查看: 208|回复: 8
[命令/FISH] 找个FISH高手帮我看下程序(FLAC-TECPLOT)
发表于 2011-11-12 09:08:24 | 显示全部楼层 |阅读模式 来自 山东青岛
开始是在论坛上下的文件。。。。转换的元素有位移、主应力、正应力等  但是我现在需要画一个第二主应力减去第三主应力的量的等值线图。。。我把程序做了一部分改动  但是我的程序总出错  我水平有限  看不出来哪里错了  找人帮解答  最好给我个能达到要求的改后程序,,,,如果你要能给我解释解释就更感谢了
程序如下:
;; by dynamax@simwe
;; 9/14/2004
;; Modifications:
;;     (1) change data packing mode from point to block
;;     (2) add zone-related info to be plotted
;; 9/11/2004
;; Modifications:
;;     (1) add range tec_range to set plot range
;;     (2) add function plot_test to hide null zones
;; 7/11/2004
;; Flac3d Mesh to Tecplot
;; Limits:
;;     (1)Zone Type ---- TETRAHEDRON or BRICK
;;     (2)Tecplot Version ---- Version 10
;;     (3)Only DISPLACEMENTS of Grid Points are outputted
;; Initialization
def ini_mesh2tec
IO_READ  = 0
    IO_WRITE = 1
IO_FISH  = 0
IO_ASCII = 1
N_RECORD = 10
    ZONE_NGP = z_numgp(zone_head)
array buf(1)
    tec_file = 'tec10.dat'
;; Edit the tec_range to set plot range
    command
        ran name tec_range
    endcommand
end
ini_mesh2tec
;; If plotit = 1, plot the zone
def plot_test
    plotit = 1
    if z_model(p_z) = 'NULL' then
        plotit = 0
    endif
    if inrange('tec_range',p_z) = 0 then
        plotit = 0
    endif
end
;; Get number of zones to plot
def get_nzone
    n_zone = 0
    p_z = zone_head
    loop while p_z # null
        plot_test
        if plotit = 1 then
            n_zone = n_zone + 1
        endif
        p_z = z_next(p_z)
    endloop
end
get_nzone
;; Write Tecplot File Head
def write_head
    buf(1) = 'TITLE     = "FLAC3D to Tecplot 10"\n'
    buf(1) = buf(1) + 'VARIABLES = "X(m)" \n"Y(m)" \n"Z(m)" \n'
    buf(1) = buf(1) + '"DISP(m)" \n"XDISP(m)" \n"YDISP(m)" \n"ZDISP(m)" \n'
    buf(1) = buf(1) + '"SIG1(MPa)" \n"SIG2(MPa)" \n"SIG3(MPa)" \n'
    buf(1) = buf(1) + '"SXX(MPa)" \n"SYY(MPa)" \n"SZZ(MPa)" \n'
    buf(1) = buf(1) + '"SQ(MPa)"\n'
    buf(1) = buf(1) + 'ZONE T="GLOBAL" \n'
    buf(1) = buf(1) + ' N=' + string(ngp) + ','
    buf(1) = buf(1) + ' E=' + string(n_zone) + ','
    if ZONE_NGP = 4 then
     buf(1) = buf(1) + ' ZONETYPE=FETETRAHEDRON \n'
    else
     buf(1) = buf(1) + ' ZONETYPE=FEBrick \n'
    endif
    buf(1) = buf(1) + ' DATAPACKING=BLOCK \n'
    buf(1) = buf(1) + ' VARLOCATION=([8-13]=CELLCENTERED) \n'
    buf(1) = buf(1) + ' DT=(SINGLE SINGLE SINGLE'
    buf(1) = buf(1) + ' SINGLE SINGLE SINGLE SINGLE'
    buf(1) = buf(1) + ' SINGLE SINGLE SINGLE'
    buf(1) = buf(1) + ' SINGLE)'
    status = write(buf,1)
end
;; Calculate displacement magnitude
def get_gp_disp
    gp_disp = gp_xdisp(p_gp)*gp_xdisp(p_gp)
    gp_disp = gp_disp + gp_ydisp(p_gp)*gp_ydisp(p_gp)
gp_disp = gp_disp + gp_zdisp(p_gp)*gp_zdisp(p_gp)
gp_disp = sqrt(gp_disp)
end
;; Write gp-related data,such as Coordinates and Displacements
def write_gp_info
    p_gp = gp_head
    loop while p_gp # null
        buf(1) = ''
        loop i(1,N_RECORD)
         if p_gp # null then
             caseof  info_flag
                 case 0
                        buf(1) = buf(1) + string(gp_xpos(p_gp)) + '  '
                 case 1
                        buf(1) = buf(1) + string(gp_ypos(p_gp)) + '  '
                 case 2
                        buf(1) = buf(1) + string(gp_zpos(p_gp)) + '  '
                 case 4
                     get_gp_disp
                        buf(1) = buf(1) + string(gp_disp) + '  '
                 case 8
                        buf(1) = buf(1) + string(gp_xdisp(p_gp)) + '  '
                 case 16
                        buf(1) = buf(1) + string(gp_ydisp(p_gp)) + '  '
                 case 32
