- 15
- 2008-7-20
MathType works with Mathematica Mathematica is a popular computer algebra system that has the capability of using MathML both for input and output.
Inserting a MathType equation into MathematicaAfter you create an equation in the MathType editing window, follow these steps to insert it into your Mathematica notebook:
- Select Translators... from the Preferences menu.
- Select the translator Mathematica -- MathML. Make sure the two checkboxes Include translator name in translation and Include MathType data in translation are not checked. You do not need to perform this step for every equation. Once you select the appropriate translator, future equations will be translated using this translator until you select a different one.
- Select the equation or equation fragment you want to insert into Mathematica, and copy it to the clipboard (Ctrl+C).
- Paste the equation into a Mathematica notebook (Ctrl+V). The equation may now be used just like any other Mathematica equation.
Inserting a Mathematica equation into MathTypeIf you have an equation in a Mathematica notebook that you want to use in MathType, follow these steps:
- Select the equation.
- Right-click the equation, and choose Copy as -> MathML from the contextual menu.
- Paste the equation into MathType. The equation may now be edited and used just like any other MathType equation.
Tips for Best ResultsFollowing the steps above, one can easily cut and paste mathematical expressions between Mathematica and MathType. However, in order to evaluate or symbolically manipulate a MathType expressions in Mathematica, it may be necessary to further edit the expression once you have pasted it into Mathematica.
Mathematica uses a number of syntax conventions for mathematical expressions that allow it to maintain an internal representation suitable for calculation. By contrast, MathType is an equation editor, concerned primarily with giving authors an easy way to create nicely styled and well-typeset notations, and doesn't impose any restrictions on the notations created. As a result, it will often be necessary to "fix up" a MathType expression you have pasted into Mathematica to ensure it conforms to Mathematica conventions. There are two areas in particular that are worth highlighting, since they arise frequently:
- Special Symbols. Mathematica uses three special symbols to eliminate ambiguities from expressions. Specifically, Mathematica uses a special DifferentialD character for the d in a differential (e.g. dx), an ExponentialE character for Euler's constant, and an ImaginaryI character for the square root of -1. Since Mathematica relies on these characters, you will need to edit your expressions to use them as well. Typically, you would do this after pasting into Mathematica, but before evaluation.
These characters can be used directly in MathType, if you have Mathematica's fonts installed on your system. Use the Edit | Insert Symbol command on the MathType window to open the Insert Symbol dialog. Choose View by Description from the pull down menu at the top, and then click the "New Search" button. Search for "differential" (or "exponential" or "imaginary" as appropriate). The relevant Mathematica characters will appear among the results. Choose the one appropriate for your expression. - Explicit Grouping. In many mathematical expressions, the proper grouping of terms is not explicit, and instead relies on the reader's understanding of notational conventions. For calculation, however, underspecified grouping is a common source of errors. Both Mathematica and MathType employ algorithms to infer the proper grouping in underspecified expressions. However, for best results, we recommend adding parentheses to make grouping explicit in the following situations:
- Add parentheses around function arguments. This is particularly important for trigonometric functions where parenthesis are often omitted in print, e.g. use sin(2x)instead of sin 2x.
- Add parentheses around integrands, e.g.
vs .
The parentheses should not include the differential.
If you have experience with Mathematica and have specific tips about how best to use MathType to work with it, we would love to hear from you. Please send questions, comments and suggestions to interop@dessci.com.
The Professional version
of Equation Editor
$97 ($57 academic) Upgrade $49 ($37 academic)
| | | | | | | | | MathType is a powerful interactive equation editor for Windows and Macintosh that lets you create mathematical notation for word processing, web pages, desktop publishing, presentations, and for TeX, LaTeX, and MathML documents. MathType works with 100s of applications and websites, allowing you to put Equations Everywhere and Anywhere™.
| Equations Everywhere and Anywhere!™While we know that most MathType users create equations for Microsoft Word documents and PowerPoint presentations, we also know that our customers are working with many other applications and websites these days. They calculate with Excel, Mathematica or Maple, create graphs in DeltaGraph, and compute statistics in SAS or Minitab, find equations on Wikipedia and PlanetMath, to name just a few. They are also working with social software such as blogs, wikis, forums, as well as communicating using instant messaging, email, bulletin boards, etc. While MathType has worked with many of these applications and websites for years, we at Design Science are making a concerted effort to enable MathType users to create equations everywhere and anywhere. Scan our MathType Interoperability List below and see that MathType already works with many of your favorite applications and websites.
