*** WARNING *** CP = 145.250 TIME= 10:57:47
Brick element 9932 has a pair of opposite edges that are 77.08 degrees
away from being parallel. This exceeds the warning limit of 70
degrees.
*** WARNING *** CP = 145.266 TIME= 10:57:47
Brick element 13837 has a pair of opposite edges that are 73.74
degrees away from being parallel. This exceeds the warning limit of
70 degrees.
*** WARNING *** CP = 145.281 TIME= 10:57:47
Brick element 13838 has a pair of opposite edges that are 73.74
70 degrees.
*** WARNING *** CP = 145.312 TIME= 10:57:47
SOLID45 wedges are recommended only in regions of relatively low
stress gradients.
*** WARNING *** CP = 145.328 TIME= 10:57:48
Brick element 16421 has a pair of opposite edges that are 77.87
70 degrees.
*** WARNING *** CP = 145.344 TIME= 10:57:48
Brick element 16422 has a pair of opposite edges that are 77.87
70 degrees.
Brick element 16869 has a pair of opposite edges that are 72.41
70 degrees.
Brick element 16870 has a pair of opposite edges that are 72.41
70 degrees.
*** WARNING *** CP = 145.359 TIME= 10:57:48
Brick element 17209 has a pair of opposite edges that are 92.88
70 degrees.
*** WARNING *** CP = 145.375 TIME= 10:57:48
Brick element 17210 has a pair of opposite edges that are 92.88
70 degrees.
*** WARNING *** CP = 145.391 TIME= 10:57:48
Brick element 17593 has a pair of opposite edges that are 73.83
70 degrees.
*** WARNING *** CP = 145.406 TIME= 10:57:48
Brick element 17594 has a pair of opposite edges that are 73.83
70 degrees.
Brick element 18541 has a pair of opposite edges that are 73.74
70 degrees.
