查看: 143|回复: 11
[OptiStruct] 做形状优化时候报错
发表于 2012-5-25 10:47:31 | 显示全部楼层 |阅读模式 来自 辽宁
做一个freeshap的优化,check的时候可以过去,计算的过程中迭代几步就报错了,请给位朋友帮看看,非常感谢啊!!!
out文件如下:
**                          OptiStruct 11.0                           **
**                  Design and Optimization Software                  **
**                   from Altair Engineering, Inc.                    **
**   Windows XP x64 Professional  SP1 (Build 3790)  ZYYJ-YF-YH-WYW    **
**           4 CPU:  Intel(R) Xeon(R) CPU  W3520  @ 2.67GHz           **
**                        CPU speed  2650 MHz                         **
**                     4095 MB RAM,  4095 MB swap                     **
** Build tag: 0569254_5333110_Ci32RH11M:61051-000  4000               **
**  COPYRIGHT (C) 1996-2011                 Altair Engineering, Inc.  **
** All Rights Reserved.  Copyright notice does not imply publication. **
**         Contains trade secrets of Altair Engineering, Inc.         **
** Decompilation or disassembly of this software strictly prohibited. **
*** OptiStruct defaults set from:
   install config file: C:\Program Files (x86)\Altair\11.0/hwsolvers/hwsolver.cfg.
1 PARAM(s) were set:
    CHECKEL ,NO
*** WARNING # 1265
PSHELL 2 has thickness 0.001 or less and bending properties
defined. This can lead to matrix singularities, causing message 153.
If this element is intended to be only a membrane element, please leave
MID2 and MID3 blank on the PSHELL data.
   Detected while reading line 480237 from file
     D:/WORK2012/A3/freeshape/00001.fem:
  "PSHELL         2       10.001          1               1        0.0"
*** WARNING 1932:    PMASS    3 is not referenced.
*** INFORMATION #  742
The dependent rotational d.o.f. of this rigid element is removed.
     RBE2 element id =    1774515
independent grid id =     306780
a dependent grid id =     222007
This is because there is no need to constrain the rotational d.o.f. of
any of the dependent grids.
*** INFORMATION #  743
The total number of rigid elements, whose rotational dependent d.o.f.
are removed because there is no need to constrain those d.o.f., is         1
NOTE #  1847
AUTOMATIC SCREENING is activated.
Use "DSCREEN,AUTO,OFF" to turn off this effect.
OPTIMIZATION FILE AND PARAMETER INFORMATION :
  FEM model file               : D:/WORK2012/A3/freeshape/00001.fem
  Output files prefix          : D:/WORK2012/A3/freeshape/00001
  Model read from files:
FINITE ELEMENT MODEL DATA INFORMATION :
  Total # of Grids (Structural)        :    89677
  Total # of Elements                  :   350842
  Total # of Rigid Elements            :        1
  Total # of Rigid Element Constraints :     3315
  Total # of Degrees of Freedom        :   278205
  Total # of Non-zero Stiffness Terms  :  5492586
  Element Type Information
   CTETRA   Elements   :   344714
   CONM2    Elements   :        1
   CTRIA3   Elements   :     6127
  Load and Boundary Information
   FORCE Sets        :        4
   SPC   Sets        :        1
  Material and Property Information
   PSOLID Cards      :        1
   PMASS  Cards      :        1
   PSHELL Cards      :        1
   MAT1   Cards      :        1
OPTIMIZATION PROBLEM PARAMETERS :
Objective Function  : Minimize Weighted Compliance
Response Summary :
Number of compliance responses        :         4
Number of equation responses          :         1
   Static Subcase Summary :
   Subcase ID    SPC ID   LOAD ID   Weight = w(i)
          1            5         1           1.000
          2            5         2           1.000
          3            5         3           1.000
          4            5         4           1.000
   Design Parameters Summary :
   Total # of free-shape cards                     :        1
   Optimization Parameters Summary :
   Maximum Number of Iterations    :       30
   Convergence Tolerance           :   5.0000E-03
   Step Size (Shape)               :   0.2000
   Run Type                        :   Free-Shape Optimization
   Restart from previous solution  :   No
   Scratch file directory          : ./
                                     Free space:  31767 MB
   Number of CPU processors        :         1
MEMORY ESTIMATION INFORMATION :
Solver Type is:  Sparse-Matrix Solver
                  Direct Method
Current Memory (RAM)                                    :     261 MB
Estimated Minimum Memory (RAM) for Out of Core Solution :     261 MB
Recommended Memory (RAM) for Out of Core Solution       :     261 MB
Recommended Memory (RAM) for In-Core Solution           :    1259 MB
Recommended Number of Nodes for OS SPMD Parallel Run    :       1
(Note: The Minimum Memory Requirement is limited by Output Module.)