MathType Interoperability RegistryThis is our list of applications and websites that MathType works with. Many of them allow you to create equations using an Insert Object command. Others work with simple cut-and-paste or drag-and-drop. Yet more can accept EPS or GIF equation image files created by MathType. For many of these applications and websites, MathType includes online help pages describing how best to work with it.
MathType also works with many more that we just don't know about or have yet to evaluate. Please send an email to interop@dessci.com and let us know any we missed, or to tell us about those that you wished worked better with MathType. We are working hard to make MathType your universal equation editing solution. We need your feedback!
Top 10 Applications- Apple iWork
- MS Word
- Moodle
- Adobe InDesign
- MS PowerPoint
| - SMART Notebook
- Open Office
- Mathematica
- Maple
- Blackboard
| View by: Alphabetic Order | Product Category
Jump to: A B C D E F G H I J K L M N O P Q R S T U V W X Y Z 0 – 9 Other
A - Access
- ACD/ChemSketch
- Adobe Dreamweaver
- Adobe Flash
- Adobe InDesign
- Adobe Pagemaker
- Amaya
- Apple iWork
- Apple Keynote
- Apple Numbers
- Apple Pages
- AppleWorks
- ArcInfo
- ASCIIMathML.js
- AutoCAD
- Autodesk
- Autodesk Inventor
- Autograph
- AutoSketch
B - Blackboard
- BraMaNet
- BrowseAloud
C - Canvas
- CATIA
- ChemDraw
- Chemistry Central Journal
- ChemSketch
- ChemWindow
- Christina's LIS Rant
- Cl1p
- ConceptDraw
- Corel DESIGNER
- Corel Ventura
- Corel WordPerfect
- Corel WordPerfect Office
- CorelDRAW
- Crystal Reports
D - Dadzilla
- DeltaGraph
- DESIGNER
- Digital Library of Mathematical Functions
- DLMF
- DragMath
- Dreamweaver
E - EdCompBlog
- EdiTeX
- EditLive!
- Edraw Max
- Ephox EditLive! WebEQ Equation Editor
- Equation Server for .NET
- EquationSheet
- Excel
- Expression Web
- Expressionism
F - FastReport
- FastReport Studio
- FileMaker
- Firefox & other Gecko browsers
- Firemath
- Flash
- Formulator MathML IE Performer
- FrontPage
G - GELLMU
- Gliffy
- Google Docs
- GtkMathView
H I - IE
- InDesign
- InfoRapid Cardfile System
- Integre techexplorer
- Internet Explorer
- ISIS/Draw
- ItexToMML plugin
- iWork
J - Jarte
- Jarte Plus
- JAWS
- jsMath
- jsTeXrender
- JungUm Global
K - Keynote
- Kingsoft Office
- Kingsoft Presentation
- Kingsoft Spreadsheets
- Kingsoft Writer
L - LaTeX Equation Editor
- LaTeXMathML
- Learnwise
- Lotus Word Pro
M - MAGic
- MAGic with Speech
- Maple
- Math & Engineering Equation Library
- Math Help Forum
- MathBB
- MathEdit
- Mathematica
- MathFlow
- MathML IE Performer
- MathML on Web
- MathPlayer
- MathTran
- Microsoft Access
- Microsoft Excel
- Microsoft Expression Web
- Microsoft FrontPage
- Microsoft Office
- Microsoft Outlook
- Microsoft PowerPoint
- Microsoft Publisher
- Microsoft Visio
- Microsoft Word
- Microsoft WordPad
- Microsoft Works (word processor)
- MIT Open Courseware
- Moodle
- Musings
N - NAG Documentation
- New York Journal of Mathematics
- Numbers
O - Office
- One Mathematical Cat
- Online Math Tests
- OpenOffice
- OpenOffice.org Writer
- Outlook
P - Pagemaker
- PagePlus
- Pages
- Physics Help and Math Help
- Physics Help Forum
- PlanetMath
- PolyEdit
- PowerPoint
