- 2011-10-20
Please make sure that the mesh density of the slave surface in the tie pair (assembly__pickedsurf310,assembly__pickedsurf309) is finer than the master surface. The analysis may run slower, may yield inaccurate results, and may require more memory if this is not the case.
For *tie pair (assembly__pickedsurf310-assembly__pickedsurf309), adjustment was specified but no node was adjusted more than the adjustment distance = 2.22000e-16.
Please make sure that the mesh density of the slave surface in the tie pair (assembly__pickedsurf364,assembly__pickedsurf363) is finer than the master surface. The analysis may run slower, may yield inaccurate results, and may require more memory if this is not the case.
For *tie pair (assembly__pickedsurf364-assembly__pickedsurf363), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
Please make sure that the mesh density of the slave surface in the tie pair (assembly__pickedsurf384,assembly__pickedsurf383) is finer than the master surface. The analysis may run slower, may yield inaccurate results, and may require more memory if this is not the case.
For *tie pair (assembly__pickedsurf384-assembly__pickedsurf383), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly__pickedsurf386-assembly__pickedsurf385), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
Please make sure that the mesh density of the slave surface in the tie pair (assembly__pickedsurf367,assembly__pickedsurf368) is finer than the master surface. The analysis may run slower, may yield inaccurate results, and may require more memory if this is not the case.
For *tie pair (assembly__pickedsurf367-assembly__pickedsurf368), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
Please make sure that the mesh density of the slave surface in the tie pair (assembly__pickedsurf370,assembly__pickedsurf369) is finer than the master surface. The analysis may run slower, may yield inaccurate results, and may require more memory if this is not the case.
For *tie pair (assembly__pickedsurf370-assembly__pickedsurf369), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
Please make sure that the mesh density of the slave surface in the tie pair (assembly__pickedsurf371,assembly__pickedsurf372) is finer than the master surface. The analysis may run slower, may yield inaccurate results, and may require more memory if this is not the case.
For *tie pair (assembly__pickedsurf371-assembly__pickedsurf372), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
Please make sure that the mesh density of the slave surface in the tie pair (assembly__pickedsurf366,assembly__pickedsurf365) is finer than the master surface. The analysis may run slower, may yield inaccurate results, and may require more memory if this is not the case.
For *tie pair (assembly__pickedsurf366-assembly__pickedsurf365), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
Please make sure that the mesh density of the slave surface in the tie pair (assembly__pickedsurf382,assembly__pickedsurf381) is finer than the master surface. The analysis may run slower, may yield inaccurate results, and may require more memory if this is not the case.
For *tie pair (assembly__pickedsurf382-assembly__pickedsurf381), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
Please make sure that the mesh density of the slave surface in the tie pair (assembly__pickedsurf374,assembly__pickedsurf373) is finer than the master surface. The analysis may run slower, may yield inaccurate results, and may require more memory if this is not the case.
For *tie pair (assembly__pickedsurf374-assembly__pickedsurf373), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
Please make sure that the mesh density of the slave surface in the tie pair (assembly__pickedsurf375,assembly__pickedsurf376) is finer than the master surface. The analysis may run slower, may yield inaccurate results, and may require more memory if this is not the case.
For *tie pair (assembly__pickedsurf375-assembly__pickedsurf376), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly__pickedsurf378-assembly__pickedsurf377), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
Please make sure that the mesh density of the slave surface in the tie pair (assembly__pickedsurf380,assembly__pickedsurf379) is finer than the master surface. The analysis may run slower, may yield inaccurate results, and may require more memory if this is not the case.
For *tie pair (assembly__pickedsurf380-assembly__pickedsurf379), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
Slave node 3 instance sanjiaopan-1 will not be tied to the master surface assembly__pickedsurf309. The distance from the master surface is greater than the position tolerance value.
Slave node 4 instance sanjiaopan-1 will not be tied to the master surface assembly__pickedsurf309. The distance from the master surface is greater than the position tolerance value.
Slave node 6 instance sanjiaopan-1 will not be tied to the master surface assembly__pickedsurf309. The distance from the master surface is greater than the position tolerance value.
Slave node 7 instance sanjiaopan-1 will not be tied to the master surface assembly__pickedsurf309. The distance from the master surface is greater than the position tolerance value.
