- 14
- 2011-1-19
发表于 2011-7-31 12:42:39
来自 湖北武汉
帮助文件:
/CONFIG
/CONFIG, Lab, VALUE
Assigns values to ANSYS configuration parameters.
Lab
Configuration parameter to be changed:
NRES
VALUE is maximum number of results sets (substeps) allowed on the result file. Defaults to 1000. For MFX analyses, defaults to 5000. Minimum is 10.
NORSTGM
Option to write or not write geometry data to the results file. VALUE is either 0 (write geometry data) or 1 (do not write geometry data). Useful when complex analyses will create abnormally large files. Default is 0.
NBUF
VALUE is the number of buffers (1 to 32) per file in the solver. Defaults to 4.
LOCFL
File open and close actions. For VALUE use: 0 for global (default); 1 for local. Applicable to File.EROT, File.ESAV, and File.EMAT. Typically used for large problems where locally closed files may be deleted earlier in the run with the /FDELE command.
SZBIO
VALUE is the record size (1024 to 4194304) of binary files (in integer words). Defaults to 16384 (system dependent).
ORDER
Automatic reordering scheme. For VALUE use: 0 for WSORT,ALL; 1 for WAVES; 2 for both WSORT,ALL and WAVES (default).
FSPLIT
Defines split points for binary files. VALUE is the file split point in megawords and defaults to the maximum file size for the system.
MXND
Maximum number of nodes. If not specified, defaults to 100 at first encounter. Dynamically expanded by doubling, even at first encounter, when maximum is exceeded.
MXEL
Maximum number of elements. Default and expansion as for MXND.
MXKP
Maximum number of keypoints. Default and expansion as for MXND.
MXLS
Maximum number of lines. Default and expansion as for MXND.
MXAR
Maximum number of areas. Default and expansion as for MXND.
MXVL
Maximum number of volumes. Default and expansion as for MXND.
MXRL
Maximum number of sets of real constants (element attributes). Default and expansion as for MXND.
MXCP
Maximum number of sets of coupled degrees of freedom. Default and expansion as for MXND.
MXCE
Maximum number of constraint equations. Default and expansion as for MXND.
NOELDB
Option to write or not write results into the database after a solution. When VALUE = 0 (default), write results into the database. When VALUE = 1, do not write results into the database.
DYNA_DBL
Option to invoke the double precision version of the explicit dynamics solver LS-DYNA. When VALUE = 0 (default), the single precision version is used. When VALUE = 1, the double precision version is used.
STAT
Displays current values set by the /CONFIG command.
VALUE
Value (an integer number) assigned to the configuration parameter. |
