***ERROR: THE SLAVE SURFACE ASSEMBLY_CP-2-HINGLE-1 DOES NOT EXIST.
***NOTE: DUE TO AN INPUT ERROR THE ANALYSIS PRE-PROCESSOR HAS BEEN UNABLE TO
INTERPRET SOME DATA. SUBSEQUENT ERRORS MAY BE CAUSED BY THIS OMISSION
*contactpair, interaction=INTPROP-1
***ERROR: THE SLAVE SURFACE ASSEMBLY_CP-4-HINGLE-1 DOES NOT EXIST.
*solidsection, elset=ASSEMBLY_HINGLE-1__PICKEDSET9, material=STEELL
*solidsection, elset=ASSEMBLY_HINGLE-1-1__PICKEDSET8, material=STEELL
*surfaceinteraction, name=INTPROP-1
*rigidbody, refnode=ASSEMBLY_PART-3-1_PART-3-1-REFPT_, analyticalsurface=ASSEMBLY_PART-3-1_SURF-1
*surface, type=REVOLUTION, name=ASSEMBLY_PART-3-1_SURF-1
*surface, type=ELEMENT, name=ASSEMBLY_SURF-3
*surface, type=ELEMENT, name=ASSEMBLY_SURF-5
*surface, type=ELEMENT, name=ASSEMBLY_CP-2-HINGLE-1-1
*surface, type=ELEMENT, name=ASSEMBLY_CP-5-HINGLE-1-1
*surface, type=ELEMENT, name=ASSEMBLY__PICKEDSURF40
*output, field
*output, history
*output, field
*output, history
*elementoutput, directions=YES
*elementoutput, elset=ASSEMBLY_SET-HOLE
*output, field
*output, history
*output, field
*output, history
*output, field
*output, history
*output, field
*output, history
*Step, name=contact
*output, field
*output, history
*Step, name=load
*output, field
*output, history
*Step, name=contact
*Step, name=load
*Step, name=contact
*static
*boundary, op=NEW
*boundary, op=NEW
*boundary, op=NEW
*monitor, dof=1, node=ASSEMBLY__PICKEDSET36, frequency=1
*output, field
*contactoutput
*output, history
*endstep
*Step, name=load
*static
*dsload
*output, field
*contactoutput
*output, history
*endstep
*boundary
*boundary
*boundary
*Step, name=contact
*static
*boundary, op=NEW
*boundary, op=NEW
*boundary, op=NEW
*output, field
*nodeoutput
*output, history
*nodeoutput, nset=ASSEMBLY_SET-POINTS
*nodeoutput, nset=ASSEMBLY_SET-SURFACE
*endstep
*Step, name=load
*static
*output, field
*nodeoutput
*output, history
*endstep
E L E M E N T Q U A L I T Y C H E C K S
***NOTES: DISTORTED ISOPARAMETRIC ELEMENTS: ANGLE BETWEEN ISOPARAMETRIC LINES
IS LESS THAN 45 DEGREES OR GREATER THAN 135 DEGREES.
TETRAHEDRAL QUALITY MEASURE: VOLUME OF TETRAHEDRON DIVIDED BY THE
VOLUME OF EQUILATERAL TETRAHEDRON WITH SAME CIRCUMSPHERE RADIUS;
0 FOR DEGENERATE TETRAHEDRON AND 1 FOR EQUILATERIAL TETRAHEDRON. IT
IS RECOMMENDED THAT THE TETRAHEDRAL QUALITY MEASURE BE GREATER THAN
0.02, THE MIN INTERIOR (DIHEDRAL) ANGLE BE GREATER THAN 10 DEGREES,
AND THE MAX INTERIOR (DIHEDRAL) ANGLE BE LESS THAN 160 DEGREES.
TRIANGULAR QUALITY MEASURE: AREA OF TRIANGLE DIVIDED BY THE AREA OF
EQUILATERAL TRIANGLE WITH SAME CIRCUMCIRCLE RADIUS; 0 FOR DEGENERATE
TRIANGLE AND 1 FOR EQUILATERAL TRIANGLE. IT IS RECOMMENDED THAT THE
TRIANGULAR QUALITY MEASURE BE GREATER THAN 0.01, THE MIN INTERIOR
ANGLE BE GREATER THAN 10 DEGREES, AND THE MAX INTERIOR ANGLE BE LESS
THAN 160 DEGREES.
NODAL ADJUSTMENTS ARISING FROM CONTACT INTERACTIONS AND/OR TIE
CONSTRAINTS CAN CAUSE SEVERE ELEMENT DISTORTION. IT MAY BE NECESSARY
TO REMESH IN ORDER TO REDUCE THE AMOUNT OF ADJUSTMENT.
***WARNING: 3 elements are distorted. Either the interior angles are out of
the suggested limits or the triangular or tetrahedral quality
measure is bad. The elements have been identified in element set
WarnElemDistorted.
Distorted isoparametric elements
Element Min/max angle Adjusted nodes
HINGLE-1.1229 41.4525 NO
HINGLE-1.1322 27.4165 NO
HINGLE-1.1389 33.6314 NO
- (RAMP) OR (STEP) - INDICATE USE OF DEFAULT AMPLITUDES ASSOCIATED WITH THE STEP
P R O B L E M S I Z E
NUMBER OF ELEMENTS IS 2897
NUMBER OF ELEMENTS DEFINED BY THE USER AND *TIE 2776
NUMBER OF INTERNAL ELEMENTS GENERATED FOR CONTACT 120
NUMBER OF NODES IS 4064
NUMBER OF NODES DEFINED BY THE USER 3824
NUMBER OF INTERNAL NODES GENERATED BY THE PROGRAM 240
TOTAL NUMBER OF VARIABLES IN THE MODEL 11835
(DEGREES OF FREEDOM PLUS ANY LAGRANGE MULTIPLIER VARIABLES)
THE PROGRAM HAS DISCOVERED 8 FATAL ERRORS
** EXECUTION IS TERMINATED **
END OF USER INPUT PROCESSING
JOB TIME SUMMARY
USER TIME (SEC) = 0.70000
SYSTEM TIME (SEC) = 0.20000
TOTAL CPU TIME (SEC) = 0.90000
WALLCLOCK TIME (SEC) = 2
