对曲轴缩减提示如下的错误:
** USER FATAL MESSAGE 392 (XSORSO)
THE AUXMID OR SEID ON THE FOLLOWING BEGIN BULK COMMAND IS NOT GREATER THAN 0.
BULK ENTRY: BEGIN BULK
USER INFORMATION: THIS ERROR MAY OCCURE DUE TO BULK DATA ENTRIES BEING DEFINED BEFORE THE "BEGIN BULK" STATEMENT.
0 INPUT BULK DATA ENTRY COUNT = 31
0 TOTAL COUNT= 9
^^^ USER FATAL MESSAGE 9002 (IFPL)
^^^ ERROR(S) ENCOUNTERED IN THE MAIN BULK DATA SECTION
^^^ SEE MESSAGES ABOVE. ERROR ENCOUNTERED IN MODULE XSORT.
1 CMS REDUCTION SEPTEMBER 29, 2011 MD NASTRAN 5/22/08 PAGE 33
0
* * * * D B D I C T P R I N T * * * * SUBDMAP = PRTSUM , DMAP STATEMENT NO. 30
0 * * * * A N A L Y S I S S U M M A R Y T A B L E * * * *
0 SEID PEID PROJ VERS APRCH SEMG SEMR SEKR SELG SELR MODES DYNRED SOLLIN PVALID SOLNL LOOPID DESIGN CYCLE SENSITIVITY
0SEID = SUPERELEMENT ID.
PEID = PRIMARY SUPERELEMENT ID OF IMAGE SUPERELEMENT.
PROJ = PROJECT ID NUMBER.
VERS = VERSION ID.
APRCH = BLANK FOR STRUCTURAL ANALYSIS. HEAT FOR HEAT TRANSFER ANALYSIS.
SEMG = STIFFNESS AND MASS MATRIX GENERATION STEP.
SEMR = MASS MATRIX REDUCTION STEP (INCLUDES EIGENVALUE SOLUTION FOR MODES).
SEKR = STIFFNESS MATRIX REDUCTION STEP.
SELG = LOAD MATRIX GENERATION STEP.
SELR = LOAD MATRIX REDUCTION STEP.
MODES = T (TRUE) IF NORMAL MODES OR BUCKLING MODES CALCULATED.
DYNRED = T (TRUE) MEANS GENERALIZED DYNAMIC AND/OR COMPONENT MODE REDUCTION PERFORMED.
SOLLIN = T (TRUE) IF LINEAR SOLUTION EXISTS IN DATABASE.
PVALID = P-DISTRIBUTION ID OF P-VALUE FOR P-ELEMENTS
LOOPID = THE LAST LOOPID VALUE USED IN THE NONLINEAR ANALYSIS. USEFUL FOR RESTARTS.
SOLNL = T (TRUE) IF NONLINEAR SOLUTION EXISTS IN DATABASE.
DESIGN CYCLE = THE LAST DESIGN CYCLE (ONLY VALID IN OPTIMIZATION).
SENSITIVITY = SENSITIVITY MATRIX GENERATION FLAG.
No PARAM values were set in the Control File.
1 * * * END OF JOB * * *
No Symbolic Replacement variables or values were specified.
我看以前的帖子,蓝老师有说:“ERROR(S) ENCOUNTERED IN THE MAIN BULK DATA SECTION 指明了你的bdf有错。”但我怎么检查我bdf那块有错?
哪位指导一下:这种错误是什么原因???求指导,急,非常感谢!!
