- 2010-6-16
楼主 |
发表于 2011-10-30 14:04:24
来自 江苏南京
** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
**** END OF REPORT ****
For Useful OptiStruct Tips and Tricks, go to the URL:
http://www.altairhyperworks.com/tips.aspx
RADIOSS/OptiStruct error termination report:
RAM: 95 MB total, 95 MB used.
Data arrays: 417 total, 206 allocated.
DATA SET size 46 MB, ram_disk 2 MB
DATASET USAGE: ndirs: 1, nfiles 1, nsets: 10, nblocks: 10, mode: 8
DIR: 0, size 45.4[MB], path "D:/10.30/" num_files 1
PROGRAM STOPPED DUE TO ERROR.
A fatal error has occurred during computations:
** ERROR # 312 **
In static load case 1
the compliance is negative or large 4.383816E+11
Optimization/buckling analysis cannot be performed
due to possible rigid body mode
OPTIMIZATION HAS CONVERGED.
FEASIBLE DESIGN.