DISK SPACE ESTIMATION INFORMATION :
Estimated Disk Space for Output Data Files              :    1565 MB
Estimated Scratch Disk Space for In-Core Solution       :     225 MB
Estimated Scratch Disk Space for Out of Core Solution   :    1534 MB
BEGINNING OPTIMIZATION SOLUTION ....
OPTIMIZATION HISTORY INFORMATION :
ITERATION   0
          Auto-SPC d. o. f.s for loadcase        1
          Number of Auto-SPC d. o. f.s  =     3315
            Grid No.       Component
              222007             4 5 6
              222008             4 5 6
              222009             4 5 6
              222010             4 5 6
              222011             4 5 6
              222012             4 5 6
              222013             4 5 6
              222014             4 5 6
              222015             4 5 6
              222016             4 5 6
              222017             4 5 6
              222018             4 5 6
              222019             4 5 6
              222020             4 5 6
              222021             4 5 6
              222022             4 5 6
              222023             4 5 6
              222024             4 5 6
              222025             4 5 6
              222026             4 5 6
              222027             4 5 6
              222028             4 5 6
              222029             4 5 6
              222030             4 5 6
              222031             4 5 6
              222032             4 5 6
              222033             4 5 6
              222034             4 5 6
              222035             4 5 6
              222036             4 5 6
              222037             4 5 6
              222038             4 5 6
              222039             4 5 6
              222040             4 5 6
            By default, Auto-SPC printing is limited to 100 dofs.
(Scratch disk space usage for starting iteration = 1134 MB)
(Running out-of-core solution)
Objective Function (Minimize WCOMP) =  2.92171E-02
Maximum Constraint Violation %      =  0.00000E+00
Volume                              =  2.41482E-02   Mass     =  1.73868E+02
Subcase  Weight     Compliance                            Weight*Comp.
       1  1.000E+00  2.646300E-02                          2.646300E-02
       2  1.000E+00  1.265212E-03                          1.265212E-03
       3  1.000E+00  1.809356E-07                          1.809356E-07
       4  1.000E+00  1.488681E-03                          1.488681E-03
Sum of Weight*Compliance                                   2.921708E-02
                           RETAINED RESPONSES TABLE
Response Type  Response    Subcase Grid/     DOF/   Response     Objective    Viol.
User-ID          Label     /RANDPS Element/  Comp     Value      Reference/     %
                           +Frqncy MID/PID/  /Reg                Constraint
                                   Mode No.                        Bound
       1 WCOMP wcomp            --       --    --   2.922E-02 MIN
ITERATION   1
Objective Function (Minimize WCOMP) =  2.88334E-02   % change =        -1.31
Volume                              =  2.41740E-02   Mass     =  1.74054E+02
       1  1.000E+00  2.612493E-02                          2.612493E-02
       2  1.000E+00  1.245180E-03                          1.245180E-03
       3  1.000E+00  1.795414E-07                          1.795414E-07
       4  1.000E+00  1.463066E-03                          1.463066E-03
Sum of Weight*Compliance                                   2.883336E-02
                                   Mode No.                        Bound
       1 WCOMP wcomp            --       --    --   2.883E-02 MIN
ITERATION   2
Objective Function (Minimize WCOMP) =  2.85516E-02   % change =        -0.98
Volume                              =  2.41926E-02   Mass     =  1.74188E+02
       1  1.000E+00  2.587615E-02                          2.587615E-02
       2  1.000E+00  1.231201E-03                          1.231201E-03
       3  1.000E+00  1.790000E-07                          1.790000E-07
       4  1.000E+00  1.444060E-03                          1.444060E-03
Sum of Weight*Compliance                                   2.855159E-02
                                   Mode No.                        Bound
       1 WCOMP wcomp            --       --    --   2.855E-02 MIN
ITERATION   3
*** ERROR #   15 ***
CTETRA          element    1391820 is distorted (zero or negative Jacobian).