Slave node 11 instance sanjiaopan-1 will not be tied to the master surface assembly__pickedsurf309. The distance from the master surface is greater than the position tolerance value.
Slave node 62 instance sanjiaopan-1 will not be tied to the master surface assembly__pickedsurf309. The distance from the master surface is greater than the position tolerance value.
Slave node 63 instance sanjiaopan-1 will not be tied to the master surface assembly__pickedsurf309. The distance from the master surface is greater than the position tolerance value.
Slave node 64 instance sanjiaopan-1 will not be tied to the master surface assembly__pickedsurf309. The distance from the master surface is greater than the position tolerance value.
Slave node 65 instance sanjiaopan-1 will not be tied to the master surface assembly__pickedsurf309. The distance from the master surface is greater than the position tolerance value.
Slave node 66 instance sanjiaopan-1 will not be tied to the master surface assembly__pickedsurf309. The distance from the master surface is greater than the position tolerance value.
Slave node 67 instance sanjiaopan-1 will not be tied to the master surface assembly__pickedsurf309. The distance from the master surface is greater than the position tolerance value.
Slave node 13 instance leisanjiaojia-copy-1 will not be tied to the master surface assembly__pickedsurf363. The distance from the master surface is greater than the position tolerance value.
Slave node 161 instance leisanjiaojia-copy-1 will not be tied to the master surface assembly__pickedsurf363. The distance from the master surface is greater than the position tolerance value.
Slave node 162 instance leisanjiaojia-copy-1 will not be tied to the master surface assembly__pickedsurf363. The distance from the master surface is greater than the position tolerance value.
Slave node 163 instance leisanjiaojia-copy-1 will not be tied to the master surface assembly__pickedsurf363. The distance from the master surface is greater than the position tolerance value.
Slave node 164 instance leisanjiaojia-copy-1 will not be tied to the master surface assembly__pickedsurf363. The distance from the master surface is greater than the position tolerance value.
Slave node 165 instance leisanjiaojia-copy-1 will not be tied to the master surface assembly__pickedsurf363. The distance from the master surface is greater than the position tolerance value.
Slave node 166 instance leisanjiaojia-copy-1 will not be tied to the master surface assembly__pickedsurf363. The distance from the master surface is greater than the position tolerance value.
Slave node 167 instance leisanjiaojia-copy-1 will not be tied to the master surface assembly__pickedsurf363. The distance from the master surface is greater than the position tolerance value.
Slave node 189 instance leisanjiaojia-copy-1 will not be tied to the master surface assembly__pickedsurf363. The distance from the master surface is greater than the position tolerance value.
Slave node 820 instance leisanjiaojia-copy-1 will not be tied to the master surface assembly__pickedsurf363. The distance from the master surface is greater than the position tolerance value.
Slave node 821 instance leisanjiaojia-copy-1 will not be tied to the master surface assembly__pickedsurf363. The distance from the master surface is greater than the position tolerance value.
Slave node 11 instance leisanjiaojia-copy-1 will not be tied to the master surface assembly__pickedsurf383. The distance from the master surface is greater than the position tolerance value.
Slave node 168 instance leisanjiaojia-copy-1 will not be tied to the master surface assembly__pickedsurf383. The distance from the master surface is greater than the position tolerance value.
Slave node 169 instance leisanjiaojia-copy-1 will not be tied to the master surface assembly__pickedsurf383. The distance from the master surface is greater than the position tolerance value.
Slave node 170 instance leisanjiaojia-copy-1 will not be tied to the master surface assembly__pickedsurf383. The distance from the master surface is greater than the position tolerance value.
Slave node 171 instance leisanjiaojia-copy-1 will not be tied to the master surface assembly__pickedsurf383. The distance from the master surface is greater than the position tolerance value.
Slave node 172 instance leisanjiaojia-copy-1 will not be tied to the master surface assembly__pickedsurf383. The distance from the master surface is greater than the position tolerance value.
Slave node 173 instance leisanjiaojia-copy-1 will not be tied to the master surface assembly__pickedsurf383. The distance from the master surface is greater than the position tolerance value.
Slave node 174 instance leisanjiaojia-copy-1 will not be tied to the master surface assembly__pickedsurf383. The distance from the master surface is greater than the position tolerance value.
