- 2011-11-18
各位高手,我正在做一平板中含一边裂纹的热力耦合有限元分析,计算,温度场,位移场,热应力场,板的上边界温度降低10,下边界保持为原来的0,固定下边位移,请问1 MATLAB边界条件中,温度边界条件和位移边界条件能写在一块么?
2,计算热应力应变的温差应为多少?
下面是我的MATLAB 边界条件代码
function [freeDOF] = boundaryCond(DOF)
% This function defines the boundary conditions to be applied. % case 1
global BC CONNEC DOMAIN NODES
nXElem = DOMAIN(1); % Number of elements in the x-direction
nYElem = DOMAIN(2); % Number of elements in the y-direction
fixedTDOF = NaN(1,(DOMAIN(1)+1)*(DOMAIN(2)+1)); % Initialize vector of fixed DOFs
fixedDOF = NaN(1,(DOMAIN(1)+1)*(DOMAIN(2)+1));
TDOF = 1*max(max(NODES));
index = 1;
switch BC
case 1 % Fix the temperature in bottom and top edge of the domain
for i = 1:nXElem+1;
if i == 1;
fixedTDOF(index) = node; % Fix temperature in bottom edge of the domain
fixedTDOFvalue=0; % bcval2 = 0;
index = index+1;
node = node+1;
elseif node == (nYElem)*(nXElem+1)+1;
fixedTDOF(index) = node; % bcval1 = -10;
fixedTDOFvalue=-10;
index = index+1;
node = node+1;
end
end
case 2 % Boundary conditions for an edge crack
fixedDOF = [2*(nXElem+1)-1 2*(nXElem+1) 2*(nXElem+1)*(nYElem+1)-1];
case 3 % Fix the bottom edge of the domain
for i = 1:nXElem+1
if i == 1
fixedDOF(indexindex+1)) = [2*i-1 2*i]; % Fix displacement in x and y-direction
index = index+2;
else
fixedDOF(index) = 2*i; % Fix displacement in y-direction
index = index+1;
end
end
case 4 % Boundary conditions for first quadrant
node = 1;
for i = 1:nYElem+1 % Rollers left edge
fixedDOF(index) = 2*node-1;
index = index+1;
node = node+nXElem+1;
end
for i = 1:nXElem+1
index = index+1;
end
end
fixedTDOF(:,isnan(fixedTDOF(1,)) = [];
freeTDOF = setdiff(1:TDOF,fixedTDOF);
fixedDOF(:,isnan(fixedDOF(1,)) = [];
freeDOF = setdiff(1OF,fixedDOF); % Solve for the free DOF
