- 1
- 2011-11-11
楼主 |
发表于 2011-12-25 14:40:23
来自 重庆
ywh362568 发表于 2011-12-25 11:08
除此之外还有其他信息吗?
计算终止了?
从内存看,要求不算高,9位数都没到
朋友,k文件太大,无法上传,你看一下求解信息吧,谢谢!
Date: 12/25/2011 Time: 13:31:30
___________________________________________________
| Livermore Software Technology Corporation |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Version : ls971s R5.1.1 Date: 03/23/2011 |
| Revision: 65543 Time: 12:57:02 |
| Features enabled in this version: |
| Shared Memory Parallel |
| ANSYS Database format |
| Licensed to: |
| Platform : WIN32 |
| OS Level : Windows XP/Vista/7 SRV 2003/2008 |
| Compiler : Intel Fortran 10.1 & MSVC++ 2008 |
| Hostname : zhuliuxian-PC |
| Precision : Single precision (I4R4) |
| SVN Version: 65550 |
| Unauthorized use infringes LSTC copyrights |
Input file: c:\users\zhuliu~1\desktop\xuange~3.k
The native file format : 32-bit small endian
Memory size from command line: 200000000
expanding memory to 200000000 starting ls-dyna
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Finite Element code. *
* the validity, accuracy, or applicability of any results *
* obtained from this system. The user must verify his own *
* results. *
* LSTC endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LSTC through your site focus. *
* Copyright (C) 1990-2011 *
* by Livermore Software Technology Corp. (LSTC) *
* All rights reserved *
Beginning of keyword reader 12/25/11 13:31:31
contracting memory to 1 beginning of keyword reader
expanding memory to 22080
expanding memory to 1977722
expanding memory to 2051990
expanding memory to 2081990
expanding memory to 2141990
expanding memory to 2169300
expanding memory to 2190308
expanding memory to 2211430
expanding memory to 2540838
expanding memory to 3838470
expanding memory to 3859972
expanding memory to 3879972
expanding memory to 3899972
expanding memory to 3921172
expanding memory to 3942266
expanding memory to 3963866
expanding memory to 3985466
expanding memory to 4007066
expanding memory to 4028666
expanding memory to 4050266
expanding memory to 4071866
expanding memory to 4093466
expanding memory to 4115066
expanding memory to 4136666
expanding memory to 4158266
expanding memory to 4179866
expanding memory to 4201466
expanding memory to 4223066
expanding memory to 4244666
expanding memory to 4266266
expanding memory to 4287866
expanding memory to 4309466
expanding memory to 4331066
expanding memory to 4352666
expanding memory to 4374266
expanding memory to 4395866
expanding memory to 4417466
expanding memory to 4439066
expanding memory to 4460666
expanding memory to 4482266
expanding memory to 4503866
expanding memory to 4525466
expanding memory to 4547066
expanding memory to 4568666
expanding memory to 4590266
expanding memory to 4611866
expanding memory to 4633466
expanding memory to 4655066
expanding memory to 4676666
expanding memory to 4698266
expanding memory to 4719866
expanding memory to 4741466
expanding memory to 4763066
expanding memory to 4784666
expanding memory to 4806266
expanding memory to 4827866
expanding memory to 4849466
expanding memory to 4871066
expanding memory to 4892666
expanding memory to 4914266
expanding memory to 4935866
expanding memory to 4957466
expanding memory to 4979066
expanding memory to 5000666
expanding memory to 5022266
expanding memory to 5043866
expanding memory to 5065466
expanding memory to 5087066
expanding memory to 5108666
expanding memory to 5130266
expanding memory to 5151866
expanding memory to 5173466
expanding memory to 5195066
expanding memory to 5216666
expanding memory to 5238266
expanding memory to 5259866
expanding memory to 5281466
expanding memory to 5303066
expanding memory to 5324666
expanding memory to 5346266
expanding memory to 5367866
expanding memory to 5389466
expanding memory to 5411066
expanding memory to 5432666
expanding memory to 5454266
expanding memory to 5475866
expanding memory to 5497466
expanding memory to 5519066
expanding memory to 5540666
expanding memory to 5562266
expanding memory to 5583866
expanding memory to 5605466
expanding memory to 5627066
expanding memory to 5648666
expanding memory to 5670266
expanding memory to 5691866
expanding memory to 5713466
expanding memory to 5735066
expanding memory to 5756666
expanding memory to 5778266
expanding memory to 5799866
expanding memory to 5821466
expanding memory to 5843066
expanding memory to 5864666
expanding memory to 6188642
expanding memory to 6512618
expanding memory to 10076344
expanding memory to 10400320
expanding memory to 10429588
expanding memory to 10753564
Memory required to process keyword : 10753564
contracting memory to 1 end of keyword reader
LS-DYNA will perform a structural only analysis
rotation
ls-dyna ls971s.65543 R5.1.1 date 03/23/2011
expanding memory to 2611 material, node and element data
expanding memory to 2689 material properties
expanding memory to 344560 element data for composite material
expanding memory to 992526 gradient of damage data
expanding memory to 1016994 user control for contact interfaces
contracting memory to 1016974 for boundary cond. vectorization
expanding memory to 1018600 arbitrary element numbering input
contracting memory to 1016974 thick shell int. pt. strain
expanding memory to 1017001 rcforc moments
expanding memory to 1033429 process element material data
expanding memory to 1035435 load curve data
contracting memory to 1033883 user_define_loading_set
expanding memory to 1034087 regularize time history data
contracting memory to 1033883 rigidwall definitions
expanding memory to 1357896 velocity b.c
expanding memory to 1681974 nodal constraint sets
expanding memory to 1693729 contact interfaces
expanding memory to 2342679 implicit contact 1
expanding memory to 2349185 implicit contact 2
expanding memory to 6875488 contact segment data 1
expanding memory to 7200491 contact segment data 2
expanding memory to 9144297 contact segment data 3
expanding memory to 21116849 contact definition
expanding memory to 22412980 rigid body
expanding memory to 26631867 contact friction
expanding memory to 29547258 joints
expanding memory to 75793498 SPH elements
expanding memory to 76116898 discrete element
contracting memory to 76116898 accelerometers
expanding memory to 76116998 rigid bodies for disp. termination
contracting memory to 76116998 transformation to move nodes
expanding memory to 76764948 interfac for file
contracting memory to 76440975 thermal expansion 0
expanding memory to 76440977 flexible body 2
contracting memory to 76440977 implicit joints
expanding memory to 76440978 minimum contact gap for auto switching
expanding memory to 76447482 initialization phase
slave surface of interface = 1
type = 16
surface timestep = 1.366E-03
controlling slave node ID = 576
part ID of slave node = 1626
current minimum time step = 1.366E-03
master surface of interface = 1
type = 16
surface timestep = 1.480E-08
controlling master node ID = 304
part ID of master node = 1
current minimum time step = 1.480E-08
The LS-DYNA time step size should not exceed 1.480E-08
to avoid contact instabilities. If the step size is
bigger then scale the penalty of the offending surface.
S t o r a g e a l l o c a t i o n
Memory required to begin solution : 76764948
Additional dynamically allocated memory: 9071445
Total: 85836393
1 t 0.0000E+00 dt 1.33E-08 flush i/o buffers 12/25/11 13:32:16
1 t 0.0000E+00 dt 1.33E-08 write d3plot file 12/25/11 13:32:16