Slave node 812 instance leisanjiaojia-copy-1 will not be tied to the master surface assembly__pickedsurf383. The distance from the master surface is greater than the position tolerance value.
Slave node 813 instance leisanjiaojia-copy-1 will not be tied to the master surface assembly__pickedsurf383. The distance from the master surface is greater than the position tolerance value.
Slave node 814 instance leisanjiaojia-copy-1 will not be tied to the master surface assembly__pickedsurf383. The distance from the master surface is greater than the position tolerance value.
Slave node 21 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf385. The distance from the master surface is greater than the position tolerance value.
Slave node 22 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf385. The distance from the master surface is greater than the position tolerance value.
Slave node 154 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf385. The distance from the master surface is greater than the position tolerance value.
Slave node 155 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf385. The distance from the master surface is greater than the position tolerance value.
Slave node 156 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf385. The distance from the master surface is greater than the position tolerance value.
Slave node 169 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf385. The distance from the master surface is greater than the position tolerance value.
Slave node 170 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf385. The distance from the master surface is greater than the position tolerance value.
Slave node 171 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf385. The distance from the master surface is greater than the position tolerance value.
Slave node 172 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf385. The distance from the master surface is greater than the position tolerance value.
Slave node 175 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf385. The distance from the master surface is greater than the position tolerance value.
Slave node 176 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf385. The distance from the master surface is greater than the position tolerance value.
Slave node 17 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf368. The distance from the master surface is greater than the position tolerance value.
Slave node 20 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf368. The distance from the master surface is greater than the position tolerance value.
Slave node 142 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf368. The distance from the master surface is greater than the position tolerance value.
Slave node 143 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf368. The distance from the master surface is greater than the position tolerance value.
Slave node 144 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf368. The distance from the master surface is greater than the position tolerance value.
Slave node 157 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf368. The distance from the master surface is greater than the position tolerance value.
Slave node 158 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf368. The distance from the master surface is greater than the position tolerance value.
Slave node 159 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf368. The distance from the master surface is greater than the position tolerance value.
Slave node 160 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf368. The distance from the master surface is greater than the position tolerance value.
Slave node 239 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf368. The distance from the master surface is greater than the position tolerance value.
Slave node 240 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf368. The distance from the master surface is greater than the position tolerance value.
Slave node 3 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf369. The distance from the master surface is greater than the position tolerance value.
Slave node 4 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf369. The distance from the master surface is greater than the position tolerance value.
Slave node 54 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf369. The distance from the master surface is greater than the position tolerance value.
Slave node 55 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf369. The distance from the master surface is greater than the position tolerance value.
Slave node 56 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf369. The distance from the master surface is greater than the position tolerance value.
Slave node 81 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf369. The distance from the master surface is greater than the position tolerance value.
Slave node 82 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf369. The distance from the master surface is greater than the position tolerance value.
Slave node 83 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf369. The distance from the master surface is greater than the position tolerance value.
Slave node 84 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf369. The distance from the master surface is greater than the position tolerance value.
Slave node 212 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf369. The distance from the master surface is greater than the position tolerance value.
Slave node 213 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf369. The distance from the master surface is greater than the position tolerance value.
Slave node 5 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf372. The distance from the master surface is greater than the position tolerance value.
Slave node 6 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf372. The distance from the master surface is greater than the position tolerance value.
Slave node 66 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf372. The distance from the master surface is greater than the position tolerance value.
Slave node 67 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf372. The distance from the master surface is greater than the position tolerance value.
Slave node 68 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf372. The distance from the master surface is greater than the position tolerance value.
Slave node 75 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf372. The distance from the master surface is greater than the position tolerance value.
Slave node 76 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf372. The distance from the master surface is greater than the position tolerance value.
Slave node 77 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf372. The distance from the master surface is greater than the position tolerance value.
Slave node 78 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf372. The distance from the master surface is greater than the position tolerance value.
Slave node 209 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf372. The distance from the master surface is greater than the position tolerance value.
Slave node 210 instance tanghuangban-copy-1 will not be tied to the master surface assembly__pickedsurf372. The distance from the master surface is greater than the position tolerance value.
