- 2011-9-30
楼主 |
发表于 2012-2-14 09:04:37
来自 江西南昌
yfjlm 发表于 2012-1-15 17:01 ![](static/image/common/back.gif)
你的proeexec.bat的驱动命令能给我吗?
!trail file version No. 1450
!Pro/ENGINEER TM 5.0 (c) 1988-2002 by Wisdom Systems All Rights Reserved.
< 0 0.860444 885 0 0 726 1024 0 0 768 13
!mem_use INCREASE Blocks 209867, AppSize 27177363, SysSize 35184392
< 0 0.680000 680 0 0 622 1024 0 0 768 13
< 0 0.612000 612 0 0 622 1024 0 0 768 13
!%CI欢迎使用 Creo Elements/Pro 5.0。
< 0 0.614000 614 0 0 622 1024 0 0 768 13
< 0 0.627000 627 0 0 622 1024 0 0 768 13
< 0 0.627000 627 0 0 594 1024 0 0 768 13
< 0 0.713481 767 0 0 602 1024 0 0 768 13
~ Resize `main_dlg_cur` `main_dlg_cur` \
4 -0.146023 -0.146023 37.382008 26.247718
~ Move `main_dlg_cur` `main_dlg_cur` \
2 -0.146023 -0.146023
~ Command `ProCmdModelOpen`
< 2 0.118519 178 0 0 100 1024 0 0 768 13
~ Trail `UI Desktop` `UI Desktop` \
`DLG_PREVIEW_POST` \
`file_open`
`PREVIEW_POPUP_TIMER` \
`file_open h_list.Filelist:<NULL>`
~ Activate `file_open` `Current Dir`
~ Select `file_open` `SAB_c:`
~ Close `file_open` `SAB_c:`
~ Select `file_open` `Location Browser`
~ Close `file_open` `Location Browser`
~ Activate `file_open` `SAB_c:`
~ Select `file_open` `SAB_pfafs:drives`
~ Close `file_open` `SAB_pfafs:drives`
~ Activate `file_open` `M_h:`
~ Select `file_open` `Ph_list.Filelist` \
1 `ProE_Ansys_iSIGHT_Brace_Opt`
~ Activate `file_open` `Ph_list.Filelist` \
~ Activate `file_open` `file_open`
1 `brace_asm.asm`
~ Activate `file_open` `Open`
!Command ProCmdModelOpenExe was pushed from the software.
!30-Nov-11 22:10:05 Start H:\ProE_Ansys_iSIGHT_Brace_Opt\brace_asm.asm.66
!30-Nov-11 22:10:05 Start H:\ProE_Ansys_iSIGHT_Brace_Opt\brace.prt.54
!30-Nov-11 22:10:05 End H:\ProE_Ansys_iSIGHT_Brace_Opt\brace.prt.54
!30-Nov-11 22:10:05 End H:\ProE_Ansys_iSIGHT_Brace_Opt\brace_asm.asm.66
< 0 0.713481 739 0 0 602 1024 0 0 768 13
~ Timer `UI Desktop` `UI Desktop` \
`EmbedBrowserTimer`
~ Activate `main_dlg_cur` `main_dlg_cur`
#FEATURE
#FEATURE
#DONE/RETURN
#COMPONENT
#COMPONENT
#DONE/RETURN
#RELATIONS
!%CPSelect a feature to display parameters, or select from Relation menu.
#RELATIONS
#EDIT REL
!results of editing REL.ptd
@ edit
^d1:0=2.000000
^d2:0=5.000000
^d3:0=0.000100
^d4:0=-0.249900
^d6:0=-0.249900
^d7:0=-0.250000
^d21:0=-0.250000
^d23:0=2.000000
^d24:0=0.750000
^d26:0=-0.150000
^d28:0=0.000100
^d30:0=-0.812500
^d31:0=-0.849900
!@ endedit
!#DONE SEL
#DONE
#REGENERATE
!%CPSelect parts to regenerate.
#REGENERATE
#AUTOMATIC
!%CIAutomatic regeneration of the parts has been completed.
~ Activate `main_dlg_cur` `ProCmdModelSave.file`
!%CPEnter object to save [BRACE_ASM1.ASM]
!%TR
BRACE_ASM1.ASM
!%CIBRACE_ASM has been saved.
