查看: 213|回复: 1
[入门&进阶] 求教proe+ansys+isight优化
发表于 2012-2-27 10:25:16 | 显示全部楼层 |阅读模式 来自 江西南昌
  我在做proe+ansys+isight优化,在做proe和isight集合的部分,我的proe用的是野火版5.0的,在proe的trail文件运行之后出现“!%CE错误: 轨迹文件在第61行失序。”这个问题如何解决,大伙帮忙看一下,谢谢!
下面是我的trail文件:
!trail file version No. 1450
!Pro/ENGINEER  TM  Wildfire 5.0  (c) 1988-2002 by Wisdom Systems  All Rights Reserved.
< 0 0.860444 885 0 0 726 1024 0 0 768 13
!mem_use INCREASE Blocks 210811, AppSize 27257115, SysSize 35188160
< 0 0.680000 680 0 0 622 1024 0 0 768 13
< 0 0.612000 612 0 0 622 1024 0 0 768 13
< 0 0.614000 614 0 0 622 1024 0 0 768 13
< 0 0.627000 627 0 0 622 1024 0 0 768 13
< 0 0.627000 627 0 0 594 1024 0 0 768 13
< 0 0.713481 767 0 0 602 1024 0 0 768 13
~ Resize `main_dlg_cur` `main_dlg_cur` \
4 -0.146023 -0.146023 37.382008 26.247718
~ Move `main_dlg_cur` `main_dlg_cur` \
2 -0.146023 -0.146023
~ Command `ProCmdModelOpen`
< 2 0.118519 178 0 0 100 1024 0 0 768 13
~ Trail `UI Desktop` `UI Desktop` \
`DLG_PREVIEW_POST` \
`file_open`
`PREVIEW_POPUP_TIMER` \
`file_openh_list.Filelist:<NULL>`
~ Select `file_open` `SAB_pfafs:drives`
~ Close `file_open` `SAB_pfafs:drives`
~ Activate `file_open` `M_h:`
~ Select `file_open` `Ph_list.Filelist` \
1  `huizhuanyao_proe`
~ Activate `file_open` `Ph_list.Filelist` \
1  `tongti`
1  `tongti`
~ Activate `file_open` `bkw_EMBED_BROWSER_TB_BFH_LAYOUT`
~ Activate `file_open` `Ph_preview.Preview`
1  `tongti`
1  `proetu`
1  `proetu`
1  `tuolun`
1  `tuolun`
1  `zuhe.asm`
`file_open:Ph_list.Filelist:zuhe.asm`
`file_open:Ph_list.Filelist:<NULL>`
~ FocusIn `file_open` `Ph_list.Filelist`
~ Activate `file_open` `Open`
< 0 0.713481 739 0 0 602 1024 0 0 768 13
~ Timer `UI Desktop` `UI Desktop` \
`EmbedBrowserTimer`
1  `node2`
~ RButtonArm `main_dlg_cur` `PHTLeft.AssyTree` \
`node2`
!TUOLUN.PRT
~ PopupOver `main_dlg_cur` `ActionMenu` \
1  `PHTLeft.AssyTree`
~ Open `main_dlg_cur` `ActionMenu`
`main_dlg_w1:PHTLeft.AssyTree:<NULL>`
~ Close `main_dlg_cur` `ActionMenu`
~ Activate `main_dlg_cur` `OpenModel`
< 2 0.592000 592 0 0 592 1024 0 0 768 13
< 2 0.742000 742 0 0 664 1024 0 0 768 13
< 2 0.598000 598 0 0 622 1024 0 0 768 13
< 2 0.612000 612 0 0 622 1024 0 0 768 13
!mem_use INCREASE Blocks 302384, AppSize 48314537, SysSize 61579784
< 2 0.614000 614 0 0 622 1024 0 0 768 13
< 2 0.627000 627 0 0 622 1024 0 0 768 13
< 2 0.627000 627 0 0 594 1024 0 0 768 13
< 2 0.599000 599 0 0 594 1024 0 0 768 13
`main_dlg_w2:PHTLeft.AssyTree:<NULL>`
< 2 0.713481 739 0 0 602 1024 0 0 768 13
~ Command `ProCmdMmParams`
~ Close `relation_dlg` `relation_dlg`
~ Command `ProCmdMmRels`
~ Activate `0_std_confirm` `OK`
~ Command `ProCmdMmProgram`
#EDIT DESIGN
#DONE/RETURN
~ Close `main_dlg_cur` `main_dlg_cur`
!Command ProCmdWinOSCloseAsyn was pushed from the software.
