- 2011-8-20
笔者采用自编的梁单元单轴本构模型计算轴向受压梁,计算中出现如下报错:
Abaqus/Explicit 6.11-1 DATE 05-Jul-2012 TIME 17:18:37
PREPROCESSOR WARNING MESSAGES
***WARNING: There are 1 warning messages in the data (.dat) file. Please
check the data file for possible errors in the input file.
USER SUBROUTINE VUMAT
***WARNING: A material defined in user subroutine VUMAT must be defined as
purely elastic (using the initial elastic modulus) at the
beginning of the analysis (stepTime=0). This is an informative
message. It does not necessarily indicate that user subroutine
VUMAT is incorrectly defined.
MODEL INFORMATION (IN GLOBAL X-Y COORDINATES)
Total mass (unscaled) in model = 540.00
Center of mass of model (based on unscaled mass) = ( 0.000000E+00, 6.750000E-01, 0.000000E+00)
Moments of Inertia :
About Center of Mass About Origin
I(XX) 9.085275E+01 3.368903E+02
I(YY) 1.440000E+01 1.440000E+01
I(ZZ) 9.085275E+01 3.368903E+02
I(XY) 0.000000E+00 0.000000E+00
I(YZ) 0.000000E+00 0.000000E+00
I(ZX) -2.286989E-17 -2.286989E-17
STABLE TIME INCREMENT INFORMATION
The stable time increment estimate for each element is based on
linearization about the initial state. The stable time increment estimates
do not account for mass scaling.
Initial time increment = 3.55067E-05
Statistics for all elements:
Mean = 3.55067E-05
Standard deviation = 0.0000
Most critical elements:
Element number Rank Time increment Increment ratio
(Instance name)
1 1 3.550669E-05 1.000000E+00
BEAM-1
3 2 3.550669E-05 1.000000E+00
BEAM-1
5 3 3.550669E-05 1.000000E+00
BEAM-1
6 4 3.550669E-05 1.000000E+00
BEAM-1
7 5 3.550669E-05 1.000000E+00
BEAM-1
9 6 3.550669E-05 1.000000E+00
BEAM-1
10 7 3.550669E-05 1.000000E+00
BEAM-1
2 8 3.550670E-05 9.999997E-01
BEAM-1
4 9 3.550670E-05 9.999997E-01
BEAM-1
8 10 3.550671E-05 9.999995E-01
BEAM-1
Instance name for the most critical element will be printed if the critical
element changes or at the beginning of a new page.
Abaqus/Explicit 6.11-1 DATE 05-Jul-2012 TIME 17:18:38
The double precision Abaqus/Explicit executable will be used in this analysis.
SOLUTION PROGRESS
STEP 1 ORIGIN 0.0000
Total memory used for step 1 is approximately 368.9 kilobytes.
Direct time incrementation control will be used.
Variable mass scaling factor at zero increment: 1.0000
***WARNING: The direct user control is used in the current analysis step. In
this case, Abaqus/Explicit will not check that the computed
response is stable during the step. Please check carefully the
energy history and other response variables to ensure that a valid
and stable response has been obtained.
STEP TOTAL CPU STABLE CRITICAL KINETIC TOTAL PERCENT
INCREMENT TIME TIME TIME INCREMENT ELEMENT ENERGY ENERGY CHNG MASS
0 0.000E+00 0.000E+00 00:00:00 1.000E-05 10 3.037E-03 3.037E-03 0.000E+00
INSTANCE WITH CRITICAL ELEMENT: BEAM-1
ODB Field Frame Number 0 of 1000 requested intervals at increment zero.
***ERROR: Floating Point Exception detected in increment 200. Job exiting.
200 2.000E-03 2.000E-03 00:00:00 1.000E-05 0 NaN NaN 0.000E+00
ODB Field Frame Number 1 of 1000 requested intervals at 2.000010E-03
Nodes involved in floating point error:
The following checklist may be helpful in diagnosing the error:
1. Check contact definitions for problems such as excessive initial
overclosure or unrealistic tied definition between contact pairs.
A vector plot of velocities or accelerations will usually help to
identify contact problems.
2. Check stiffness (elastic modulus) and mass (density) definitions for
consistent units and verify that the combination is reasonable.
3. Check for poor mesh definition.
4. Check the boundary conditions for an excessive loading rate. The
*DIAGNOSTICS, DEFORMATION SPEED CHECK=DETAIL option may be used to obtain
detailed diagnostics information.
5. Check the current status of the structure to see if it has
totally failed.
6. A dashpot or a very stiff spring may cause the analysis to go unstable.
The *DYNAMIC, DIRECT option may be used to control the time increment
directly.
***ERROR: The fatal error will generate a new field output in the last
increment. All variables applicable to the current procedure and
material type(s) will be written to the output database.
***ERROR: Floating Point Exception detected in increment 202. Job exiting.
202 2.010E-03 2.010E-03 00:00:00 1.000E-05 0 NaN NaN 0.000E+00
A special ODB Field Frame with all relevant variables was written at 2.010E-03
THE ANALYSIS HAS NOT BEEN COMPLETED
对于错误警告信息中Floating Point Exception这是什么意思?有什么可以解决的方法吗?
