- 2011-12-28
由于附件比较大,麻烦做过相关的兄弟六个邮箱 ,帮忙看看看k文件,不胜感激!!
Date: 12/30/2011 Time: 15:56:20
___________________________________________________
| Livermore Software Technology Corporation |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Version : ls971s R4.2 Date: 02/04/2009 |
| Revision: 50638 Time: 07:58:32 |
| Features enabled in this version: |
| Shared Memory Parallel |
| ANSYS Database format |
| Licensed to: |
| Platform : PC WIN32 |
| OS Level : Windows 2K/XP/VISTA |
| Compiler : Intel Fortran Compiler 10.1 |
| Hostname : John |
| Precision : Single precision (I4R4) |
| Product ID : 50777 |
| Unauthorized use infringes LSTC copyrights |
Input file: c:\docume~1\admini~1\桌面\12301.k
The native file format : 32-bit small endian
Memory size from command line: 300000000
expanding memory to 300000000 starting ls-dyna
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Finite Element code. *
* the validity, accuracy, or applicability of any results *
* obtained from this system. The user must verify his own *
* results. *
* LSTC endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LSTC through your site focus. *
* Copyright (C) 1990-2009 *
* by Livermore Software Technology Corp. (LSTC) *
* All rights reserved *
contracting memory to 1 beginning of keyword reader
expanding memory to 21002
expanding memory to 296664
expanding memory to 4865964
expanding memory to 4895964
expanding memory to 4955964
expanding memory to 5974522
expanding memory to 6983922
expanding memory to 7041418
expanding memory to 7086271
expanding memory to 9141924
expanding memory to 9186777
expanding memory to 13711077
expanding memory to 13755930
CHECKING MATERIAL INPUT Part ID= 1
*** Warning The default hourglass properties of the following
ALE part are being modified to avoid unnecessary
application of hourglass forces.
Resetting coefficient qm=1.0e-6.
PART ID 1 with
MATERIAL ID 1 and
EOS ID 1
This is PART 1 in the order of input.
CHECKING MATERIAL INPUT Part ID= 2
PART ID 2 with
MATERIAL ID 2 and
EOS ID 2
This is PART 2 in the order of input.
Memory required to process keyword : 13755930
contracting memory to 1 end of keyword reader
LS-DYNA will perform a structural only analysis
File: hang
ls-dyna ls971s.50638 R4.2 date 02/04/2009
expanding memory to 2625 material, node and element data
expanding memory to 2704 material properties
expanding memory to 2812419 element data
expanding memory to 2902783 gradient of damage data
expanding memory to 6673133 user control for contact interfaces
expanding memory to 6673137 for boundary cond. vectorization
contracting memory to 6673113 nodal data
expanding memory to 6924463 arbitrary element numbering input
contracting memory to 6677413 spc cards
expanding memory to 12994819 process element material data
expanding memory to 12996820 load curve data
contracting memory to 12995021 regularize time history data
contracting memory to 12995021 rigidwall definitions
expanding memory to 13055595 nodal constraint sets
expanding memory to 15064053 contact interfaces
expanding memory to 17415909 mass scaling with ale
expanding memory to 17550468 ALE neighboring info
expanding memory to 33896926 ALE multimaterial storage
expanding memory to 33897926 contact segment data 1
expanding memory to 36043285 contact segment data 3
contracting memory to 36042286 contact definition
expanding memory to 36177178 rigid body
contracting memory to 36043040 contact friction
expanding memory to 36043085 joints
*** Error part # 4 is out-of-range
0.000E+00 0 2.771E+03 7.991E+03 3.600E+03 4
input phase will continue if possible
*** Error part # 5 is out-of-range
0.000E+00 0 3.308E+03 7.451E+03 3.600E+03 5
contracting memory to 36043085 shell solid interfaces
contracting memory to 36043085 accelerometers
expanding memory to 36057638 non-reflecting silent boundary 1
expanding memory to 36057738 rigid bodies for disp. termination
contracting memory to 36057738 transformation to move nodes
expanding memory to 36264231 ale reference system
expanding memory to 36264365 ALE fsi control block
expanding memory to 36264368 ALE fsi node and seg list
expanding memory to 36286538 ALE fsi seg connectivity
expanding memory to 37322217 ALE fsi coupling forces
expanding memory to 37501689 void materials
expanding memory to 37501692 thermal expansion 0
expanding memory to 37501695 flexible body 2
contracting memory to 37501695 implicit joints
input phase completed with 2 fatal errors
please check messag file
E r r o r t e r m i n a t i o n
s t o r a g e a l l o c a t i o n
Memory required to complete solution : 37501695
Additional dynamically allocated memory: 3132540
Total: 40634235
T i m i n g i n f o r m a t i o n
CPU(seconds) %CPU Clock(seconds) %Clock
Initialization ....... 0.0000E+00 0.00 0.0000E+00 0.00
Element processing ... 0.0000E+00 0.00 0.0000E+00 0.00
Binary databases ..... 0.0000E+00 0.00 0.0000E+00 0.00
ASCII database ....... 0.0000E+00 0.00 0.0000E+00 0.00
Contact algorithm .... 0.0000E+00 0.00 0.0000E+00 0.00
ALE CoupleID 1 0.0000E+00 0.00 0.0000E+00 0.00
Contact entities ..... 0.0000E+00 0.00 0.0000E+00 0.00
Rigid bodies ......... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Nonlinear ... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Lin. Alg. ... 0.0000E+00 0.00 0.0000E+00 0.00
T o t a l s 0.0000E+00 0.00 0.0000E+00 0.00
Problem time = 0.0000E+00
Problem cycle = 0
Total CPU time = 0 seconds ( 0 hours 0 minutes 0 seconds)
CPU time per zone cycle = 0 nanoseconds
Clock time per zone cycle= 0 nanoseconds
Number of CPU's 2
NLQ used/max 96/ 96
Start time 12/30/2011 15:56:20
End time 12/30/2011 15:56:26
Elapsed time 6 seconds( 0 hours 0 min. 6 sec.) for 0 cycles
