我建了一个长方体和柔性体设置成接触,在长方体上加载力通过接触面传递面力,在仿真时出现错误,请教坛里的高手指点一下,先谢谢!
WARNING: The number of edges does not match the number of triangles.
The shell may not be water tight.
If the shell is from a coarsened Flexible Body,
it may experience difficulty when used in a CONTACT.
ERROR:
Static equilibrium analysis has not been successful.
The maximum number of iterations 25, has been reached.
For the last attempted iteration:
The equation with the largest error was yyzj423.block Comp = 1 Error = 1530.033533
The variable receiving the largest increment was yyzj423.block Comp = 4 Delta = 1530.033533.
ERROR: Simulation failure detected.
