查看: 121|回复: 1
[前处理] 地应力平衡cae_no_parts_input_file=ON加在什么位置?
发表于 2012-10-22 20:15:40 | 显示全部楼层 |阅读模式 来自 浙江杭州
在地应力平衡中
“在abaqus安装文件的环境变量文件中最后一行加入
cae_no_parts_input_file=ON”
是在什么位置加这句话?
 楼主| 发表于 2012-10-23 08:47:17 | 显示全部楼层 来自 浙江杭州
When you start an Abaqus/CAE session
To change the format of the input files generated by Abaqus/CAE, you can modify the cae_no_parts_input_file parameter in the Abaqus environment file (abaqus_v6.env) as follows:
If you use this method, the input file format cannot be changed during the Abaqus/CAE session. For additional information on defining environment file parameters, refer to the Abaqus Installation and Licensing Guide.
During an Abaqus/CAE session
There are two methods that you can use to change the format of the input files generated by Abaqus/CAE.
Select ModelModel Attributesmodel name for the model that you want to change, then toggle on Do not use parts and assemblies in input files.
Enter the following Abaqus Scripting Interface command into the command line interface at the bottom of the Abaqus/CAE main window:
mdb.models[modelName].setValues(noPartsInputFile=ON)
Note:  The command line interface is hidden by default, but it uses the same space that is occupied by the message area at the bottom of the main window. To access the command line interface, click  in the bottom left corner of the main window.
If you use either method, the changed input file format is a part of the model definition. When you exit the Abaqus/CAE session and return to the model database at a later time, the changed input file format is retained.
GMT+8, 2024-5-17 23:04 , Processed in 0.027263 second(s), 11 queries , Gzip On, MemCache On.
