- 2011-5-24
** OptiStruct 10.0 **
** Design and Optimization Software **
** from Altair Engineering, Inc. **
** Windows XP Professional SP3 (Build 2600) ZHANGXUETAO-PC **
** 2 CPU: Intel(R) Pentium(R) Dual CPU E2180 @ 2.00GHz **
** CPU speed 2000 MHz **
** 1385 MB RAM, 3933 MB swap **
** Build tag: 0466938_5333O00_Ci3242M-000 4000 **
** COPYRIGHT (C) 1996-2009 Altair Engineering, Inc. **
** All Rights Reserved. Copyright notice does not imply publication. **
** Contains trade secrets of Altair Engineering, Inc. **
** Decompilation or disassembly of this software strictly prohibited. **
** OptiStruct defaults set from:
install config file: d:\Altair\hw10.0/hwsolvers/hwsolver.cfg
** WARNING # 1051
CONM2 data has zero or negative mass.
Detected while reading line 10335 from file F:/11-17/11-11-1.fem:
"CONM2 36921 37045 00.0 0.0 0.0 0.0"
** WARNING # 1051
Detected while reading line 10336 from file F:/11-17/11-11-1.fem:
"CONM2 36922 37046 00.0 0.0 0.0 0.0"
** WARNING # 1051
Detected while reading line 10337 from file F:/11-17/11-11-1.fem:
"CONM2 36923 37047 00.0 0.0 0.0 0.0"
** WARNING # 1051
Detected while reading line 10338 from file F:/11-17/11-11-1.fem:
"CONM2 36924 37048 00.0 0.0 0.0 0.0"
** WARNING # 1051
Detected while reading line 10339 from file F:/11-17/11-11-1.fem:
"CONM2 36925 37049 00.0 0.0 0.0 0.0"
** WARNING # 1051
Detected while reading line 10340 from file F:/11-17/11-11-1.fem:
"CONM2 36926 37050 00.0 0.0 0.0 0.0"
** WARNING 1932: PMASS 8 is not referenced.
** ERROR # 1501 **
for material id = 1 referenced from property id = 2.
Either E or G must be explicitly provided for MAT1. Otherwise singular
material is produced.
NOTE # 1599
1 stability-related material property errors found. To bypass checking
these errors use PARAM,CHECKMAT,NO. This may, however, cause zero or negative
pivots and excessive compliance.
OPTIMIZATION FILE AND PARAMETER INFORMATION :
Optimization parameters from : F:/11-17/11-11-1.fem
FEM model file : F:/11-17/11-11-1.fem
Output files prefix : F:/11-17/11-11-1
FINITE ELEMENT MODEL DATA INFORMATION :
Total # of Grids (Structural) : 10236
Total # of Elements : 10333
Total # of Rigid Elements : 6
Element Type Information
CONM2 Elements : 6
CQUAD4 Elements : 10171
CTRIA3 Elements : 156
Load and Boundary Information
FORCE Sets : 1
SPC Sets : 1
Material and Property Information
PMASS Cards : 1
PSHELL Cards : 6
MAT1 Cards : 1
*** ERROR ENCOUNTERED BEFORE COMPLETING THE CHECK RUN ***
Current Memory (RAM) : 32 MB
Estimated Minimum Memory (RAM) for the check run : 21 MB
RESOURCE USAGE INFORMATION
MAXIMUM MEMORY USED 32 MB
MAXIMUM DISK SPACE USED 0 MB
COMPUTE TIME INFORMATION
EXECUTION STARTED Thu Nov 17 14:13:46 2011
EXECUTION COMPLETED Thu Nov 17 14:13:47 2011
ELAPSED TIME 00:00:00
CPU TIME 00:00:00
** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
*** END OF REPORT ***
For Useful OptiStruct Tips and Tricks, go to the URL:
http://www.altairhyperworks.com/tips.aspx
A fatal error has been detected during input processing:
** ERROR # 1501 **