This error occurs in module "asmbdrv".
RESOURCE USAGE INFORMATION
MAXIMUM MEMORY USED                                       261 MB
MAXIMUM DISK SPACE USED                                  2699 MB
COMPUTE TIME INFORMATION
EXECUTION STARTED                         Fri May 25 10:15:42 2012
EXECUTION COMPLETED                       Fri May 25 10:20:43 2012
ELAPSED TIME                                         00:05:00
CPU TIME                                             00:04:17
*** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
                        ***** END OF REPORT *****
For Useful OptiStruct Tips and Tricks, go to the URL:
http://www.altairhyperworks.com/tips.aspx
RADIOSS/OptiStruct error termination report printed to file
"00001.stat".
PROGRAM STOPPED DUE TO ERROR.
A fatal error has occurred during computations:
  *** ERROR #   15 ***
发表于 2012-5-25 11:12:05 | 显示全部楼层 来自 上海
经过几个迭代变形后,网格质量太差。 可以把最终的结果重新划分网格,改进网格质量后重新优化。
发表于 2012-5-25 11:12:56 | 显示全部楼层 来自 上海
方便的话,把模型贴上来,我可以帮你看看。
发表于 2012-5-25 18:39:08 | 显示全部楼层 来自 重庆
zkong 发表于 2012-5-25 11:12
经过几个迭代变形后,网格质量太差。 可以把最终的结果重新划分网格,改进网格质量后重新优化。 ...
您好~~~你的意思是把几何导出来,再划分网格么?
发表于 2012-5-27 20:42:37 | 显示全部楼层 来自 上海
apply result 把优化的结果(新的节点坐标)施加到网格上,就可以得到新的网格。  网格重新划分不需要几何。
 楼主| 发表于 2012-5-28 14:38:41 | 显示全部楼层 来自 辽宁
谢谢Zkong版主
您说的这个办法具体如何操作呢?
出错的模型我变量选择的是三个面(一起选择)上的接点,如果三个面单独作为变量计算都没有问题,怎么回事呢?
模型还是不太方便上传啊!非常感谢!
 楼主| 发表于 2012-5-30 09:04:14 | 显示全部楼层 来自 辽宁
zkong 发表于 2012-5-27 20:42
apply result 把优化的结果(新的节点坐标)施加到网格上,就可以得到新的网格。  网格重新划分不需要几何。 ...
具体是怎么操作呢,求版主解答  谢谢
 楼主| 发表于 2012-5-30 09:22:50 | 显示全部楼层 来自 辽宁
模型已经传上来了 麻烦有时间帮看看吧  非常感谢了
发表于 2012-5-30 11:58:30 | 显示全部楼层 来自 上海
其实你的问题是,形状优化后怎么得到优化的设计。
两种方式得到:
方式1:
HyperMesh -> post -> apply result ->
"Simulation" 选择优化最后一个迭代步的结果
"Data type" 选择 "shape change",
"Nodes" 选择所有节点 "all",
点"apply"按钮,就会用形状优化的结果更新节点坐标,然后remesh就是用HyperMesh的问题了。
方式2:
在HyperMesh打开原模型的情况下,导入.grid 或者_err.grid文件, 覆盖原模型的坐标(选中FE overwrite, 见下图)。*.grid和 *_err.grid的区别是,.grid存的是最后一个通过单元质量检查的迭代步的坐标,_err.grid存的是最后坏掉的坐标。 根据需要,你可以选择其中任意一个作为remesh的起点。
 楼主| 发表于 2012-5-30 14:39:58 | 显示全部楼层 来自 辽宁
两种方式得到:
谢谢版主的解答,还有一个问题,我利用3D>tetra mesh>volume tetra的办法画的四面体网格,如何进行remesh呢?谢谢!
发表于 2012-5-30 14:47:59 | 显示全部楼层 来自 上海
wangyuewu 发表于 2012-5-30 14:39
谢谢版主的解答,还有一个问题,我利用3D>tetra mesh>volume tetra的办法画的四面体网格,如何进行remesh ...
抱歉,我HyperMesh用得很烂,这个问题可以到HyperMesh版去问。
 楼主| 发表于 2012-6-1 10:26:30 | 显示全部楼层 来自 辽宁
谢谢斑竹了
GMT+8, 2024-10-5 02:23 , Processed in 0.041951 second(s), 11 queries , Gzip On, MemCache On.
