- 2012-5-29
发表于 2012-8-29 19:25:44
来自 江苏南京
蒋二两 发表于 2012-8-26 19:36
请问用Input文件来实现重启动时,建立Job时,Model是用原来的模型还是Input Files修改后的inp文件)?我 ...
我explicit,recover计算
遇到这样的问题The executable C:\SIMULIA\Abaqus\6.9-1\exec\explicit.exe aborted with system error code 144. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
Job 2012-8-28-recover aborted due to errors.
求解决 |
