查看: 72|回复: 2
现在火烧眉毛了,跪求懂热结构耦合命令流的给与指导
发表于 2012-6-5 10:58:40 | 显示全部楼层 |阅读模式 来自 山东青岛
温度场可以运行,应力场不行不收敛,做的事焊接,大恩大德毕生难忘。。。。。
 楼主| 发表于 2012-6-5 10:59:34 | 显示全部楼层 来自 山东青岛
自己顶一个
发表于 2012-6-25 14:28:18 | 显示全部楼层 来自 河北石家庄
/filename,Themal
/title,themal_analysis  !标题
/PREP7                  !前处理
!定义单元类型
ET,1,SOLID70
!设置材料属性
   !材料1为混凝土
MP,KXX,1,280.43
MP,C,1,0.976
MP,DENS,1,2450
MAT,1
   !材料2为基础土
MP,KXX,2,287.53
MP,C,2,1.45
MP,DENS,2,1670
MAT,2
!输入参数
   !输入外界气温表
*DIM,qiwen,TABLE,21,1,1,TIME, , ,  !外界气温表名为qiwen
QIWEN(1,0,1) = 0
QIWEN(1,1,1) = 16.5
QIWEN(2,0,1) = 0.5
QIWEN(2,1,1) = 21.4
QIWEN(3,0,1) = 1
QIWEN(3,1,1) = 18
QIWEN(4,0,1) = 1.5
QIWEN(4,1,1) = 26.2
QIWEN(5,0,1) = 2
QIWEN(5,1,1) = 18.3
QIWEN(6,0,1) = 2.5
QIWEN(6,1,1) = 28.6
QIWEN(7,0,1) = 3
QIWEN(7,1,1) = 15
QIWEN(8,0,1) = 3.5
QIWEN(8,1,1) = 33
QIWEN(9,0,1) = 4
QIWEN(9,1,1) = 16.7
QIWEN(10,0,1) = 4.5
QIWEN(10,1,1) = 29
QIWEN(11,0,1) = 5
QIWEN(11,1,1) = 16.5
QIWEN(12,0,1) = 5.5
QIWEN(12,1,1) = 26
QIWEN(13,0,1) = 6
QIWEN(13,1,1) = 11.6
QIWEN(14,0,1) = 6.5
QIWEN(14,1,1) = 32.6
QIWEN(15,0,1) = 7
QIWEN(15,1,1) = 16
QIWEN(16,0,1) = 7.5
QIWEN(16,1,1) = 34.2
QIWEN(17,0,1) = 8
QIWEN(17,1,1) = 11.6
QIWEN(18,0,1) = 8.5
QIWEN(18,1,1) = 30.8
QIWEN(19,0,1) = 9
QIWEN(19,1,1) = 15.4
QIWEN(20,0,1) = 9.5
QIWEN(20,1,1) = 31
QIWEN(21,0,1) = 10
QIWEN(21,1,1) = 13
   !输入热生成率函数
*SET,_FNCNAME,'heats'
*DIM,%_FNCNAME%,TABLE,6,16,1
   ! Begin of equation: 2450*0.7462*227.2246*0.13*exp(-0.7426*{TIME})
%_FNCNAME%(0,0,1)= 0.0, -999
%_FNCNAME%(2,0,1)= 0.0
%_FNCNAME%(3,0,1)= 0.0
%_FNCNAME%(4,0,1)= 0.0
%_FNCNAME%(5,0,1)= 0.0
%_FNCNAME%(6,0,1)= 0.0
%_FNCNAME%(0,1,1)= 1.0, -1, 0, 2450, 0, 0, 0
%_FNCNAME%(0,2,1)= 0.0, -2, 0, 0.7462, 0, 0, -1
%_FNCNAME%(0,3,1)=   1, -3, 0, 1, -1, 3, -2
%_FNCNAME%(0,4,1)= 0.0, -1, 0, 227.2246, 0, 0, -3
%_FNCNAME%(0,5,1)= 0.0, -2, 0, 1, -3, 3, -1
%_FNCNAME%(0,6,1)= 0.0, -1, 0, 0.13, 0, 0, -2
%_FNCNAME%(0,7,1)= 0.0, -3, 0, 1, -2, 3, -1
%_FNCNAME%(0,8,1)= 0.0, -1, 0, 0, 0, 0, 0
%_FNCNAME%(0,9,1)= 0.0, -2, 0, 1, 0, 0, -1
%_FNCNAME%(0,10,1)= 0.0, -4, 0, 1, -1, 2, -2
%_FNCNAME%(0,11,1)= 0.0, -1, 0, 0.7426, 0, 0, -4
%_FNCNAME%(0,12,1)= 0.0, -2, 0, 1, -4, 3, -1
%_FNCNAME%(0,13,1)= 0.0, -1, 0, 1, -2, 3, 1
%_FNCNAME%(0,14,1)= 0.0, -1, 7, 1, -1, 0, 0
%_FNCNAME%(0,15,1)= 0.0, -2, 0, 1, -3, 3, -1
%_FNCNAME%(0,16,1)= 0.0, 99, 0, 1, -2, 0, 0
   ! End of equation: 2450*0.7462*227.2246*0.13*exp(-0.7426*{TIME})
!创建几何体
BLOCK,,5,,7.5,,2.4          !创建混凝土块
BLOCK,,20,,20,-10,0         !创建基础土体
KWPLAN,-1,4,3,6             !定位工作坐标系1
VSBW,ALL                    !分割体1
KWPLAN,-1,3,1,7             !定位工作坐标系2
VSBW,ALL                    !分割体2
VGLUE,ALL                   !GLUE所有体元素
NUMMRG,ALL                  !合并所有重复元素
NUMCMP, ALL                 !压缩所有元素的编号
CSYS,0                      !返回全局坐标系
!进行网格划分
      !划分混凝土体
VSEL,S,,,1,1,1              !选择混凝土体
VATT,1,,1,0                 !指定混凝土材料
ALLSEL
VSEL,U,,,1,1,1              !选择基础土体
VATT,2,,1,0                 !指定基础土体材料
ALLSEL                      !选择所有料
LSEL,S,,,5,5,1              !选择混凝土短边
LESIZE,ALL,,,5              !混凝土短边划分为5
LSEL,S,,,8,8,1              !选择混凝土长边
LESIZE,ALL,,,10             !混凝土短边划分为10
LSEL,S,,,9,9,1              !选择混凝土高
