- 2011-12-7
自己最近需要将一个fortran程序转译成matlab的
找了好久,终于找到一个比较有用的资料了
兴奋之余,拿出来与大家分享,希望大家有类似有用的资料拿出来一起分享下。
MATLAB FORTRAN F77
PROGRAMMING ENVIRIONMENT
Path for functions & M-files: Path for libraries
set in DOS set in DOS
set matlabpath=??? set lib=???
set in matlabrc.m for Windows
matlabpath['???']
set in matlab program
path('c:\', path)
other path commands
path, pwd, cd
Preferred usage:
2 windows (editor, command) 2 windows (editor, DOS for compile-link-run)
Intepreter Compiler
Speed: Slow as a turtle Fast as a rabbit
See speed.m See speed.exe
GENERAL SYNTAX
% comments c comments
Columns: all Columns 7-72 for statements
Case Sensitive Case insensitive
Ignore blank spaces and lines. Ignore blank spaces and lines.
Everything is a matrix. Scalar (default=real/integer)
the whole vector/matrix: x, A x, A
an element: x(1), A(1,1) x(1), A(1,1)
dimension: <=2 (in v4.0) dimension may be > 2 (e.g., A(1,2,3))
Array size is dynamically adjusted. Array size must be declared/fixed
(F90 allows adjustable array size.)
No type declaration REAL, INTEGER, CHARACTER, LOGICAL ...
(more efficient with preallocation)
e.g., A = zeros(2,3) e.g., REAL A(2,3)
Matrix stored in column-wise order Matrix stored in column-wise order
A = [ 1 2 3; 4 5 6]; data A/1, 4, 2, 5, 3, 6/
fprintf('%i\n',A) ... column-wise order print *, A ... column-wise order
Complex number: x = 1 + 2*i COMPLEX x; x = CMPLX(1., 2.)
Logical variable (none) LOGICAL declaration
1 for true; 0 for false .true. .false.
Algebraic operators: + - * / ^ + - * / **
Element-wise operator: "."
Transpose: ' (user provided)
Logical operators:
< <= > >= == ~= .lt. .le. .gt. .ge. .eq. .ne.
& | ~ .and. .or. .not.
MATLAB and FORTRAN share the same algebraic function names
sin, cos, tan, asin, acos, atan, exp, abs, etc.
exception:
sqrt: negative augument is ok sqrt: positive argument only
(-27)^0.3333 gives 1.5+2.6i (not -3) domain error
log alog (i.e., natural logarithm)
log10 alog10 (i.e., common logarithm)
rem mod
Other conversion functions
int8, int16, int32 int
num2str, int2str
uint8('A') ichar('A')
Continuation: ... column 6
Multiple statements separated by:
"," or ";" none
I/O
x print *, 'x = ', x
x+y print *, 'ans = ', x+y
y=x+1; (assignment) y=x+1
disp(' ') print *, ' ' or write(*,*)
disp('text string') print *, 'text string'
disp(x) print *, x
disp(['x = ', num2str(x)]) print *, 'x = ', x
x=input('enter x ') print *, 'enter x' ; read *, x
resp=input('Y/N ', 's') print *, 'Y/N:' ; read '(a)', resp
(i.e., input a string; need to declare "CHARACTER resp" in FORTRAN)
sprintf('format string', x); write(*,'(format string)') x
where format: %e, %f, %g, %s
%15.3e, %15.7f, %15.7g, e15.3, f15.7, g15.7,
%8s, %7i a8, i7
\n (new line) /
fprintf('filename', 'format', [x, y]) open (1, file='filename') ... one shot
write(1,'(format)') x, y
load x.dat or load x.ext read an ascii file into a variable x
save file variable_list /ascii save the specified variables in a file
fid=fopen('filename', 'r' ) open(fid, 'filename', status='old')
fid=fopen('filename', 'w' ) open(fid, 'filename', status='new')
where standard input fid=0 standard input fid=5
standard output fid=1 standard output fid=6
x = fscanf(0, 'format', size) read (5, '(format)') x
fprintf(1, 'format', x, y, z) write(6, '(format)') x, y, z
fprintf('format', x, y, z) write(*, '(format)') x, y, z
fclose(1) close(1)
GRAPH
plot No standard graphing functions,
axis([xmin,xmax,ymin,ymax]) but most compilers provide a system-
title('title') dependent set of graphing functions.
xlabel('xlabel'), ylabel('ylabel')
text
legend
subplot
In title, xlabel, etc., TeX commands are recognized: eg: _ ^ \alpha
LOOP
DO-Loop
for i=1:n do i=1, n
(return/keyboard/pause/break) (return/stop/goto/exit)
end enddo
One line format:
for i=1:n statement; statement; end
for i=n:-1:1 ... decrement i do i=n, 1, -1 ... decrement i
end enddo
WHILE
while condition do while (condition)
end enddo
CONDITION
IF
if condition if (condition) then
elseif condition elseif (condition) then
else else
end endif
SELECT-CASE (MATLAB v5)
switch expression select case (resp)
case 0 case ('y')
statements1 statements1
case 1 case ('a', 'b')
statements2 statements2
case 2 case ('c':'f', 'h':'j')
statements3 statements3
otherwise case default
statements4 statements4
end end select
JUMP
none goto label
MAIN/SUB PROGRAMS and STRUCTURE
Script file
% comments program main
(1st blank line) c comments
% further comments statements
statements :
error('text string') stop 'text string'
end
(may have several script files) (can have only one main program)
Subroutine without Returned Variables
function dummy_name(arguments) subroutine name(arguments)
(1st blank line) statements
% further comments :
statements :
(return) (return)
Calling convention:
foo(arguments)
Similar to a plain script end
Scalar function
function y = dummy_name(arguments) function y(arguments)
statements :
y = .... y = ...
(Assignment is made to y.) (Assignment is made to function name)
(y may be a matrix.) end
Multiple-output function
function [y1, y2] = dummy_name(arguments)
% comments
(1st blank line)
% further comments
statements Return multiple choices with FUNCTION F(..., choice)
y1 = .... Return multiple variables with SUBROUTINE
y2 = ....
(All return variables must be on LHS
grouped in "[?,?]" .)
The LHS is NOT a matrix; thus, the
dimensions of y1 and y2 need not match.
Calling convension (/w or /wo comma):
[y1 y2]=foo(...)
[y1,y2]=foo(...)
Alternative way to pass variables
global x y z common x, y, z
common /cblock/ x, y, z
(Caution: v3 forced globalization within the entire MATLAB! Choose names wisely.)
v4 extends globalization within only the functions in which
global is declared.)
Function arguments should not appear in "global" or "common" list.
Funciton with no argument
y = dummy_name () function name()
Calling convension: y=foo Calling convension: y=name()
(Note: no parentheses!)
Each function stored in a separate Multiple subroutines in one file.
M-file. (No restriction.)
A copy of the argument is passed Address of the argument is passed.
to a function. Passing by value. Passing by address/pointer.
(Nothing is returned via arguments!) (Subroutine/function can return variables
See pass.m in the argument list)
passfcn.m
(资料摘自网站)http://terpconnect.umd.edu/~nsw/ench250/for-mat.htm
希望给位多多补充 fortran 转译到matlab的相关有用资料,谢谢先! |
