- 2011-9-19
楼主 |
发表于 2011-10-7 20:58:13
来自 重庆
请问上面兄弟一些问题
new
;建模型
def x_rad
xrad=sqrt(6.19*6.19-2.19*2.19)
end
x_rad
gen zon cylinder p0 0 0 0 p1 xrad 0 -2.19 p2 add 0 50 0 p3 0 0 6.19 p4 xrad 50 -2.19 p5 0 50 6.19 size 7 50 8 rat 1 1 1
plot block group
plot add axes red
gen zon wedge p0 0 0 -2.19 p1 xrad 0 -2.19 p2 add 0 50 0 p3 0 0 0 p4 xrad 50 -2.19 p5 0 50 0 p6 0 0 0 p7 0 50 0 &
size 7 50 7 rat 1 1 1
gen zon reflect dip 90 dd 90 ori 0 0 0
group nsoil
gen zon radcyl p0 0 0 0 p1 35.19 0 -13.311021248234213556702313453022 p2 0 50 0 p3 0 0 21.69 p4 35.19 50 &
-13.311021248234213556702313453022 p5 0 50 21.69 &
p6 35.19 0 21.69 p7 35.19 50 21.69 &
p8 xrad 0 -2.19 p9 0 0 6.19 p10 xrad 50 -2.19 p11 0 50 6.19 dim 6.19 6.19 6.19 6.19 &
size 5 50 8 10 rat 1 1 1 1.2
gen zon brick p0 0 0 21.69 p1 35.19 0 21.69 p2 add 0 50 0 p3 0 0 41.69 size 4 50 3 rat 1 1 1
gen zon brick p0 35.19 0 21.69 p1 add 20 0 0 p2 add 0 50 0 p3 add 0 0 20 size 3 50 3 rat 1 1 1
gen zon brick p0 35.19 0 -13.311021248234213556702313453022 p1 add 20 0 0 p2 add 0 50 0 &
p3 35.19 0 21.69 size 3 50 4 rat 1 1 1
gen zon brick p0 0 0 -2.19 p1 0 0 -13.311021248234213556702313453022 p2 add 0 50 0 p3 add xrad 0 0 p4 0 50 -13.311021248234213556702313453022 &
p5 add xrad 50 0 p6 35.19 0 -13.311021248234213556702313453022 p7 35.19 50 -13.311021248234213556702313453022 &
size 10 50 7 rat 1.2 1 1
group wsoil range group nsoil not ;更改群组名
gen zon reflect dip 90 dd 90 ori 0 0 0 range group wsoil
pause
model mohr ;魔尔—库仑模型
pro bulk 50e6 she 18e6 fric 20 coh 25e3 ten 9e5 dil 30
ini szz -1210000 grad 0 0 22000
ini syy -605000 grad 0 0 11000
ini sxx -605000 grad 0 0 11000
fix x range x 55.18 55.20
fix x range x -55.20 -55.18
fix y range y -0.1 0.1
fix y range y 49.9 50.1
fix z range z -13.4 -13.2
set grav 0 0 -10
ini density 2200
;定义超前锚秆
def fen_jiao_chao
jiao=float(120/32) ;角度
end
fen_jiao_chao
def cab_parm_chao
array x_b(1,33),z_b(1,33),x_2b(1,33),z_2b(1,33) ;数组
yd_mao=0
x_b(1,1)=6.19*cos(30*degrad)
z_b(1,1)=6.19*sin(30*degrad)
x_b(1,2)=6.19*cos((30+jiao*1)*degrad)
z_b(1,2)=6.19*sin((30+jiao*1)*degrad)
x_b(1,3)=6.19*cos((30+jiao*2)*degrad)
z_b(1,3)=6.19*sin((30+jiao*2)*degrad)
x_b(1,4)=6.19*cos((30+jiao*3)*degrad)
z_b(1,4)=6.19*sin((30+jiao*3)*degrad)
x_b(1,5)=6.19*cos((30+jiao*4)*degrad)
z_b(1,5)=6.19*sin((30+jiao*4)*degrad)
x_b(1,6)=6.19*cos((30+jiao*5)*degrad)
z_b(1,6)=6.19*sin((30+jiao*5)*degrad)
x_b(1,7)=6.19*cos((30+jiao*6)*degrad)
z_b(1,7)=6.19*sin((30+jiao*6)*degrad)
x_b(1,8)=6.19*cos((30+jiao*7)*degrad)
z_b(1,8)=6.19*sin((30+jiao*7)*degrad)
x_b(1,9)=6.19*cos((30+jiao*8)*degrad)
z_b(1,9)=6.19*sin((30+jiao*8)*degrad)
x_b(1,10)=6.19*cos((30+jiao*9)*degrad)
z_b(1,10)=6.19*sin((30+jiao*9)*degrad)
x_b(1,11)=6.19*cos((30+jiao*10)*degrad)
z_b(1,11)=6.19*sin((30+jiao*10)*degrad)
x_b(1,12)=6.19*cos((30+jiao*11)*degrad)
z_b(1,12)=6.19*sin((30+jiao*11)*degrad)
x_b(1,13)=6.19*cos((30+jiao*12)*degrad)
z_b(1,13)=6.19*sin((30+jiao*12)*degrad)
x_b(1,14)=6.19*cos((30+jiao*13)*degrad)
z_b(1,14)=6.19*sin((30+jiao*13)*degrad)
x_b(1,15)=6.19*cos((30+jiao*14)*degrad)
z_b(1,15)=6.19*sin((30+jiao*14)*degrad)
x_b(1,16)=6.19*cos((30+jiao*15)*degrad)
z_b(1,16)=6.19*sin((30+jiao*15)*degrad)
x_b(1,17)=6.19*cos((30+jiao*16)*degrad)
