plot file
15000 t 3.0903E+01 dt 2.06E-03 flush i/o buffers
19415 t 4.0000E+01 dt 2.06E-03 write d3plot file
20000 t 4.1205E+01 dt 2.06E-03 flush i/o buffers
*** Warning Airbag data not written to full restart file
20000 t 4.1207E+01 dt 2.06E-03 write d3dump01 file
24268 t 4.9999E+01 dt 2.06E-03 write d3plot file
25000 t 5.1507E+01 dt 2.06E-03 flush i/o buffers
29122 t 6.0000E+01 dt 2.06E-03 write d3plot file
30000 t 6.1809E+01 dt 2.06E-03 flush i/o buffers
33975 t 6.9999E+01 dt 2.06E-03 write d3plot file
35000 t 7.2111E+01 dt 2.06E-03 flush i/o buffers
38829 t 8.0000E+01 dt 2.06E-03 write d3plot file
40000 t 8.2413E+01 dt 2.06E-03 flush i/o buffers
40000 t 8.2415E+01 dt 2.06E-03 write d3dump02 file
43682 t 8.9999E+01 dt 2.06E-03 write d3plot file
45000 t 9.2715E+01 dt 2.06E-03 flush i/o buffers
48536 t 1.0000E+02 dt 2.06E-03 write d3plot file
50000 t 1.0302E+02 dt 2.06E-03 flush i/o buffers
53389 t 1.1000E+02 dt 2.06E-03 write d3plot file
55000 t 1.1332E+02 dt 2.06E-03 flush i/o buffers
58243 t 1.2000E+02 dt 2.06E-03 write d3plot file
60000 t 1.2362E+02 dt 2.06E-03 flush i/o buffers
60000 t 1.2362E+02 dt 2.06E-03 write d3dump03 file
63096 t 1.3000E+02 dt 2.06E-03 write d3plot file
65000 t 1.3392E+02 dt 2.06E-03 flush i/o buffers
67950 t 1.4000E+02 dt 2.06E-03 write d3plot file
70000 t 1.4422E+02 dt 2.06E-03 flush i/o buffers
72803 t 1.5000E+02 dt 2.06E-03 write d3plot file
75000 t 1.5453E+02 dt 2.06E-03 flush i/o buffers
77657 t 1.6000E+02 dt 2.06E-03 write d3plot file
80000 t 1.6483E+02 dt 2.06E-03 flush i/o buffers
80000 t 1.6483E+02 dt 2.06E-03 write d3dump04 file
82510 t 1.7000E+02 dt 2.06E-03 write d3plot file
85000 t 1.7513E+02 dt 2.06E-03 flush i/o buffers
87364 t 1.8000E+02 dt 2.06E-03 write d3plot file
90000 t 1.8543E+02 dt 2.06E-03 flush i/o buffers
92217 t 1.9000E+02 dt 2.06E-03 write d3plot file
95000 t 1.9573E+02 dt 2.06E-03 flush i/o buffers
97071 t 2.0000E+02 dt 2.06E-03 write d3plot file
100000 t 2.0603E+02 dt 2.06E-03 flush i/o buffers
100000 t 2.0604E+02 dt 2.06E-03 write d3dump05 file
101924 t 2.1000E+02 dt 2.06E-03 write d3plot file
105000 t 2.1634E+02 dt 2.06E-03 flush i/o buffers
106778 t 2.2000E+02 dt 2.06E-03 write d3plot file
110000 t 2.2664E+02 dt 2.06E-03 flush i/o buffers
111631 t 2.3000E+02 dt 2.06E-03 write d3plot file
115000 t 2.3694E+02 dt 2.06E-03 flush i/o buffers
116485 t 2.4000E+02 dt 2.06E-03 write d3plot file
120000 t 2.4724E+02 dt 2.06E-03 flush i/o buffers
120000 t 2.4724E+02 dt 2.06E-03 write d3dump06 file
121338 t 2.5000E+02 dt 2.06E-03 write d3plot file
125000 t 2.5754E+02 dt 2.06E-03 flush i/o buffers
126192 t 2.6000E+02 dt 2.06E-03 write d3plot file
130000 t 2.6785E+02 dt 2.06E-03 flush i/o buffers
131045 t 2.7000E+02 dt 2.06E-03 write d3plot file
135000 t 2.7815E+02 dt 2.06E-03 flush i/o buffers
135899 t 2.8000E+02 dt 2.06E-03 write d3plot file
140000 t 2.8845E+02 dt 2.06E-03 flush i/o buffers
140000 t 2.8845E+02 dt 2.06E-03 write d3dump07 file
140752 t 2.9000E+02 dt 2.06E-03 write d3plot file
145000 t 2.9875E+02 dt 2.06E-03 flush i/o buffers
145606 t 3.0000E+02 dt 2.06E-03 write d3plot file
150000 t 3.0905E+02 dt 2.06E-03 flush i/o buffers
150459 t 3.1000E+02 dt 2.06E-03 write d3plot file
155000 t 3.1936E+02 dt 2.06E-03 flush i/o buffers