LESIZE,ALL,,,6              !混凝土高划分为6
      !划分基础土体
LSEL,S,,,1,1,1              !选择混凝土高
LESIZE,ALL,,,10
LSEL,S,,,4,4,1
LESIZE,ALL,,,5
LSEL,S,,,15,15,1
LSEL,A,,,13,13,1
LSEL,A,,,24,39,15
LSEL,A,,,20,30,10
LSEL,A,,,37,40,3
LESIZE,ALL,,,6
LSEL,S,,,2,2,1
LESIZE,ALL,,,5
LSEL,S,,,3,3,1
LESIZE,ALL,,,10
ALLSEL
VMESH,ALL                   !映射划分网格
FINISH
/SOLU                       !进入求解器
ANTYPE,4                    !选择瞬态求解
TRNOPT,FULL
LUMPM,0
ESEL,S,MAT,,1               !选择混凝土体的所有结点
NSLE,S
IC,all,TEMP,23.6            !混凝土的浇筑温度为23.6
ESEL,S,MAT,,2               !选择基础土体的所有结点
NSLE,S
IC,all,TEMP,16              !基础的初始温度为16
ALLSEL
SFA,4,1,CONV,616.32, %QIWEN%  !四周木模对流系数616.32
SFA,6,1,CONV,616.32, %QIWEN%
SFA,2,1,CONV,2054.4, %QIWEN%  !上面裸露对流系数616.32
BFV,1,HGEN, %HEATS%           !输入热生成率heats
ALLSE                         !选择所有
TRNOPT,FULL                   !设置计算方法
*DO,DAY,0.5,10,0.5            !设置循环计算
TIME,DAY                      !设置荷载步时间
AUTOTS,0                      !关闭自动时间步长
KBC,0                         !设置阶梯荷载步
TSRES,ERASE                   !Defines an array of keytimes at which the time-stepping strategy changes
OUTRES,ALL,ALL                !输出所有项
SOLVE                         !开始计算
*ENDDO                        !终止循环计算
!结构应力分析
/PREP7                                !前处理
ETCHG,TTS                             !转换热分析单元为结构单元
  !输入参数
!定义变化弹模EXX
*DIM,EXX,ARRAY,20
EXX(1,1,1) = 0.87e10
EXX(2,1,1) = 1.05e10
EXX(3,1,1) = 1.17e10
EXX(4,1,1) = 1.26e10
EXX(5,1,1) = 1.33e10
EXX(6,1,1) = 1.39e10
EXX(7,1,1) = 1.44e10
EXX(8,1,1) = 1.48e10
EXX(9,1,1) = 1.52e10
EXX(10,1,1) = 1.56e10
EXX(11,1,1) = 1.59e10
EXX(12,1,1) = 1.61e10
EXX(13,1,1) = 1.64e10
EXX(14,1,1) = 1.67e10
EXX(15,1,1) = 1.69e10
EXX(16,1,1) = 1.71e10
EXX(17,1,1) = 1.73e10
EXX(18,1,1) = 1.75e10
EXX(19,1,1) = 1.77e10
EXX(20,1,1) = 1.79e10
!定义20种材料每0.5小时一种材料来反映弹模的改变
*DO,I,1,20,1
    MP,DENS,I,2450        !混凝土 密度为2450
    MP,EX,I,EXX(I)        !混凝土 弹模为EXX(I)
    MP,PRXY,I,0.167       !混凝土 泊松比为0.167
    MP,ALPX,I,0.75E-5     !混凝土 热膨胀系数为0.75e-5
    MP,REFT,I,15          !定义参考温度
*ENDDO
VCLEAR, 2, 5, 1           !清除基础土体网格
VDELE, 2, 5, 1, 1         !删除基础土体
ALLSEL                    !选择选择所有
/SOLU                     !进入求解器
NROPT,FULL                !Specifies the Newton-Raphson options in a full transient analysis
NLGEOM,ON                 !考虑大变形的影响
ASEL,S,,,1,1,1            !选择面1
NSLA,S,1                  !选择面1上的结点
D,all,ALL                 !加基础全约束
ALLSEL                    !选择选择所有
DA,3,SYMM                 !加对称约束
DA,5,SYMM                 !加对称约束
I=1
*DO,DAY,0.5,10,0.5
    ESEL, S, MAT, , I, I,1                    !选择混凝土材料号为I的元素
    ACEL,0,0,-9.8,                            !GRAVITY LOAD 施加重力荷载加速度
    LDREAD,TEMP,,,DAY, ,'themal','rth',' '    !TEMP LOAD Reads results from the results file and applies them as loads.
    TIME,DAY
    AUTOTS,0
    KBC,0                                     !设置阶梯荷载步
    OUTRES,ALL,ALL,                           !输出所有的结果
    SOLVE                                     !计算
    I=I+1
    *IF,I,LE,20,THEN
        MPCHG,I,ALL
    *ENDIF
*ENDDO
GMT+8, 2024-9-18 01:15 , Processed in 0.029579 second(s), 11 queries , Gzip On, MemCache On.