                        buf(1) = buf(1) + string(gp_zdisp(p_gp)) + '  '
             endcase
          p_gp = gp_next(p_gp)
         endif
        endloop
    endloop
end
def get_z_sq
    z_sq = z_sig2(p_z) - z_sig3(p_z)
end
;; Write zone-related data,such as Stresses
def write_zone_info
p_z = zone_head
        buf(1) = ''
        loop i(1,N_RECORD)
         if p_z # null then
                plot_test
                if plotit = 1 then
                 caseof  info_flag
                     case 0
                            buf(1) = buf(1) + string(z_sig1(p_z) / (-1000000.0)) + '  '
                        case 1
                            buf(1) = buf(1) + string(z_sig2(p_z) / (-1000000.0)) + '  '
                     case 2
                            buf(1) = buf(1) + string(z_sig3(p_z) / (-1000000.0)) + '  '
                     case 4
                            buf(1) = buf(1) + string(z_sxx(p_z) / (-1000000.0)) + '  '
                     case 8
                            buf(1) = buf(1) + string(z_syy(p_z) / (-1000000.0)) + '  '
                     case 16
                            buf(1) = buf(1) + string(z_szz(p_z) / (-1000000.0)) + '  '
                        case 32
                              get_z_sq
                            buf(1) = buf(1) + string(z_sq(p_z) / (-1000000.0)) + '  '
                 endcase
                endif
          p_z = z_next(p_z)
         endif
        endloop
endloop
end
;; Write Zone Connectivity
def write_zone
    p_z = zone_head
        buf(1) = '  '
            buf(1) = buf(1) + string(gp_id(z_gp(p_z, 1))) + '  '
            buf(1) = buf(1) + string(gp_id(z_gp(p_z, 2))) + '  '
            buf(1) = buf(1) + string(gp_id(z_gp(p_z, 3))) + '  '
            buf(1) = buf(1) + string(gp_id(z_gp(p_z, 4))) + '  '
        else
            buf(1) = buf(1) + string(gp_id(z_gp(p_z, 5))) + '  '
            buf(1) = buf(1) + string(gp_id(z_gp(p_z, 7))) + '  '
            buf(1) = buf(1) + string(gp_id(z_gp(p_z, 8))) + '  '
            buf(1) = buf(1) + string(gp_id(z_gp(p_z, 6))) + '  '
        endif
        plot_test
        if plotit = 1 then
        endif
        p_z = z_next(p_z)
    endloop
end
;; Main Function
def mesh2tec
    status = close
status = open(tec_file,IO_WRITE,IO_ASCII)
if status = 0 then
     write_head
     info_flag = 0
     write_gp_info
     info_flag = 1
     write_gp_info
     info_flag = 2
     write_gp_info
     info_flag = 4
     write_gp_info
     info_flag = 8
     write_gp_info
     info_flag = 16
     write_gp_info
     info_flag = 32
     write_gp_info
     info_flag = 0
     write_zone_info
     info_flag = 1
     write_zone_info
     info_flag = 2
     write_zone_info
     info_flag = 4
     write_zone_info
     info_flag = 8
     write_zone_info
     info_flag = 16
     write_zone_info
     info_flag = 32
     write_zone_info
     write_zone
  status = close
  ii = out('Successfully Write ' + string(n_zone) + ' Zone Data Into File ' + tec_file)
else
  ii=out('Open File Error! Status = ' + string(status))
endif
end
mesh2tec
在FLAC3D里面读入程序  出现如下错误
发表于 2011-11-12 19:25:12 | 显示全部楼层 来自 伊朗
thanks dear sir
发表于 2011-11-13 22:07:57 | 显示全部楼层 来自 北京
看不懂 帮你顶顶吧 = =。。。高手似乎都不逛论坛。。
发表于 2011-12-27 13:17:05 | 显示全部楼层 来自 湖南长沙
好东西,争取看懂先
发表于 2012-3-26 01:59:44 | 显示全部楼层 来自 陕西
好东西,争取看懂先
发表于 2013-3-29 20:15:51 | 显示全部楼层 来自 四川成都
看不懂,刚开始学。
发表于 2013-3-31 08:35:47 | 显示全部楼层 来自 黑龙江哈尔滨
楼主水平很高哦 学习
发表于 2013-4-14 19:07:25 | 显示全部楼层 来自 山东青岛
爱莫能助,我也想学好fish啊
发表于 2013-4-17 16:19:57 | 显示全部楼层 来自 北京
楼主可以重点查下有没有一些变量是字符型的,结果赋值时没加单引号,程序太长,不仔细看了
GMT+8, 2024-9-24 06:20 , Processed in 0.037746 second(s), 10 queries , Gzip On, MemCache On.