!Command ProCmdWinClose was pushed from the software.
~ Select `main_dlg_cur` `MenuBar1` \
1  `Utilities`
~ Close `main_dlg_cur` `MenuBar1`
~ Select `main_dlg_cur` `PHTLeft.AssyTree` \
1  `node1`
`node1`
!TONGTI.PRT
< 2 0.586000 586 0 0 622 1024 0 0 768 13
< 2 0.599000 599 0 0 622 1024 0 0 768 13
#EDIT DESIGN
#DONE/RETURN
~ Minimize `main_dlg_cur` `main_dlg_cur`
~ Restore `main_dlg_cur` `main_dlg_cur`
1  `node2`
`node2`
!TUOLUN.PRT
~ Select `main_dlg_cur` `SimpRepOper`
~ Close `main_dlg_cur` `SimpRepOper`
#EDIT DESIGN
!sket_eps       76.94258497
!sket_eps       53.86225752
!results of editing TUOLUN.pls
@ edit
^VERSION 5.0
^REVNUM 2065
^d0:0=1230
^d1:0=2200
^d2:0=880
^d3:0=30
^d4:0=1720
^d25:0=100
^d45:0=60
^d46:0=228.16
^d47:0=360
^d26:0=1763
^d27 :0=200
^d28:0=760
^d29:0=615
^d58:0= 360
^d60:0=1050
^d61:0=0.76
^d62:0=90
^d63:0=45
^d64:0=11.95
^d72:0=2
^d73:0=2
^d0:1=1230
^d1:1=5680
^d2:1=5500
1  `Utilities`
1  `Manikin`
1  `Windows`
~ FocusIn `UI Message Dialog` `no`
~ Activate `UI Message Dialog` `no`
#EDIT DESIGN
~ Command `ProCmdModelSave`
~ Activate `file_saveas` `OK`
1  `File`
~ FocusIn `UI Message Dialog` `yes`
~ Activate `UI Message Dialog` `yes`
!End of Trail File
运行之后的文件:
!mem_use INCREASE Blocks 210815, AppSize 27257307, SysSize 35188160
!%CI欢迎使用 Pro/ENGINEER Wildfire 5.0。
~ Close `pse_abnorm_exit_dlg` `pse_abnorm_exit_dlg`
~ Command `ProCmdUtilTrailTrain`
`file_open`
~ Activate `file_open` `desktop_pb`
1  `today1.txt`
2 -0.109518 -0.109518
`file_open`
`file_open`
1  `tongti`
1  `tongti`
1  `tongti`
1  `proetu`
1  `proetu`
1  `tuolun`
1  `tuolun`
1  `zuhe.asm`
!Command ProCmdModelOpenExe was pushed from the software.
!27-Feb-12 10:19:44  Start H:\huizhuanyao_proe\proetu\tuolun\zuhe.asm.2
!27-Feb-12 10:19:44  Start H:\huizhuanyao_proe\proetu\tuolun\tuolun.prt.2
!27-Feb-12 10:19:44  End   H:\huizhuanyao_proe\proetu\tuolun\tuolun.prt.2
!27-Feb-12 10:19:44  Start H:\huizhuanyao_proe\proetu\tuolun\tongti.prt.2
!27-Feb-12 10:19:44  End   H:\huizhuanyao_proe\proetu\tuolun\tongti.prt.2
!27-Feb-12 10:19:44  End   H:\huizhuanyao_proe\proetu\tuolun\zuhe.asm.2
`EmbedBrowserTimer`
!End of Trail File
发表于 2012-12-7 19:14:54 | 显示全部楼层 来自 山西太原
楼主想请教你一下,上面trail文件中的这些是在proe中的哪个地方定义的??
^d0:0=1230
^d1:0=2200
^d2:0=88
^d3:0=30
^d4:0=1720
^d25:0=1003
^d45:0=60
^d46:0=228.16
^d47:0=360
^d26:0=17637
^d27 :0=200
^d28:0=760
^d29:0=615
^d58:0= 360
^d60:0=1050
^d61:0=
^d62:0=90
^d63:0=45
^d64:0=11.95
^d72:0=2
^d73:0=2
^d0:1=1230
^d1:1=56803
^d2:1=5500
回复 1 不支持 0
GMT+8, 2024-10-2 20:37 , Processed in 0.033132 second(s), 11 queries , Gzip On, MemCache On.
