查看: 340|回复: 0
[其他] 曲轴和连杆模板缩减遇到的问题
发表于 2011-9-1 18:51:08 | 显示全部楼层 |阅读模式 来自 山东青岛
我按照蓝博士您的nastran2005模板缩减连杆,曲轴,我用的是nastran2005r2,缩减完成后可以产生需要的out2等文件,但收f06文件有警告错误!传上来给蓝博士看看!我看不懂,也不知什么问题?困惑!
USER WARNING MESSAGE 6450 (OUTPT4)
     THE SELECTION OF THE  ASCII FORMAT OPTION IN THE OUTPUT4 MODULE FOR DATABLOCK KSAA     MAY RESULT IN NUMERIC TRUNCATION.
     USER INFORMATION:
      1. THE FORTRAN FORMAT BEING USED IS (1P,5E16.9)
      2. THE DEFAULT FORTRAN FORMAT IS (1P,5E16.9)
      3. THE FIFTH PARAMETER OF THE OUTPUT4 MODULE CAN BE USED TO INCREASE THE NUMBER OF SIGNIFICANT DIGITS.
     USER ACTION:
      1. IF THE NUMBER OF SIGNIFICANT DIGITS IS ACCEPTABLE, THEN NO ACTION IS REQUIRED.
      2. IF ADDITIONAL SIGNIFICANT DIGITS ARE REQUIRED, THEN INCREASE THE VALUE OF THE FIFTH PARAMETER, AND
         RERUN THE JOB.
DATA BLOCK KSAA    WRITTEN ON FORTRAN UNIT   33 FROM DMAP MODULE OUTPUT4 IN ASCII FORMAT (1P,5E16.9)
TRAILER =     101     750     750       6       2    1320    7746
** USER WARNING MESSAGE 6450 (OUTPT4)
     THE SELECTION OF THE  ASCII FORMAT OPTION IN THE OUTPUT4 MODULE FOR DATABLOCK MSAA     MAY RESULT IN NUMERIC TRUNCATION.
     USER INFORMATION:
     USER ACTION:
         RERUN THE JOB.
DATA BLOCK MSAA    WRITTEN ON FORTRAN UNIT   33 FROM DMAP MODULE OUTPUT4 IN ASCII FORMAT (1P,5E16.9)
TRAILER =     102     750     750       6       2    1500    9858
1    CONROD                                                               SEPTEMBER   1, 2008  MSC.NASTRAN  9/23/04   PAGE  1019
0
* * * *  D B D I C T   P R I N T  * * * *      SUBDMAP = PRTSUM  ,  DMAP STATEMENT NO.     30
0                                   * * * *  A N A L Y S I S  S U M M A R Y  T A B L E  * * * *
0 SEID  PEID PROJ VERS APRCH      SEMG SEMR SEKR SELG SELR MODES DYNRED SOLLIN PVALID SOLNL LOOPID DESIGN CYCLE SENSITIVITY
     0     0    1    1 '        '    T    T    T    T    T     T      T      T      0     F     -1            0           F
0SEID = SUPERELEMENT ID.
PEID = PRIMARY SUPERELEMENT ID OF IMAGE SUPERELEMENT.
PROJ = PROJECT ID NUMBER.
VERS = VERSION ID.
APRCH = BLANK FOR STRUCTURAL ANALYSIS.  HEAT FOR HEAT TRANSFER ANALYSIS.
SEMG = STIFFNESS AND MASS MATRIX GENERATION STEP.
SEMR = MASS MATRIX REDUCTION STEP (INCLUDES EIGENVALUE SOLUTION FOR MODES).
SEKR = STIFFNESS MATRIX REDUCTION STEP.
SELG = LOAD MATRIX GENERATION STEP.
SELR = LOAD MATRIX REDUCTION STEP.
MODES = T (TRUE) IF NORMAL MODES OR BUCKLING MODES CALCULATED.
DYNRED = T (TRUE) MEANS GENERALIZED DYNAMIC AND/OR COMPONENT MODE REDUCTION PERFORMED.
SOLLIN = T (TRUE) IF LINEAR SOLUTION EXISTS IN DATABASE.
PVALID = P-DISTRIBUTION ID OF P-VALUE FOR P-ELEMENTS
LOOPID = THE LAST LOOPID VALUE USED IN THE NONLINEAR ANALYSIS.  USEFUL FOR RESTARTS.
SOLNL = T (TRUE) IF NONLINEAR SOLUTION EXISTS IN DATABASE.
DESIGN CYCLE = THE LAST DESIGN CYCLE (ONLY VALID IN OPTIMIZATION).
SENSITIVITY = SENSITIVITY MATRIX GENERATION FLAG.
     THE SELECTION OF THE  ASCII FORMAT OPTION IN THE OUTPUT4 MODULE FOR DATABLOCK X2OA     MAY RESULT IN NUMERIC TRUNCATION.
     USER INFORMATION:
     USER ACTION:
         RERUN THE JOB.
DATA BLOCK X2OA    WRITTEN ON FORTRAN UNIT   45 FROM DMAP MODULE OUTPUT4 IN ASCII FORMAT (1P,5E16.9)
TRAILER =     101   19158     750       2       2    1500   10000
No PARAM values were set in the Control File.
1                                        * * * END OF JOB * * *
GMT+8, 2024-9-22 07:40 , Processed in 0.026570 second(s), 10 queries , Gzip On, MemCache On.
