查看: 42|回复: 0
关于TUNIF 命令的一些区别有什么影响啊
发表于 2011-10-13 09:34:17 | 显示全部楼层 |阅读模式 来自 江苏南京
请问各位11和12中的TUNIF 命令的区别有什么影响啊,12中多了句If using the command default to set the uniform temperature (to the reference temperature set via TREF), you can convert temperature-dependent secant coefficients of thermal expansion (SCTEs) from the definition temperature to the uniform temperature. To do so, issue the MPAMOD command.
拜托了~~
有大虾知道的不~~
GMT+8, 2024-9-20 02:30 , Processed in 0.024881 second(s), 9 queries , Gzip On, MemCache On.