- Pro/ENGINEER
- Publicon
- Publisher
Q R S - Saxon Test and Practice Generator
- Scientific Word
- Scientific Workplace
- ScribeStudio
- Serotek System Access
- Sitmo Equation Editor
- Sitmo Equations
- SMART Notebook
- SmartDraw
- sMArTH
- SoftMaker Office
- SoftMaker PlanMaker
- SoftMaker Presentations
- SoftMaker TextMaker
- SOS Mathematics Cyberboard
- Supernova
- System Access
T - techexplorer
- Terry Tao's Blog
- Texthelp Read&Write
- The Math Less Traveled
- The String Coffee Table
- The Unapologetic Mathematician
U V - Ventura
- Virtual Laboratories in Probability and Statistics
- Visio
- VoicePad
W - Walking Randomly
- WebCT
- Wikipedia
- Wikispaces
- Window-Eyes
- Windows Journal
- Windows Journal for Tablet PC
- WIRIS
- Wolfram Publicon
- Wondershare QuizCreator
- Word
- Word Pro
- WordPad
- WordPerfect
- Works
- WPS Office
X Y Z - Zoho
- Zoho Sheet
- Zoho Show
- Zoho wiki
- Zoho Writer
0 - 9Other
Jump to:
Assessment writers - Saxon Test and Practice Generator
CAD/CAM - AutoCAD
- AutoSketch
- Autodesk Inventor
- CATIA
- Pro/ENGINEER
Chemical structure drawing - ACD/ChemSketch
- ChemDraw
- ChemWindow
- ISIS/Draw
Classroom materials authoring Computer algebra systems Course content - MIT Open Courseware
DAISY readers Databases - FileMaker
- Microsoft Access
Desktop publishing - Adobe InDesign
- Adobe Pagemaker
- Corel Ventura
- PagePlus
- QuarkXPress
Diagramming - ConceptDraw
- Edraw Max
- Gliffy
- Microsoft Visio
- SmartDraw
Education blogs, forums, & wikis Email clients Encyclopedias Equation editors - DragMath
- Expressionism
- Firemath
- MathEdit
- WIRIS
- sMArTH
Graphing tools HTML editors - Adobe Dreamweaver
Learning management systems - Blackboard
- Learnwise
- Moodle
- ScribeStudio
- WebCT
Math blogs, forums, & wikis - 9math
- Math Help Forum
- MathBB
- Terry Tao's Blog
- Walking Randomly
Math journals - New York Journal of Mathematics
Math library/encyclopedia - Digital Library of Mathematical Functions
- EquationSheet
- NAG Documentation
- PlanetMath
- Sitmo Equations
Math practice tools MathML display engines - Equation Server for .NET
- GtkMathView
- MathML on Web
- MathPlayer
MathML editors Miscellaneous - ASCIIMathML.js
- ArcInfo
- BraMaNet
- Canvas
- Cl1p
- Crystal Reports
- FastReport Studio
- SMART Notebook
- VoicePad
Multimedia content creation Office suites - Apple iWork
- AppleWorks
- Kingsoft Office
- Microsoft Office
- OpenOffice
- SoftMaker Office
- WPS Office
- Zoho
Presentation creation - 280 Slides
- Apple Keynote
- HTML Slidy
- Zoho Show
Science blogs, forums, & wikis - Christina's LIS Rant
- Musings
Science journals - Chemistry Central Journal
Scientific publishing - Scientific Word
- Wolfram Publicon
Screen readers - BrowseAloud
- Hal
- JAWS
- MAGic with Speech
- Supernova
- Window-Eyes
Spreadsheets - Apple Numbers
- Microsoft Excel
- Zoho Sheet
TeX - EdiTeX
- GELLMU
- ItexToMML plugin
- LaTeXMathML
- MathTran
- jsMath
- jsTeXrender
Vector graphics editors Web browsers - Amaya
- Dadzilla
- Internet Explorer
Wiki hosts Word processors - Apple Pages
- Corel WordPerfect
- Google Docs
- Jarte
- Jarte Plus
- JungUm Global
- Kingsoft Writer
- Lotus Word Pro
- Microsoft Word
- Microsoft WordPad
- PolyEdit
- Zoho Writer
