** WARNING ** CP = 18.891 TIME= 10:22:07
The thermal transient analysis has no mass.
** WARNING ** CP = 19.109 TIME= 10:22:08
There are 1 small equation solver pivot terms. This may be a
transitional effect caused by the Newton-Raphson logic.
** WARNING ** CP = 19.562 TIME= 10:22:08
** WARNING ** CP = 20.266 TIME= 10:22:09
** WARNING ** SUPPRESSED MESSAGE CP = 20.500 TIME= 10:22:09
** WARNING ** SUPPRESSED MESSAGE CP = 20.688 TIME= 10:22:09
Material property KXX of material 1 of element 2412 is evaluated at a
temperature of 0, which is below the supplied temperature range.
Temperature range checking terminates.
** WARNING ** SUPPRESSED MESSAGE CP = 20.859 TIME= 10:22:10
** WARNING ** SUPPRESSED MESSAGE CP = 21.109 TIME= 10:22:10
** WARNING ** SUPPRESSED MESSAGE CP = 21.438 TIME= 10:22:10
** WARNING ** SUPPRESSED MESSAGE CP = 21.672 TIME= 10:22:10
** WARNING ** SUPPRESSED MESSAGE CP = 21.906 TIME= 10:22:11
** WARNING ** SUPPRESSED MESSAGE CP = 22.219 TIME= 10:22:11
** WARNING ** SUPPRESSED MESSAGE CP = 22.625 TIME= 10:22:11
** WARNING ** SUPPRESSED MESSAGE CP = 22.875 TIME= 10:22:12
** WARNING ** SUPPRESSED MESSAGE CP = 23.422 TIME= 10:22:12
** WARNING ** SUPPRESSED MESSAGE CP = 23.672 TIME= 10:22:12
** WARNING ** SUPPRESSED MESSAGE CP = 24.328 TIME= 10:22:13
** WARNING ** SUPPRESSED MESSAGE CP = 24.562 TIME= 10:22:13
** WARNING ** SUPPRESSED MESSAGE CP = 25.344 TIME= 10:22:14
** WARNING ** SUPPRESSED MESSAGE CP = 25.625 TIME= 10:22:14
** WARNING ** SUPPRESSED MESSAGE CP = 26.000 TIME= 10:22:14
** WARNING ** SUPPRESSED MESSAGE CP = 26.266 TIME= 10:22:15
** WARNING ** SUPPRESSED MESSAGE CP = 26.781 TIME= 10:22:15
** WARNING ** SUPPRESSED MESSAGE CP = 27.594 TIME= 10:22:16
** WARNING ** SUPPRESSED MESSAGE CP = 27.844 TIME= 10:22:16
** WARNING ** SUPPRESSED MESSAGE CP = 28.141 TIME= 10:22:17
** WARNING ** SUPPRESSED MESSAGE CP = 28.359 TIME= 10:22:17
** WARNING ** SUPPRESSED MESSAGE CP = 28.828 TIME= 10:22:17
** WARNING ** SUPPRESSED MESSAGE CP = 29.266 TIME= 10:22:18
** WARNING ** SUPPRESSED MESSAGE CP = 29.547 TIME= 10:22:18
** WARNING ** SUPPRESSED MESSAGE CP = 30.125 TIME= 10:22:19
** WARNING ** SUPPRESSED MESSAGE CP = 30.891 TIME= 10:22:19
** WARNING ** SUPPRESSED MESSAGE CP = 31.156 TIME= 10:22:20
** WARNING ** SUPPRESSED MESSAGE CP = 32.156 TIME= 10:22:21
** WARNING ** SUPPRESSED MESSAGE CP = 32.422 TIME= 10:22:21
** WARNING ** SUPPRESSED MESSAGE CP = 32.656 TIME= 10:22:21
** WARNING ** SUPPRESSED MESSAGE CP = 32.906 TIME= 10:22:21
** WARNING ** SUPPRESSED MESSAGE CP = 33.188 TIME= 10:22:22
** WARNING ** SUPPRESSED MESSAGE CP = 33.969 TIME= 10:22:22
** WARNING ** SUPPRESSED MESSAGE CP = 34.250 TIME= 10:22:23
** WARNING ** SUPPRESSED MESSAGE CP = 34.781 TIME= 10:22:23
** WARNING ** SUPPRESSED MESSAGE CP = 35.078 TIME= 10:22:23
** ERROR ** SUPPRESSED MESSAGE CP = 35.797 TIME= 10:22:24
Solution not converged at time 1.E-04 (load step 1 substep 1).
Run terminated.
** WARNING ** SUPPRESSED MESSAGE CP = 35.797 TIME= 10:22:24
The unconverged solution (identified as time 0.22 substep 999999) is
output for analysis debug purposes. Results should not be used for
any other purpose.
