查看: 141|回复: 2
[建模专区] solve time n是什么意思?
发表于 2011-11-14 11:39:27 | 显示全部楼层 |阅读模式 来自 江苏南京
看手册出solve命令后面出现solve time 14这个是什么意思?之前只见过solve average 0.001 maximum 0.001。手册看了也没看明白。
timet
For the mechanical calculation process, t is the mechanical time limit (i.e., the sum of all mechanical timesteps). For the thermal calculation process, t is the thermal time limit (i.e., the sum of all thermal timesteps). For the coupled thermal-mechanical calculation process, t is the thermal time limit. By default, there is no time limit. Note that the unit for time, t, will depend on the input properties.
发表于 2011-11-14 18:40:31 | 显示全部楼层 来自 江苏南京
solve time t    就是设置计算时间t
solve ave 0.001   就是设置平均不平衡力和平均接触力之比小于0.001时计算停止
solve max 0.001   就是设置最大不平衡力和最大接触力之比小于0.001时计算停止
发表于 2012-1-11 17:21:53 | 显示全部楼层 来自 江苏徐州
学习了。。。
GMT+8, 2024-9-29 15:31 , Processed in 0.028104 second(s), 12 queries , Gzip On, MemCache On.
