查看: 146|回复: 10
[OptiStruct] 做静力分析时出现以下错误#1237,求高手解决,谢谢啊
发表于 2012-5-23 10:15:44 | 显示全部楼层 |阅读模式 来自 福建福州
**                          OptiStruct 10.0                           **
**                  Design and Optimization Software                  **
**                   from Altair Engineering, Inc.                    **
**     Windows XP Professional  SP3 (Build 2600)  WWW-4B46AD9643E     **
**         2 CPU:  Pentium(R) Dual-Core CPU  T4300  @ 2.10GHz         **
**                        CPU speed  2100 MHz                         **
**                     978 MB RAM,  3935 MB swap                      **
** Build tag: 0466938_5333O00_Ci3242M-000      14000                  **
**  COPYRIGHT (C) 1996-2009                 Altair Engineering, Inc.  **
** All Rights Reserved.  Copyright notice does not imply publication. **
** Contains trade secrets of Altair Engineering, Inc.                 **
** Decompilation or disassembly of this software strictly prohibited. **
*** OptiStruct defaults set from:
   install config file: D:\Hyperworks10/hwsolvers/hwsolver.cfg
NOTE # 1929
Created RAM scratch area: total size 200 MB.
*** ERROR # 1237 ***
CQUAD4 element number 8039 references
a missing or invalid property number 3.
CQUAD4 element number 8045 references
CQUAD4 element number 8048 references
CQUAD4 element number 8049 references
CQUAD4 element number 8050 references
CQUAD4 element number 8051 references
CQUAD4 element number 9900 references
CQUAD4 element number 9901 references
CQUAD4 element number 9902 references
CQUAD4 element number 9903 references
CQUAD4 element number 9904 references
CQUAD4 element number 9905 references
CQUAD4 element number 9906 references
CQUAD4 element number 9907 references
CQUAD4 element number 9908 references
CQUAD4 element number 9909 references
CQUAD4 element number 9910 references
CQUAD4 element number 9911 references
CQUAD4 element number 9912 references
*** More of ERROR messages # 1237 were suppressed...
*** ERROR # 14 ***
         34 errors found in the input data.
RESOURCE USAGE INFORMATION
MAXIMUM MEMORY USED                                       211 MB
   THIS INCLUDES    200 MB RAMDISK AREA ALLOCATED IN MEMORY
MAXIMUM DISK SPACE USED                                     0 MB
COMPUTE TIME INFORMATION
EXECUTION STARTED                         Sun May 20 14:23:03 2012
EXECUTION COMPLETED                       Sun May 20 14:23:03 2012
ELAPSED TIME                                         00:00:00
CPU TIME                                             00:00:00
*** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
                        ***** END OF REPORT *****
For Useful OptiStruct Tips and Tricks, go to the URL:
http://www.altairhyperworks.com/tips.aspx
Following error/warning messages appeared too many times
and were suppressed:
    1237
Total of 15 repeat error message(s) were suppressed.
To see more messages use "MSGLMT" control card in the data or config file.
There were 34 error messages during input processing.
  The first message is repeated below:
发表于 2012-5-23 13:10:14 | 显示全部楼层 来自 上海
CQUAD4单元应该赋予PSHELL属性,而不是PSOLID
 楼主| 发表于 2012-5-23 13:36:22 | 显示全部楼层 来自 福建福州
我之前有做过PSHELL属性的,但是也是不行的。所以一直很纳闷。能不能加Q详聊嘛?我的QQ151275773.
发表于 2012-5-23 14:39:37 | 显示全部楼层 来自 上海
把PSHELL的.fem文件传上来吧
 楼主| 发表于 2012-5-23 15:56:51 | 显示全部楼层 来自 福建福州
zkong 发表于 2012-5-23 14:39
把PSHELL的.fem文件传上来吧
你说的那个文件就是里面这个?
发表于 2012-5-23 17:59:09 | 显示全部楼层 来自 上海
zds23816380 发表于 2012-5-23 15:56
你说的那个文件就是里面这个?
CHEXA element number 1043 references a missing property ID 5
or uses property of incorrect type for this element type.
CHEXA为实体单元,应该引用PSOLID, 而不是PSHELL 5
发表于 2012-5-23 22:37:29 | 显示全部楼层 来自 法国
or uses prop ...
我也碰到同样的问题,我引用PSOLID,但同样是error#1237,请问什么问题?附上.fem
 楼主| 发表于 2012-5-24 00:12:19 | 显示全部楼层 来自 福建福州
or uses prop ...
我对整个物体划分二维网格时,按照上面来操作就可以操作成功。划分三维网格就不可以。
 楼主| 发表于 2012-5-24 00:17:10 | 显示全部楼层 来自 福建福州
zds23816380 发表于 2012-5-24 00:12
我对整个物体划分二维网格时,按照上面来操作就可以操作成功。划分三维网格就不可以。 ...
您能不能把我修改下啊?看哪里错误了?
发表于 2012-6-30 15:29:04 | 显示全部楼层 来自 安徽合肥
我没看你的文件我的8.0打不开   我感觉你是不是用了solidmap划分六面体 但是你忘了删除你的二维网格
我猜的  不是勿怪
发表于 2012-7-6 17:06:12 | 显示全部楼层 来自 上海长宁区
单元类型附的不对  二维单元只能附shell   三维单元 附solid
GMT+8, 2024-10-6 21:20 , Processed in 0.038922 second(s), 11 queries , Gzip On, MemCache On.
