- 55
- 2005-4-25
楼主 |
发表于 2007-9-18 12:53:51
来自 湖北宜昌
去掉网格的inp文件
*Surface, type=ELEMENT, name=top_sur
top, S1
*Solid Section, elset=press, material=STEEL
3.68155,
** Region: (Section-2-SOLIDMAP:SOLIDMAP)
** Section: Section-2-SOLIDMAP
*Solid Section, elset=solidmap, material=CON
1.,
** Constraint: Embed-1
*Embedded Element
press
** MATERIALS
*Material, name=CON
*Density
2.6e-05,
*Elastic
3.5e+06, 0.1667
*Material, name=STEEL
*Density
7.85e-05,
*Elastic
1.95e+07, 0.3
*Expansion
1e-05,
** STEP: Step-1
*Step, name=Step-1
*Static
1., 1., 1e-05, 1.
*model change,type=element,remove
press
** BOUNDARY CONDITIONS
** Name: Disp-BC-1 Type: Displacement/Rotation
*Boundary
bom_l, 1, 1
** Name: Disp-BC-2 Type: Displacement/Rotation
*Boundary
bom_l, 2, 2
** Name: Disp-BC-3 Type: Displacement/Rotation
*Boundary
bom_l, 3, 3
** Name: Disp-BC-4 Type: Displacement/Rotation
*Boundary
bom_r, 2, 2
** Name: Disp-BC-5 Type: Displacement/Rotation
*Boundary
bom_r, 3, 3
** LOADS
** Name: Load-1 Type: Gravity
*Dload
, GRAV, 980., 0., 0., -1.
** OUTPUT REQUESTS
*Restart, write, frequency=0
** FIELD OUTPUT: F-Output-1
*Output, field, variable=PRESELECT
** HISTORY OUTPUT: H-Output-1
*Output, history, variable=PRESELECT
*End Step
** STEP: Step-2
*Step, name=Step-2
*Static
1., 1., 1e-05, 1.
*model change,add=with strain
press
** FIELDS
** Name: Field-1 Type: Temperature
*Temperature
pre_node, -764.
** OUTPUT REQUESTS
*End Step
** STEP: Step-3
*Step, name=Step-3, inc=80
*Static, direct
10., 800.,
*Dsload
top_sur, PNU, 1.
** OUTPUT REQUESTS
*End Step |
