- 2012-2-13
这是我的一个模拟直剪实验的程序,怎么都调试不通,希望高人指点。
; FNAME: Shear_box.dat
; the units used in this simulation: mass(kg), length(m), time(step),density(kg/m^3) , sxxreq=100000(pa);
; stiffness(N/m), force(N), pressure(N/m^2)
set random
new
call fishcall.fis
macro pt1 '6.0 0.0 0.0'
macro pt2 '6.0 6.0 0.0'
macro pt3 '0.0 6.0 0.0'
macro pt4 '0.0 0.0 0.0'
macro pt5 '6.0 0.0 3.0'
macro pt6 '6.0 6.0 3.0'
macro pt7 '0.0 6.0 3.0'
macro pt8 '0.0 0.0 3.0'
macro pt9 '6.0 0.0 3.01'
macro pt10 '6.0 6.0 3.01'
macro pt11 '0.0 6.0 3.01'
macro pt12 '0.0 0.0 3.01'
macro pt13 '6.0 0.0 6.01'
macro pt14 '6.0 6.0 6.01'
macro pt15 '0.0 6.0 6.01'
macro pt16 '0.0 0.0 6.01'
macro pt17 '6.0 -3.0 3.0'
macro pt18 '0.0 -3.0 3.0'
macro pt19 '6.0 9.0 3.0'
macro pt20 '0.0 9.0 3.0'
macro pt21 '5.95 0.05 6.01'
macro pt22 '0.05 0.05 6.01'
macro pt23 '0.05 5.95 6.01'
macro pt24 '5.95 5.95 6.01'
macro wall_s_stiff '1e16'
macro wall_n_stiff '1e16'
macro wall_fric '0.3'
macro wall_props 'kn wall_n_stiff ks wall_s_stiff fric wall_fric'
wall id 1 wall_props face pt1 pt2 pt3 pt4
wall id 2 wall_props face pt2 pt6 pt7 pt3
wall id 3 wall_props face pt3 pt7 pt8 pt4
wall id 4 wall_props face pt4 pt8 pt5 pt1
wall id 5 wall_props face pt1 pt5 pt6 pt2
wall id 6 wall_props face pt6 pt19 pt20 pt7
wall id 7 wall_props face pt5 pt8 pt18 pt17
wall id 8 wall_props face pt9 pt13 pt14 pt10
wall id 9 wall_props face pt14 pt15 pt11 pt10
wall id 10 wall_props face pt15 pt16 pt12 pt11
wall id 11 wall_props face pt13 pt9 pt12 pt16
wall id 12 wall_props face pt13 pt16 pt15 pt14
delete wall 12
wall id 13 wall_props face pt21 pt22 pt23 pt24
gen id=1,5000 rad 0.03 0.050 x 0 6 y 0 6 z 0 6.01
property density 2000 kn 1e8 ks 1e8
plot add wall red id on
plot set rotation (30, 0, 60)
plot add ball yellow
plot show
ini rad mul 4.5
set dt dscale
cycle 100
measure id 1 x 0.25 y 0.25 z 0.25 rad 0.24
print measure 1
plot show
; cycle 100
def wall_addr
w1 = find_wall(1)
w2 = find_wall(2)
w3 = find_wall(3)
w4 = find_wall(4)
w5 = find_wall(5)
w7 = find_wall(7)
w8 = find_wall(8)
w9 = find_wall(9)
w10 = find_wall(10)
w12= find_wall(12)
w13= find_wall(13)
end
def make_ss ;
ydisp1=w_y(w4)
ydisp2=w_y(w3)
xdif = w_x(w8) - w_x(w10)
ydif = w_y(w11)
zdif = w_z(w13)
wyforce2=w_yfob(w2)
wyforce8=w_yfob(w8)
wyforce10=w_yfob(w10)
wyforce11=w_yfob(w11)
wyforce9=w_yfob(w9)
wxforce2=w_xfob(w2)
wxforce8=w_xfob(w8)
wxforce10=w_xfob(w10)
wxforce11=w_xfob(w11)
wxforce9=w_xfob(w9)
shearforce=0.5*(wyforce2-wyforce11)
new_xwidth = 6.0 + xdif
new_ywidth = 6.0 + ydif
new_height = 0.5*6.0 + zdif
wsxx = 0.5*(w_xfob(w8) - w_xfob(w10)) / (new_ywidth * new_height)
wsyy = w_yfob(w11) / (new_xwidth * new_height)
wszz = w_zfob(w13)/ (new_xwidth * new_ywidth)
wexx = 2.0 * xdif / (width + new_xwidth)
weyy = 2.0 * ydif / (width + new_ywidth)
wezz = 2.0 * zdif / (0.5*height + new_height)
