- 2011-5-24
楼主 |
发表于 2012-3-17 09:37:43
来自 辽宁大连
求大侠指教!!!!
** OptiStruct 10.0 **
** Design and Optimization Software **
** from Altair Engineering, Inc. **
** Windows XP Professional SP3 (Build 2600) ZHANGXUETAO-PC **
** 2 CPU: Intel(R) Pentium(R) Dual CPU E2180 @ 2.00GHz **
** CPU speed 2000 MHz **
** 1148 MB RAM, 3933 MB swap **
** Build tag: 0466938_5333O00_Ci3242M-000 4000 **
** COPYRIGHT (C) 1996-2009 Altair Engineering, Inc. **
** All Rights Reserved. Copyright notice does not imply publication. **
** Contains trade secrets of Altair Engineering, Inc. **
** Decompilation or disassembly of this software strictly prohibited. **
*** OptiStruct defaults set from:
install config file: d:\Altair\hw10.0/hwsolvers/hwsolver.cfg
*** ERROR # 1479 *** in the input data:
Incorrectly formatted numeric data in field 9.
(If it is a character field, it should start with a letter.)
Detected while reading line 95190 from file F:/zuizhongyouhuafenxi/2.fem:
" BEAML 27 1 +"
Syntax error in the current line:
95190 BEAML, 27, 1, , , , , , >ERROR<
Detected while reading line 95196 from file F:/zuizhongyouhuafenxi/2.fem:
"PBEAML 28 1 +"
95196:PBEAML, 28, 1, , , , , , >ERROR<
*** WARNING # 1072
DCONSTR lower bound of 0.0 replaced with 1.0E-7.
It is suggested to leave unimportant bounds blank.
Detected while reading line 111 from file F:/zuizhongyouhuafenxi/2.fem:
"DCONSTR 1 20.0 237.0"
*** WARNING # 1051
CONM2 data has zero or negative mass.
Detected while reading line 46332 from file F:/zuizhongyouhuafenxi/2.fem:
"CONM2 70796 69435 00.0 0.0 0.0 0.0"
*** WARNING # 1051
Detected while reading line 46333 from file F:/zuizhongyouhuafenxi/2.fem:
"CONM2 70797 69436 00.0 0.0 0.0 0.0"
*** WARNING # 1051
Detected while reading line 46334 from file F:/zuizhongyouhuafenxi/2.fem:
"CONM2 70800 69438 00.0 0.0 0.0 0.0"
*** WARNING # 1051
Detected while reading line 46335 from file F:/zuizhongyouhuafenxi/2.fem:
"CONM2 70801 69437 00.0 0.0 0.0 0.0"
*** WARNING # 1051
Detected while reading line 46336 from file F:/zuizhongyouhuafenxi/2.fem:
"CONM2 70805 69440 00.0 0.0 0.0 0.0"
*** WARNING # 1051
Detected while reading line 46337 from file F:/zuizhongyouhuafenxi/2.fem:
"CONM2 70806 69439 00.0 0.0 0.0 0.0"
*** WARNING # 1051
Detected while reading line 46338 from file F:/zuizhongyouhuafenxi/2.fem:
"CONM2 70809 69441 00.0 0.0 0.0 0.0"
*** WARNING # 1051
Detected while reading line 46339 from file F:/zuizhongyouhuafenxi/2.fem:
"CONM2 70810 69442 00.0 0.0 0.0 0.0"
*** WARNING # 1051
Detected while reading line 46340 from file F:/zuizhongyouhuafenxi/2.fem:
"CONM2 70813 69444 00.0 0.0 0.0 0.0"
*** WARNING # 1051
Detected while reading line 46341 from file F:/zuizhongyouhuafenxi/2.fem:
"CONM2 70814 69443 00.0 0.0 0.0 0.0"
*** More of WARNING messages # 1051 were suppressed...
"PBEAML 27 1 +"
95190:PBEAML, 27, 1, , , , , , >ERROR<
"PBEAML 28 1 +"
RESOURCE USAGE INFORMATION
MAXIMUM MEMORY USED 60 MB
MAXIMUM DISK SPACE USED 0 MB
COMPUTE TIME INFORMATION
EXECUTION STARTED Sat Mar 17 10:02:39 2012
EXECUTION COMPLETED Sat Mar 17 10:02:41 2012
ELAPSED TIME 00:00:01
CPU TIME 00:00:01
*** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
***** END OF REPORT *****
For Useful OptiStruct Tips and Tricks, go to the URL:
http://www.altairhyperworks.com/tips.aspx
Following error/warning messages appeared too many times
and were suppressed:
1051
Total of 24 repeat message(s) were suppressed.
To see more messages use "MSGLMT" control card in the data or config file.
There were 4 error messages during input processing.
The first message is repeated below:
"PBEAML 27 1 +"