z_b(1,17)=6.19*sin((30+jiao*16)*degrad)
x_b(1,18)=6.19*cos((30+jiao*17)*degrad)
z_b(1,18)=6.19*sin((30+jiao*17)*degrad)
x_b(1,19)=6.19*cos((30+jiao*18)*degrad)
z_b(1,19)=6.19*sin((30+jiao*18)*degrad)
x_b(1,20)=6.19*cos((30+jiao*19)*degrad)
z_b(1,20)=6.19*sin((30+jiao*19)*degrad)
x_b(1,21)=6.19*cos((30+jiao*20)*degrad)
z_b(1,21)=6.19*sin((30+jiao*20)*degrad)
x_b(1,22)=6.19*cos((30+jiao*21)*degrad)
z_b(1,22)=6.19*sin((30+jiao*21)*degrad)
x_b(1,23)=6.19*cos((30+jiao*22)*degrad)
z_b(1,23)=6.19*sin((30+jiao*22)*degrad)
x_b(1,24)=6.19*cos((30+jiao*23)*degrad)
z_b(1,24)=6.19*sin((30+jiao*23)*degrad)
x_b(1,25)=6.19*cos((30+jiao*24)*degrad)
z_b(1,25)=6.19*sin((30+jiao*24)*degrad)
x_b(1,26)=6.19*cos((30+jiao*25)*degrad)
z_b(1,26)=6.19*sin((30+jiao*25)*degrad)
x_b(1,27)=6.19*cos((30+jiao*26)*degrad)
z_b(1,27)=6.19*sin((30+jiao*26)*degrad)
x_b(1,28)=6.19*cos((30+jiao*27)*degrad)
z_b(1,28)=6.19*sin((30+jiao*27)*degrad)
x_b(1,29)=6.19*cos((30+jiao*28)*degrad)
z_b(1,29)=6.19*sin((30+jiao*28)*degrad)
x_b(1,30)=6.19*cos((30+jiao*29)*degrad)
z_b(1,30)=6.19*sin((30+jiao*29)*degrad)
x_b(1,31)=6.19*cos((30+jiao*30)*degrad)
z_b(1,31)=6.19*sin((30+jiao*30)*degrad)
x_b(1,32)=6.19*cos((30+jiao*31)*degrad)
z_b(1,32)=6.19*sin((30+jiao*31)*degrad)
x_b(1,33)=6.19*cos((30+jiao*32)*degrad)
z_b(1,33)=6.19*sin((30+jiao*32)*degrad)
x_2b(1,1)=(6.19+3.5*sin(14*degrad))*cos(30*degrad)
z_2b(1,1)=(6.19+3.5*sin(14*degrad))*sin(30*degrad)
x_2b(1,2)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*1)*degrad)
z_2b(1,2)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*1)*degrad)
x_2b(1,3)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*2)*degrad)
z_2b(1,3)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*2)*degrad)
x_2b(1,4)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*3)*degrad)
z_2b(1,4)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*3)*degrad)
x_2b(1,5)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*4)*degrad)
z_2b(1,5)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*4)*degrad)
x_2b(1,6)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*5)*degrad)
z_2b(1,6)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*5)*degrad)
x_2b(1,7)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*6)*degrad)
z_2b(1,7)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*6)*degrad)
x_2b(1,8)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*7)*degrad)
z_2b(1,8)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*7)*degrad)
x_2b(1,9)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*8)*degrad)
z_2b(1,9)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*8)*degrad)
x_2b(1,10)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*9)*degrad)
z_2b(1,10)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*9)*degrad)
x_2b(1,11)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*10)*degrad)
z_2b(1,11)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*10)*degrad)
x_2b(1,12)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*11)*degrad)
z_2b(1,12)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*11)*degrad)
x_2b(1,13)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*12)*degrad)
z_2b(1,13)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*12)*degrad)
