- 2011-4-28
程序出现错误为 s_b函数运行时,出现了数组下标为非整形数的错误,程序的功能为导入tecplot后出现一个新的后处理项,即损伤值。。。。。损伤定义即在s_b函数中。可是一运行到函数,就出错。程序代:
;; by dynamax@simwe
;; 9/14/2004
;; Modifications:
;; (1) change data packing mode from point to block
;; (2) add zone-related info to be plotted
;; 9/11/2004
;; Modifications:
;; (1) add range tec_range to set plot range
;; (2) add function plot_test to hide null zones
;; 7/11/2004
;; Flac3d Mesh to Tecplot
;; Limits:
;; (1)Zone Type ---- TETRAHEDRON or BRICK
;; (2)Tecplot Version ---- Version 10
;; (3)Only DISPLACEMENTS of Grid Points are outputted
;; Initialization
def ini_mesh2tec
IO_READ = 0
IO_WRITE = 1
IO_FISH = 0
IO_ASCII = 1
N_RECORD = 5
ZONE_NGP = z_numgp(zone_head)
array buf(1)
tec_file = 'tec10.dat'
;; Edit the tec_range to set plot range
command
ran name tec_range
endcommand
end
ini_mesh2tec
;; If plotit = 1, plot the zone
def plot_test
plotit = 1
if z_model(p_z) = 'NULL' then
plotit = 0
endif
if inrange('tec_range',p_z) = 0 then
plotit = 0
endif
end
;; Get number of zones to plot
def get_nzone
n_zone = 0
p_z = zone_head
loop while p_z # null
plot_test
if plotit = 1 then
n_zone = n_zone + 1
endif
p_z = z_next(p_z)
endloop
end
get_nzone
;; Write Tecplot File Head
def write_head
buf(1) = 'TITLE = "FLAC3D to Tecplot 10"\n'
buf(1) = buf(1) + 'VARIABLES = "X(m)" \n"Y(m)" \n"Z(m)" \n'
buf(1) = buf(1) + '"DISP(m)" \n"XDISP(m)" \n"YDISP(m)" \n"ZDISP(m)" \n'
buf(1) = buf(1) + '"SIG1(Pa)" \n"SIG2(Pa)" \n"SIG3(Pa)" \n'
buf(1) = buf(1) + '"SXX(Pa)" \n"SYY(Pa)" \n"SZZ(Pa)" \n"sunshang(pa)"\n'
buf(1) = buf(1) + 'ZONE T="GLOBAL" \n'
buf(1) = buf(1) + ' N=' + string(ngp) + ','
buf(1) = buf(1) + ' E=' + string(n_zone) + ','
if ZONE_NGP = 4 then
buf(1) = buf(1) + ' ZONETYPE=FETETRAHEDRON \n'
else
buf(1) = buf(1) + ' ZONETYPE=FEBrick \n'
endif
buf(1) = buf(1) + ' DATAPACKING=BLOCK \n'
buf(1) = buf(1) + ' VARLOCATION=([8-14]=CELLCENTERED) \n'
buf(1) = buf(1) + ' DT=(SINGLE SINGLE SINGLE'
buf(1) = buf(1) + ' SINGLE SINGLE SINGLE SINGLE'
buf(1) = buf(1) + ' SINGLE SINGLE SINGLE'
buf(1) = buf(1) + ' SINGLE SINGLE SINGLE SINGLE)'
status = write(buf,1)
end
;; Calculate displacement magnitude
def get_gp_disp
gp_disp = gp_xdisp(p_gp)*gp_xdisp(p_gp)
gp_disp = gp_disp + gp_ydisp(p_gp)*gp_ydisp(p_gp)
gp_disp = gp_disp + gp_zdisp(p_gp)*gp_zdisp(p_gp)
gp_disp = sqrt(gp_disp)
end
;; Write gp-related data,such as Coordinates and Displacements
def write_gp_info
p_gp = gp_head
loop while p_gp # null
buf(1) = ''
loop i(1,N_RECORD)
if p_gp # null then
caseof info_flag
case 0
buf(1) = buf(1) + string(gp_xpos(p_gp)) + ' '
case 1
buf(1) = buf(1) + string(gp_ypos(p_gp)) + ' '
case 2
buf(1) = buf(1) + string(gp_zpos(p_gp)) + ' '
case 4
get_gp_disp
buf(1) = buf(1) + string(gp_disp) + ' '
case 8
buf(1) = buf(1) + string(gp_xdisp(p_gp)) + ' '
case 16
buf(1) = buf(1) + string(gp_ydisp(p_gp)) + ' '
case 32
buf(1) = buf(1) + string(gp_zdisp(p_gp)) + ' '
endcase
p_gp = gp_next(p_gp)
endif
endloop
endloop
end
;; Write zone-related data,such as Stresses
def write_zone_info
