- 2011-9-30
** OptiStruct 10.0 **
** Design and Optimization Software **
** from Altair Engineering, Inc. **
** Windows XP Professional SP3 (Build 2600) DALIANJIAOTONG **
** 2 CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz **
** CPU speed 2800 MHz **
** 86 MB RAM, 1247 MB swap **
** Build tag: 0466938_5333O00_Ci3242M-000 4000 **
** COPYRIGHT (C) 1996-2009 Altair Engineering, Inc. **
** All Rights Reserved. Copyright notice does not imply publication. **
** Contains trade secrets of Altair Engineering, Inc. **
** Decompilation or disassembly of this software strictly prohibited. **
*** OptiStruct defaults set from:
install config file: D:\Altair\hw10.0/hwsolvers/hwsolver.cfg
NOTE # 1847
AUTOMATIC SCREENING is activated.
Use "DSCREEN,AUTO,OFF" to turn off this effect.
OPTIMIZATION FILE AND PARAMETER INFORMATION :
Optimization parameters from : F:/0507/0507.fem
FEM model file : F:/0507/0507.fem
Output files prefix : F:/0507/0507
FINITE ELEMENT MODEL DATA INFORMATION :
Total # of Grids (Structural) : 3
Total # of Elements : 1
Total # of Degrees of Freedom : 2
Total # of Non-zero Stiffness Terms : 3
Element Type Information
CBEAM Elements : 1
Load and Boundary Information
FORCE Sets : 1
SPC Sets : 1
Material and Property Information
PBEAM Cards : 1
MAT1 Cards : 1
OPTIMIZATION PROBLEM PARAMETERS :
Objective Function : Minimize Volume
Response Summary :
Number of volume responses : 1
Number of displacement responses : 1
Number of stress responses : 8
Static Subcase Summary :
Subcase ID SPC ID FORCE ID
1 1 3
Design Parameters Summary :
Total # of user-defined sizing design variables : 4
Total # of user-defined design variables : 4
Optimization Parameters Summary :
Maximum Number of Iterations : 30
Convergence Tolerance : 5.0000E-03
Step Size (Sizing) : 0.5000
Run Type : Sizing Optimization
Sizing Optimization Summary :
DESVAR Label Lower Design Upper
ID Bound Variable Bound
1 high 9.000E+01 1.000E+02 1.100E+02
2 wide 4.500E+01 5.000E+01 5.500E+01
3 th1 5.000E+00 1.000E+01 1.500E+01
4 th2 1.500E+01 2.000E+01 3.000E+01
Restart from previous solution : No
Scratch file directory : ./
Free space: 12021 MB
Number of CPU processors : 1
MEMORY ESTIMATION INFORMATION :
Solver Type is: Sparse-Matrix Solver
Direct Method
Current Memory (RAM) : 32 MB
Estimated Minimum Memory (RAM) for Out of Core Solution : 3 MB
Recommended Memory (RAM) for Out of Core Solution : 3 MB
Recommended Memory (RAM) for In-Core Solution : 3 MB
(Note: The Minimum Memory Requirement is limited by Sensitivity Module.)
DISK SPACE ESTIMATION INFORMATION :
Estimated Disk Space for Output Data Files : 4 MB
Estimated Scratch Disk Space for In-Core Solution : 5 MB
Estimated Scratch Disk Space for Out of Core Solution : 5 MB
BEGINNING OPTIMIZATION SOLUTION ....
OPTIMIZATION HISTORY INFORMATION :
ITERATION 0
*** WARNING # 1955
Static Loadcase 1 has zero static force vector.
This typically produces zero solution and zero compliance.
(Scratch disk space usage for starting iteration = 5 MB)
WARNING: A constrained DOF is used as a response.
The value will always be specified by the SPC data.
***** INTERNAL PROGRAMMING ERROR *****
in file "barstress.F", at location # 96
ioerr(1) = 5
**** ABORTING RUN DUE TO AN INTERNAL ERROR ****
RADIOSS/OptiStruct error termination report:
RAM: 32 MB total, 1 MB used.
Data arrays: 272 total, 177 allocated.
DATA SET size 1 MB, ram_disk 1 MB
DATASET USAGE: ndirs: 1, nfiles 1, nsets: 10, nblocks: 10, mode: 8
DIR: 0, size 160.0[KB], path "F:/0507/" num_files 1
OptiStruct traceback info at: 05/07/12 20:01:51
Trace point: 1015
CPU times[sec]: user 0.063, system 0.047, Wall clock 0.109
Command line arguments:
F:/0507/0507.fem
-exec=OS
File stats with output file root: 0507
Work directory: "./" Free size 12.0 GB
36090 0507.fem
1767 0507.out
61 0507.stat
0 0507_3716_00.scr
2504 0507.3716_00st.scr
2632 0507.3716_01fm.scr
Work directory: "F:/0507/" Free size 12.0 GB
36090 0507.fem
1767 0507.out
61 0507.stat
0 0507_3716_00.scr