wevol = wexx + weyy + wezz
end
def make_gain ;
alpha = 0.05 ;
; count = 0
; avg_stiff = 0
; cp = contact_head ;
; loop while cp # null
; if c_ball2(cp) = w4
; count = count + 1
; avg_stiff = avg_stiff + c_kn(cp)
; end_if
; if c_ball2(cp) = w3
; count = count + 1
; end_if
; if c_ball2(cp) = w5
; count = count + 1
; end_if
; if c_ball2(cp) = w2
; count = count + 1
; end_if
; cp = c_next(cp)
; end_loop
;ncount = count / 4.0
;avg_stiff = avg_stiff / count
;gxy = alpha * (6.05 * 6.0) / (avg_stiff * ncount * tdel)
count = 0
avg_stiff = 0
cp = contact_head ; find avg. number of contacts on top/bottom walls
; if c_ball2(cp) = w1
; count = count + 1
; end_if
if c_ball2(cp) = w13
if wszz#0
www=c_ball2(cp)
count = count + 1
command
;print count
;pause
end_command
end_if
end_if
cp = c_next(cp)
end_loop
ncount = count
if count # 0
gz = alpha * (6.05 * 6.0)/ (avg_stiff * ncount * tdel)
else
gz=0.1
end_if
command
print count gz
;pause
end_command
end
def _servo
while_stepping
make_ss
ydisp=ydisp+w_y(w4)
; udx = gxy * (wsxx - 100000)
; w_xvel(w2) = udx
; w_xvel(w3) = -udx
; udy = gxy * (wsyy - 100000)
; w_yvel(w4) = udy
; w_yvel(w5) = -udy
; if z_servo = 1 ; switch stress servo on or off
udz = gz * (wszz - 100000)
command
print udz gz wszz count
; pause
end_command
; w_zvel(w1) = udz
w_zvel(w13) = udz
; end_if
end
def iterate
loop while 1 # 0
n_cyc=n_cyc+1
make_gain
; if abs((wsxx - 100000)/ 100000) < 5 then
; if abs((wsyy - 100000)/ 100000) < 5 then
; if wszz> 100000
if abs((wszz - 100000)/ 100000) < 5 then
exit
end_if
; end_if
; end_if
; end_if
command
cyc 100
end_command
end_loop
end
def accel_platens
;------Accelerates the platens to achieve vel of _vfinal in _nsteps,
; using _nchunks
_nsteps=2000
_nchunks=200
_vfinal=0.02
_close=0
_niter=_nsteps/_nchunks
loop _chnk(1,_nchunks)
if _close=1 then
_vel=_chnk*(_vfinal/_nchunks)
else
_vel=-_chnk*(_vfinal/_nchunks)
end_if
_mvel=-_vel
command
wall id 2 yv _vel
wall id 4 yv _vel
wall id 3 yv _vel
wall id 5 yv _vel
wall id 6 yv _vel
wall id 7 yv _vel
step _niter
end_command
end_loop
end
set grav 0 0 -9.8
macro zero_vel 'ini xvel 0.0 yvel 0.0 zvel 0.0 xspin 0.0 yspin 0.0 zspin 0.0'
plot add axes brown
plot add wall white id on
;plot show
;zero_vel
;cyc 5
;zero_vel
;cyc 5
zero_vel
wall_addr
prop fric 0.7
wall_addr
ydisp1=w_y(w4)
ydisp2=w_y(w3)
ydif = w_y(w11)
zdif = w_z(w13)
wyforce2=w_yfob(w2)
wyforce8=w_yfob(w8)
wyforce9=w_yfob(w9)
wxforce2=w_xfob(w2)
wxforce8=w_xfob(w8)
wxforce9=w_xfob(w9)
iterate ;
hist id=1 shearforce
hist id=2 wszz
hist id=3 ydisp2
hist id=4 wyforce2
hist id=5 wyforce11
hist id=6 wyforce8
hist id=7 wyforce9
hist id=8 wxforce2
hist id=9 wxforce8
hist id=10 energy body
hist id=11 energy boundary
hist id=12 energy fric
hist id=13 energy kinetic
hist id=14 energy strain
plot add hist -5 vs -3
accel_platens
save directshear_reg.sav |