p_z = zone_head
buf(1) = ''
loop i(1,N_RECORD)
if p_z # null then
plot_test
if plotit = 1 then
caseof info_flag
case 0
buf(1) = buf(1) + string(z_sig1(p_z)) + ' '
case 1
buf(1) = buf(1) + string(z_sig2(p_z)) + ' '
case 2
buf(1) = buf(1) + string(z_sig3(p_z)) + ' '
case 4
buf(1) = buf(1) + string(z_sxx(p_z)) + ' '
case 8
buf(1) = buf(1) + string(z_syy(p_z)) + ' '
case 16
buf(1) = buf(1) + string(z_szz(p_z)) + ' '
endcase
endif
p_z = z_next(p_z)
endif
endloop
endloop
end
;定义损伤变量
def s_b
p_z = zone_head
array z_DDDD(n_zone)
ef=0.1 !峰值应变
eu=0.2 !极限应变
ee=18*z_prop(p_z,'bu')*z_prop(p_z,'shear')/(2*z_prop(p_z,'shear')+6*z_prop(p_z,'bu')) ;弹性模量
uu=(3*z_prop(p_z,'bu')-2*z_prop(p_z,'shear'))/(2*z_prop(p_z,'shear')+6*z_prop(p_z,'bu')) ;泊松比
; ee=z_prop(p_z,'young')
; uu=z_prop(p_z,'poisson')
;确定et,ec
array eee(3)
eee(1)=(1/ee)*(z_sig1(p_z)-uu*(z_sig2(p_z)+z_sig3(p_z))) ;第1主营变
eee(2)=(1/ee)*(z_sig2(p_z)-uu*(z_sig1(p_z)+z_sig3(p_z))) ;第2主营变
eee(3)=(1/ee)*(z_sig3(p_z)-uu*(z_sig1(p_z)+z_sig2(p_z))) ;第3主营变
ezong=sqrt(eee(1)*eee(1)+eee(2)*eee(2)+eee(3)*eee(3)) ;总应变
et2=0
ec2=0
loop i (1,3)
if eee(i)>0 then
et2=et2+eee(i)*eee(i)
else
ec2=ec2+eee(i)*eee(i)
end_if
end_loop
et=sqrt(et2)
ec=sqrt(ec2)
;确定Dt和Dc
if ezong=0 then
z_DDDD(p_z)=0
endif
if ezong # 0 then
if et>ef then
Dt=(eu*(et-ef))/(ezong*(eu-ef))
else
Dt=0
endif
if ec>ef then
Dc=(eu*(ec-ef))/(ezong*(eu-ef))
else
Dc=0
endif
at=(et/ezong)^2
ac=(ec/ezong)^2
z_DDDD(p_z)=at*Dt+ac*Dc
endif
p_z = z_next(p_z)
endloop
end
s_b
;; Write 损伤变量
def write_zone_info1
p_z = zone_head
buf(1) = ''
loop i(1,N_RECORD)
if p_z # null then
plot_test
if plotit = 1 then
buf(1) = buf(1) + string(z_DDDD(p_z)) + ' '
endif
p_z = z_next(p_z)
endif
endloop
endloop
end
;; Write Zone Connectivity
def write_zone
p_z = zone_head
buf(1) = ' '
buf(1) = buf(1) + string(gp_id(z_gp(p_z, 1))) + ' '
buf(1) = buf(1) + string(gp_id(z_gp(p_z, 2))) + ' '
buf(1) = buf(1) + string(gp_id(z_gp(p_z, 3))) + ' '
buf(1) = buf(1) + string(gp_id(z_gp(p_z, 4))) + ' '
else
buf(1) = buf(1) + string(gp_id(z_gp(p_z, 5))) + ' '
buf(1) = buf(1) + string(gp_id(z_gp(p_z, 7))) + ' '
buf(1) = buf(1) + string(gp_id(z_gp(p_z, 8))) + ' '
buf(1) = buf(1) + string(gp_id(z_gp(p_z, 6))) + ' '
endif
plot_test
if plotit = 1 then
endif
p_z = z_next(p_z)
endloop
end
;; Main Function
def mesh2tec
status = close
status = open(tec_file,IO_WRITE,IO_ASCII)
if status = 0 then
write_head
info_flag = 0
write_gp_info
info_flag = 1
write_gp_info
info_flag = 2
write_gp_info
info_flag = 4
write_gp_info
info_flag = 8
write_gp_info
info_flag = 16
write_gp_info
info_flag = 32
write_gp_info
info_flag = 0
write_zone_info
info_flag = 1
write_zone_info
info_flag = 2
write_zone_info
info_flag = 4
write_zone_info
info_flag = 8
write_zone_info
info_flag = 16
write_zone_info
;sunshang_bianliang
;write_zone_info1
write_zone
status = close
ii = out('Successfully Write ' + string(n_zone) + ' Zone Data Into File ' + tec_file)
else
ii=out('Open File Error! Status = ' + string(status))
endif
end
mesh2tec