Slave node 11 instance leisanjiaojia-1 will not be tied to the master surface assembly__pickedsurf365. The distance from the master surface is greater than the position tolerance value.
Slave node 168 instance leisanjiaojia-1 will not be tied to the master surface assembly__pickedsurf365. The distance from the master surface is greater than the position tolerance value.
Slave node 169 instance leisanjiaojia-1 will not be tied to the master surface assembly__pickedsurf365. The distance from the master surface is greater than the position tolerance value.
Slave node 170 instance leisanjiaojia-1 will not be tied to the master surface assembly__pickedsurf365. The distance from the master surface is greater than the position tolerance value.
Slave node 171 instance leisanjiaojia-1 will not be tied to the master surface assembly__pickedsurf365. The distance from the master surface is greater than the position tolerance value.
Slave node 172 instance leisanjiaojia-1 will not be tied to the master surface assembly__pickedsurf365. The distance from the master surface is greater than the position tolerance value.
Slave node 173 instance leisanjiaojia-1 will not be tied to the master surface assembly__pickedsurf365. The distance from the master surface is greater than the position tolerance value.
Slave node 174 instance leisanjiaojia-1 will not be tied to the master surface assembly__pickedsurf365. The distance from the master surface is greater than the position tolerance value.
Slave node 178 instance leisanjiaojia-1 will not be tied to the master surface assembly__pickedsurf365. The distance from the master surface is greater than the position tolerance value.
Slave node 812 instance leisanjiaojia-1 will not be tied to the master surface assembly__pickedsurf365. The distance from the master surface is greater than the position tolerance value.
Slave node 813 instance leisanjiaojia-1 will not be tied to the master surface assembly__pickedsurf365. The distance from the master surface is greater than the position tolerance value.
Slave node 13 instance leisanjiaojia-1 will not be tied to the master surface assembly__pickedsurf381. The distance from the master surface is greater than the position tolerance value.
Slave node 161 instance leisanjiaojia-1 will not be tied to the master surface assembly__pickedsurf381. The distance from the master surface is greater than the position tolerance value.
Slave node 162 instance leisanjiaojia-1 will not be tied to the master surface assembly__pickedsurf381. The distance from the master surface is greater than the position tolerance value.
Slave node 163 instance leisanjiaojia-1 will not be tied to the master surface assembly__pickedsurf381. The distance from the master surface is greater than the position tolerance value.
Slave node 164 instance leisanjiaojia-1 will not be tied to the master surface assembly__pickedsurf381. The distance from the master surface is greater than the position tolerance value.
Slave node 165 instance leisanjiaojia-1 will not be tied to the master surface assembly__pickedsurf381. The distance from the master surface is greater than the position tolerance value.
Slave node 166 instance leisanjiaojia-1 will not be tied to the master surface assembly__pickedsurf381. The distance from the master surface is greater than the position tolerance value.
Slave node 167 instance leisanjiaojia-1 will not be tied to the master surface assembly__pickedsurf381. The distance from the master surface is greater than the position tolerance value.
Slave node 820 instance leisanjiaojia-1 will not be tied to the master surface assembly__pickedsurf381. The distance from the master surface is greater than the position tolerance value.
Slave node 821 instance leisanjiaojia-1 will not be tied to the master surface assembly__pickedsurf381. The distance from the master surface is greater than the position tolerance value.
Slave node 822 instance leisanjiaojia-1 will not be tied to the master surface assembly__pickedsurf381. The distance from the master surface is greater than the position tolerance value.
Slave node 21 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf373. The distance from the master surface is greater than the position tolerance value.
Slave node 22 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf373. The distance from the master surface is greater than the position tolerance value.
Slave node 154 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf373. The distance from the master surface is greater than the position tolerance value.
Slave node 155 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf373. The distance from the master surface is greater than the position tolerance value.
Slave node 156 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf373. The distance from the master surface is greater than the position tolerance value.
Slave node 169 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf373. The distance from the master surface is greater than the position tolerance value.
Slave node 170 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf373. The distance from the master surface is greater than the position tolerance value.
Slave node 171 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf373. The distance from the master surface is greater than the position tolerance value.
Slave node 172 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf373. The distance from the master surface is greater than the position tolerance value.
Slave node 175 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf373. The distance from the master surface is greater than the position tolerance value.