155313 t 3.2000E+02 dt 2.06E-03 write d3plot file
160000 t 3.2966E+02 dt 2.06E-03 flush i/o buffers
160000 t 3.2966E+02 dt 2.06E-03 write d3dump08 file
160166 t 3.3000E+02 dt 2.06E-03 write d3plot file
165000 t 3.3996E+02 dt 2.06E-03 flush i/o buffers
165020 t 3.4000E+02 dt 2.06E-03 write d3plot file
169873 t 3.5000E+02 dt 2.06E-03 write d3plot file
170000 t 3.5026E+02 dt 2.06E-03 flush i/o buffers
174727 t 3.6000E+02 dt 2.06E-03 write d3plot file
175000 t 3.6056E+02 dt 2.06E-03 flush i/o buffers
179580 t 3.7000E+02 dt 2.06E-03 write d3plot file
180000 t 3.7086E+02 dt 2.06E-03 flush i/o buffers
180000 t 3.7087E+02 dt 2.06E-03 write d3dump09 file
184434 t 3.8000E+02 dt 2.06E-03 write d3plot file
185000 t 3.8117E+02 dt 2.06E-03 flush i/o buffers
189287 t 3.9000E+02 dt 2.06E-03 write d3plot file
190000 t 3.9147E+02 dt 2.06E-03 flush i/o buffers
194141 t 4.0000E+02 dt 2.06E-03 write d3plot file
195000 t 4.0177E+02 dt 2.06E-03 flush i/o buffers
198994 t 4.1000E+02 dt 2.06E-03 write d3plot file
200000 t 4.1207E+02 dt 2.06E-03 flush i/o buffers
200000 t 4.1207E+02 dt 2.06E-03 write d3dump10 file
203848 t 4.2000E+02 dt 2.06E-03 write d3plot file
205000 t 4.2237E+02 dt 2.06E-03 flush i/o buffers
208701 t 4.3000E+02 dt 2.06E-03 write d3plot file
210000 t 4.3268E+02 dt 2.06E-03 flush i/o buffers
213555 t 4.4000E+02 dt 2.06E-03 write d3plot file
215000 t 4.4298E+02 dt 2.06E-03 flush i/o buffers
218408 t 4.5000E+02 dt 2.06E-03 write d3plot file
220000 t 4.5328E+02 dt 2.06E-03 flush i/o buffers
220000 t 4.5328E+02 dt 2.06E-03 write d3dump11 file
223262 t 4.6000E+02 dt 2.06E-03 write d3plot file
225000 t 4.6358E+02 dt 2.06E-03 flush i/o buffers
228115 t 4.7000E+02 dt 2.06E-03 write d3plot file
230000 t 4.7388E+02 dt 2.06E-03 flush i/o buffers
232969 t 4.8000E+02 dt 2.06E-03 write d3plot file
235000 t 4.8418E+02 dt 2.06E-03 flush i/o buffers
237822 t 4.9000E+02 dt 2.06E-03 write d3plot file
240000 t 4.9449E+02 dt 2.06E-03 flush i/o buffers
240000 t 4.9449E+02 dt 2.06E-03 write d3dump12 file
242676 t 5.0000E+02 dt 2.06E-03 write d3plot file
245000 t 5.0479E+02 dt 2.06E-03 flush i/o buffers
247529 t 5.1000E+02 dt 2.06E-03 write d3plot file
250000 t 5.1509E+02 dt 2.06E-03 flush i/o buffers
252383 t 5.2000E+02 dt 2.06E-03 write d3plot file
255000 t 5.2539E+02 dt 2.06E-03 flush i/o buffers
257236 t 5.3000E+02 dt 2.06E-03 write d3plot file
260000 t 5.3569E+02 dt 2.06E-03 flush i/o buffers
260000 t 5.3570E+02 dt 2.06E-03 write d3dump13 file
262090 t 5.4000E+02 dt 2.06E-03 write d3plot file
265000 t 5.4600E+02 dt 2.06E-03 flush i/o buffers
266943 t 5.5000E+02 dt 2.06E-03 write d3plot file
270000 t 5.5630E+02 dt 2.06E-03 flush i/o buffers
271797 t 5.6000E+02 dt 2.06E-03 write d3plot file
275000 t 5.6660E+02 dt 2.06E-03 flush i/o buffers
276650 t 5.7000E+02 dt 2.06E-03 write d3plot file
280000 t 5.7690E+02 dt 2.06E-03 flush i/o buffers
280000 t 5.7690E+02 dt 2.06E-03 write d3dump14 file
281504 t 5.8000E+02 dt 2.06E-03 write d3plot file
285000 t 5.8720E+02 dt 2.06E-03 flush i/o buffers
286357 t 5.9000E+02 dt 2.06E-03 write d3plot file
290000 t 5.9750E+02 dt 2.06E-03 flush i/o buffers
291211 t 6.0000E+02 dt 2.06E-03 write d3plot file
计算到这里就中止了,也没有任何错误提示.
我用的IBM的机器,采用的是linux操作系统.恳请shanget给我指导,感谢! |
