- 2008-10-7
new
;建立网格模型
gen zone brick &
p0 0 0 0 p1 2 0 0 p2 0 0.5 0 p3 0 0 3 size 3 1 3
gen zone brick &
p0 2 0 0 p1 20 0 0 p2 2 0.5 0 p3 2 0 3 &
size 17 1 3 ratio 1.03 1 1
gen zone brick &
p0 2 0 3 p1 20 0 3 p2 2 0.5 3 p3 12 0 13 &
p4 20 0.5 3 p5 12 0.5 13 p6 20 0 13 &
p7 20 0.5 13 size 17 1 17 ratio 1.03 1 1
def SSR
;定义有关参数及循环终止条件
ait1=0.02
k11=1.0
k12=2.0
ks=(k11+k12)/2
loop while (k12-k11)>ait1
coh1=7.5e4/ks
fri1=atan(tan(18*pi/180)/ks)*180/pi
dila1=18.0
ten1=-5.5e5
K1=5.1e10
G1= 2.35e10
;折减实现过程
command
model null
config fluid
set fluid off
pl bl g
model elas
prop bulk 5.1e12 shear 2.35e12
model fl_iso
prop poros 0.5 perm 1.34e-11
ini fden 1000
ini fmod 2e9 ftens -1e-3
apply nstress -3e4 grad 0 0 10e3 range x -0.1 0.1 y 0 3
;设置边界条件
fix x y z range z -0.1 0.1
fix x range x 19.9 20.1
fix x range x -0.1 0.1
fix y
ini dens 2000
set gravity 0 0 -10.0
history unb
solve
save lizi2.sav
;位移和速度归零
ini xdisp 0
ini ydisp 0
ini zdisp 0
ini xvel 0
ini yvel 0
ini zvel 0
;...fluid flow model...
model fl_iso
prop poros 0.5
ini fden 1000
ini fmod 6.7e3 ftens -1e-3
water density 1000
table 1 name hanshuilv
table 2 name jizhixili
table 3 name shentouxishu
def ana_sol
n_max=20
aerfa=0.006
c_a=1/aerfa
c_n=1.45
c_m=1-1/c_n
sita_r=0.15
sita_s=0.5
perm_s=1e-11
pnt=gp_head
loop while pnt # null
sita0=0.15
sita=0.0
n=0
loop while n < n_max
n=n+1
sita=sita0+n*0.035
if sita < sita_s
command
apply discharge 2.23e-6 range x 2 20 y 0 0.5 z 3 13
endcommand
else
sita=sita_s
command
apply nstress -5e2 range x 2 20 y 0 0.5 z 3 13
endcommand
endif
sita1=sita-sita_r
sita2=sita_s-sita_r
h_xili=c_a*[(sita1/sita2)^(-1/c_m)-1]^(1-c_m)
a_h=aerfa*h_xili
an_h=a_h^(c_n-1)
a1_h=1+(a_h)^c_n
k_perm=perm_s*[1-an_h*a1_h^(-c_m)]^2/a1_h^(c_m/2)
command
prop perm k_perm
endcommand
table(1,n)=sita
table(2,n)=h_xili
table(3,n)=k_perm
endloop
pnt=gp_next(pnt)
endloop
end
m m
prop bulk K1 shear G1 coh coh1 fric fri1 tens ten1 dila dila1
;设置边界条件
fix y
;初始化材料密度
ini dens 2000
set fluid on
set mech ratio 9.8e-6
ana_sol
solve age 43200
save lizi2_12.sav
set fluid off
endcommand
;二分法实现过程
if mech_ratio<1.0e-5
k11=ks
k12=k12
else
k12=ks
k11=k11
endif
ks=(k11+k12)/2
endloop
;计算结果的保存
fosfile0='_fos12'+'.sav'
command
save fosfile0
endcommand
end
SSR
pr ks
[img]file:///D:/Program%20Files/Tencent/QQ/Users/282173282/Image/O6Q(C[`S8ZHX]QYVRJ9ICWQ.jpg[/img] 速度矢量往上走了,孔压也不对,怎么会这样,高手请指教 |