Slave node 176 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf373. The distance from the master surface is greater than the position tolerance value.
Slave node 17 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf376. The distance from the master surface is greater than the position tolerance value.
Slave node 20 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf376. The distance from the master surface is greater than the position tolerance value.
Slave node 142 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf376. The distance from the master surface is greater than the position tolerance value.
Slave node 143 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf376. The distance from the master surface is greater than the position tolerance value.
Slave node 144 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf376. The distance from the master surface is greater than the position tolerance value.
Slave node 157 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf376. The distance from the master surface is greater than the position tolerance value.
Slave node 158 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf376. The distance from the master surface is greater than the position tolerance value.
Slave node 159 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf376. The distance from the master surface is greater than the position tolerance value.
Slave node 160 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf376. The distance from the master surface is greater than the position tolerance value.
Slave node 239 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf376. The distance from the master surface is greater than the position tolerance value.
Slave node 240 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf376. The distance from the master surface is greater than the position tolerance value.
Slave node 3 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf377. The distance from the master surface is greater than the position tolerance value.
Slave node 4 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf377. The distance from the master surface is greater than the position tolerance value.
Slave node 54 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf377. The distance from the master surface is greater than the position tolerance value.
Slave node 55 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf377. The distance from the master surface is greater than the position tolerance value.
Slave node 56 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf377. The distance from the master surface is greater than the position tolerance value.
Slave node 81 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf377. The distance from the master surface is greater than the position tolerance value.
Slave node 82 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf377. The distance from the master surface is greater than the position tolerance value.
Slave node 83 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf377. The distance from the master surface is greater than the position tolerance value.
Slave node 84 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf377. The distance from the master surface is greater than the position tolerance value.
Slave node 212 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf377. The distance from the master surface is greater than the position tolerance value.
Slave node 213 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf377. The distance from the master surface is greater than the position tolerance value.
Slave node 5 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf379. The distance from the master surface is greater than the position tolerance value.
Slave node 6 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf379. The distance from the master surface is greater than the position tolerance value.
Slave node 66 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf379. The distance from the master surface is greater than the position tolerance value.
Slave node 67 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf379. The distance from the master surface is greater than the position tolerance value.
Slave node 68 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf379. The distance from the master surface is greater than the position tolerance value.
Slave node 75 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf379. The distance from the master surface is greater than the position tolerance value.
Slave node 76 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf379. The distance from the master surface is greater than the position tolerance value.
Slave node 77 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf379. The distance from the master surface is greater than the position tolerance value.
Slave node 78 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf379. The distance from the master surface is greater than the position tolerance value.
Slave node 209 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf379. The distance from the master surface is greater than the position tolerance value.
Slave node 210 instance tanghuangban-1 will not be tied to the master surface assembly__pickedsurf379. The distance from the master surface is greater than the position tolerance value.
1287 nodes are either missing intersection with their respective master surface or are outside the adjust zone. The nodes have been identified in node set WarnNodeMissMasterIntersect.
Logarithmic scale is chosen for zero frequency
The load case parameter should no longer be used in *steady state dynamics or *matrix generate procedures. Instead use real or imaginary parameter to describe load type.
720 elements are distorted. Either the isoparametric angles are out of the suggested limits or the triangular or tetrahedral quality measure is bad. The elements have been identified in element set WarnElemDistorted.
A STEADY STATE, SUBSPACE PROJECTION BASED, OR MODE-BASED DYNAMIC ANALYSIS IS REQUESTED FOR A MODEL WITH NON-DIAGONAL MASS MATRIX. Abaqus/Standard SUBSPACE PROJECTION BASED OR MODE-BASED DYNAMIC ANALYSIS FOR A MODEL WITH NON-DIAGONAL MASS MATRIX (E.G. USING SUBSTRUCTURES) MIGHT GIVE INCORRECT REACTION FORCES. HOWEVER, OTHER OUTPUT QUANTITIES WILL BE CORRECT. THE WORKAROUND FOR THE STEADY STATE DYNAMIC ANALYSIS IS TO USE THE DIRECT SOLUTION PROCEDURE.
The specified type of interaction cannot be created or resumed in this type of step. Contact pair definition will not written to the ODB.
请高手,指导怎么修改,我改了好久都还是这些警告~ |
