- 2005-12-7
参照刘展主编的《abaqus6.6基础教程与实例详解》第351页12.5销钉过盈装配失效预测分析的二维分析。尝试做下面的三维模拟,
共两个圆柱,过盈量为0.005mm,外圆柱固定,内圆柱向下移动。源文件见附件。结果内外圆柱上的应力相差11个量级,这样的结果正确吗。
如果第一个step的位移量为0.005,则会出现如下警告:
There are 2 unconnected regions in the model.
There is zero FORCE everywhere in the model based on the default criterion. please check the value of the average FORCE during
the current iteration to verify that the FORCE is small enough to be treated as zero. if not, please use the solution controls
to reset the criterion for zero FORCE.
若改为0.5,则只剩下
另外书上的例题可以通过运行,但第三个step中的pressure的加载区域和数值是如何决定的,有什么作用,我不太清楚,所以三维模拟时没有加这一步,
不知道是否阐述明白,请大家指教! |
