查看: 73|回复: 1
复杂非线性方程求零点问题
发表于 2012-1-9 21:16:51 | 显示全部楼层 |阅读模式 来自 江苏南京
  1. clc
  2. clear
  3. syms N M
  4. K3=[1, 0, 0, 0, 0, 0, -1, 0, 0, 0, 0, 0;0, 3.975474723*10^10*(0.0000001949404375*N - 1)^(1/2), 0, 12.3, 0, 0, 0, (-4.722675159)*10^10*(1 - 0.0000001122230922*N)^(1/2), 0, 0, 0, -550;1516646116.0, 0, 1, 0, 0, 0, 0, 0, -1, 0, 0, 0;0, 0, 0, 0, 1, 0, -3503184.713, 0, 0, 0, -1, 0;0, 0, 0, -0.00000000811, 0, 0, 0, 0, 0, 8.0*10^(-11), 0, 0;0, 0, 0, 0, 0, -0.000005, 0, 0, 0, 0, 0, 0.000157;3.975474723*10^10*sin(2*pi*M*(0.0000001949404375*N - 1)^(1/2))*(0.0000001949404375*N - 1)^(1/2), 3.975474723*10^10*cos(2*pi*M*(0.0000001949404375*N - 1)^(1/2))*(0.0000001949404375*N - 1)^(1/2), (-12.3)*sinh(2*pi*M), 12.3*cosh(2*pi*M), 0, 0, 0, 0, 0, 0, 0, 0;0, 0, 0, 0, 0, 0, 4.722675159*10^10*sinh(20.0*pi*M*(1 - 0.0000001122230922*N)^(1/2))*(1 - 0.0000001122230922*N)^(1/2), 4.722675159*10^10*cosh(20.0*pi*M*(1 - 0.0000001122230922*N)^(1/2))*(1 - 0.0000001122230922*N)^(1/2), 0, 0, 550*sinh(20.0*pi*M), 550*cosh(20.0*pi*M);1516646116.0*cos(2*pi*M*(0.0000001949404375*N - 1)^(1/2)), (-1516646116.0)*sin(2*pi*M*(0.0000001949404375*N - 1)^(1/2)), cosh(2*pi*M), -sinh(2*M*pi), 0, 0, 0, 0, 0, 0, 0, 0;0, 0, 0, 0, cosh(2*pi*M), -sinh(2*M*pi), 0, 0, 0, 0, 0, 0;0, 0, 0, 0, 0, 0, 0, 0, cosh(20.0*pi*M), sinh(20.0*pi*M), 0, 0;0, 0, 0, 0, 0, 0, 3503184.713*cosh(20.0*pi*M*(1 - 0.0000001122230922*N)^(1/2)), 3503184.713*sinh(20.0*pi*M*(1 - 0.0000001122230922*N)^(1/2)), 0, 0, cosh(20.0*pi*M), sinh(20.0*pi*M)];
  5. % K3=vpa(K3);
  6. K5=subs(K3,M,1);
  7. df=det(K5);
  8. dff=eval(['@(N)',char(df)]);
  9. opt=optimset;
  10. opt.largeScale='off';
  11. opt.MaxFunEvals=200;
  12. opt.TolX=1e-10;
  13. opt.TolFun=1e-10;
  14. [x,f]=fsolve(dff,3e6,opt)
复制代码
结果如下:
No solution found.
fsolve stopped because the relative size of the current step is less than the
selected value of the step size tolerance squared, but the vector of function values
is not near zero as measured by the selected value of the function tolerance.
<stopping criteria details>
x =
  4.0041e+006 +1.3434e-011i
f =
-5.4836e+082 +9.3127e+086i
明显不对,此乃何故?
发表于 2012-1-11 09:51:42 | 显示全部楼层 来自 山东烟台
明显是不收敛,换个初始值试试
GMT+8, 2024-10-4 14:49 , Processed in 0.040552 second(s), 15 queries , Gzip On, MemCache On.