x_2b(1,14)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*13)*degrad)
z_2b(1,14)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*13)*degrad)
x_2b(1,15)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*14)*degrad)
z_2b(1,15)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*14)*degrad)
x_2b(1,16)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*15)*degrad)
z_2b(1,16)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*15)*degrad)
x_2b(1,17)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*16)*degrad)
z_2b(1,17)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*16)*degrad)
x_2b(1,18)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*17)*degrad)
z_2b(1,18)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*17)*degrad)
x_2b(1,19)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*18)*degrad)
z_2b(1,19)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*18)*degrad)
x_2b(1,20)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*19)*degrad)
z_2b(1,20)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*19)*degrad)
x_2b(1,21)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*20)*degrad)
z_2b(1,21)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*20)*degrad)
x_2b(1,22)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*21)*degrad)
z_2b(1,22)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*21)*degrad)
x_2b(1,23)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*22)*degrad)
z_2b(1,23)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*22)*degrad)
x_2b(1,24)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*23)*degrad)
z_2b(1,24)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*23)*degrad)
x_2b(1,25)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*24)*degrad)
z_2b(1,25)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*24)*degrad)
x_2b(1,26)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*25)*degrad)
z_2b(1,26)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*25)*degrad)
x_2b(1,27)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*26)*degrad)
z_2b(1,27)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*26)*degrad)
x_2b(1,28)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*27)*degrad)
z_2b(1,28)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*27)*degrad)
x_2b(1,29)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*28)*degrad)
z_2b(1,29)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*28)*degrad)
x_2b(1,30)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*29)*degrad)
z_2b(1,30)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*29)*degrad)
x_2b(1,31)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*30)*degrad)
z_2b(1,31)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*30)*degrad)
x_2b(1,32)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*31)*degrad)
z_2b(1,32)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*31)*degrad)
x_2b(1,33)=(6.19+3.5*sin(14*degrad))*cos((30+jiao*32)*degrad)
z_2b(1,33)=(6.19+3.5*sin(14*degrad))*sin((30+jiao*32)*degrad)
end
锚杆支护中array x_b(1,33),z_b(1,33),x_2b(1,33),z_2b(1,33) 4个数组各表示啥? x_b(1,2)=6.19*cos((30+jiao*1)*degrad)
中6.19是半径,那个30从哪来的啊? x_2b(1,1)=(6.19+3.5*sin(14*degrad))*cos(30*degrad)中的3.5估计是锚杆的长度,那个14又是从哪冒出来的呀?请各位大哥指点一下拉,上面的命令流相信很多人看到
