- 1
- 2011-4-6
发表于 2011-10-10 11:02:55
来自 安徽合肥
Furthermore, even if all solids are mappable, they may not all be meshable at once--you may still need to mesh each mappable solid individually, or only a few at a time. Any given volume can have one of four states, which are color-coded when using the mappable view option on the visualization toolbar. Although the colors can be customized, the default settings are:
Blue indicates a solid that has not been edited at all and therefore isn't evaluated for mappability.
Orange indicates a solid that has been edited, but remains completely unmappable (further partitioning may enable mapping).
Yellow indicates a solid that is mappable in 1 direction.
Green indicates a solid that is mappable in three directions (this is very rare).
