附上命令流:
finish$/clear$/prep7
/title,the analsys of chishuihe bridge
et,1,95
et,2,8
mp,ex,1,3.6e10!!!!!!!!!!!混凝土材料特性
mp,prxy,1,0.2
mp,dens,1,2549
mp,ex,2,1.99e11!!!!!!!!!!!纵向钢束材料特性
mp,prxy,2,0.3
mp,dens,2,8005
mp,ex,3,1.99e11!!!!!!!!!!!竖向钢束材料特性
mp,prxy,3,0.3
mp,dens,3,8005
mp,ex,4,1.99e11!!!!!!!!!!!横向钢束材料特性
mp,prxy,4,0.3
mp,dens,4,8005
!纵向钢束特性
!单根直径15.2mm,标准强度1860MPA,单根张拉控制吨位195.3KN
areagjx=1.4e-4
* dim,gjarea,array,5
gjarea(1)=15*areagjx
gjarea(2)=19*areagjx
gjarea(3)=22*areagjx
gjarea(4)=25*areagjx
gjarea(5)=27*areagjx
F=195.5e3 !!!单根张拉控制吨位195.3KN
E=1.99e11 !!!钢绞线弹性模量
L=1 !!!每根钢筋单元的长度为1M
detL=F*L/(E*areagjx) !!!每根钢绞线单元的伸长量
istrn=detL/(detL+L) !!!每根钢绞线的拉应变
r,2,gjarea(1),istrn !!!定义各种钢束的实常数
r,3,gjarea(2),istrn
r,4,gjarea(3),istrn
r,5,gjarea(4),istrn
r,6,gjarea(5),istrn
!!!竖向及横向钢束特性
areagjx1=1.4e-4!!!!!单根钢束面积
* dim,gjarea2,array,3 !!!定义钢束面积为数组
gjarea2(1)=2*areagjx1
gjarea2(2)=3*areagjx1
gjarea2(3)=7*areagjx1
F1=182.3e3 !!!单根竖向张拉控制吨位182.3KN
L=1 !!!每根钢筋单元的长度为1M
detL=F1*L/(E*areagjx1) !!!每根钢绞线单元的伸长量
r,7,gjarea2(2),istrn !!!定义竖向钢束的实常数
F2=195.5e3 !!!单根横向张拉控制吨位195.5KN
L=1 !!!每根钢筋单元的长度为1M
detL=F2*L/(E*areagjx1) !!!每根钢绞线单元的伸长量
r,8,gjarea2(1),istrn !!!定义横向钢束的实常数
r,9,gjarea2(3),istrn
acel,,9.8 !!!定义重力加速度
k,1,-0.3
k,2,-2.95
k,3,-3.75
k,4,-6.925,
k,5,-6.925,-0.2
k,6,-3.75,-0.9
k,7,-2.95,-0.9
k,8,-0.3,-0.32
k,9,-3.75,-14
k,10,-2.95,-14
k,11,-2.95,-(11.2/(118**1.8))*((124-6)**1.8)-4.8
k,12,-3.75,-(11.2/(118**1.8))*((124-6)**1.8)-4.8
ksym,x,1,12,1,100
kgen,2,1,12,1,0,0,6,1000
kgen,2,101,112,1,0,0,6,1000
kgen,2,11,12,1,0,-(11.2/(118**1.8))*((124-8.5)**1.8)-4.8+16,8.5,2000
kgen,2,9,10,1,0,0.363,8.5,2000
kgen,2,11,12,1,0,-(11.2/(118**1.8))*((124-11)**1.8)-4.8+16,11,3000
kgen,2,9,10,1,0,0.72,11,3000
kgen,2,11,12,1,0,-(11.2/(118**1.8))*((124-13.5)**1.8)-4.8+16,13.5,4000
kgen,2,9,10,1,0,1.071,13.5,4000
kgen,2,11,12,1,0,-(11.2/(118**1.8))*((124-16)**1.8)-4.8+16,16,5000
kgen,2,9,10,1,0,1.414,16,5000
kgen,2,11,12,1,0,-(11.2/(118**1.8))*((124-18.5)**1.8)-4.8+16,18.5,6000
kgen,2,9,10,1,0,1.752,18.5,6000
kgen,2,11,12,1,0,-(11.2/(118**1.8))*((124-21)**1.8)-4.8+16,21,7000
kgen,2,9,10,1,0,2.084,21,7000
kgen,2,11,12,1,0,-(11.2/(118**1.8))*((124-23.5)**1.8)-4.8+16,23.5,8000
kgen,2,9,10,1,0,2.409,23.5,8000
kgen,2,11,12,1,0,-(11.2/(118**1.8))*((124-26)**1.8)-4.8+16,26,9000
kgen,2,9,10,1,0,2.728,26,9000
kgen,2,11,12,1,0,-(11.2/(118**1.8))*((124-28.5)**1.8)-4.8+16,28.5,10000
kgen,2,9,10,1,0,3.04,28.5,10000
kgen,2,11,12,1,0,-(11.2/(118**1.8))*((124-31)**1.8)-4.8+16,31,11000
kgen,2,9,10,1,0,3.346,31,11000
kgen,2,111,112,1,0,-(11.2/(118**1.8))*((124-8.5)**1.8)-4.8+16,8.5,2000
kgen,2,109,110,1,0,0.363,8.5,2000
kgen,2,111,112,1,0,-(11.2/(118**1.8))*((124-11)**1.8)-4.8+16,11,3000
kgen,2,109,110,1,0,0.72,11,3000
kgen,2,111,112,1,0,-(11.2/(118**1.8))*((124-13.5)**1.8)-4.8+16,13.5,4000
kgen,2,109,110,1,0,1.071,13.5,4000
kgen,2,111,112,1,0,-(11.2/(118**1.8))*((124-16)**1.8)-4.8+16,16,5000
kgen,2,109,110,1,0,1.414,16,5000
kgen,2,111,112,1,0,-(11.2/(118**1.8))*((124-18.5)**1.8)-4.8+16,18.5,6000
kgen,2,109,110,1,0,1.752,18.5,6000
kgen,2,111,112,1,0,-(11.2/(118**1.8))*((124-21)**1.8)-4.8+16,21,7000
kgen,2,109,110,1,0,2.084,21,7000
kgen,2,111,112,1,0,-(11.2/(118**1.8))*((124-23.5)**1.8)-4.8+16,23.5,8000
kgen,2,109,110,1,0,2.409,23.5,8000
kgen,2,111,112,1,0,-(11.2/(118**1.8))*((124-26)**1.8)-4.8+16,26,9000
kgen,2,109,110,1,0,2.728,26,9000
kgen,2,111,112,1,0,-(11.2/(118**1.8))*((124-28.5)**1.8)-4.8+16,28.5,10000
kgen,2,109,110,1,0,3.04,28.5,10000
kgen,2,111,112,1,0,-(11.2/(118**1.8))*((124-31)**1.8)-4.8+16,31,11000
kgen,2,109,110,1,0,3.346,31,11000
kgen,2,1,8,1,0,0,8.5,2000
kgen,2,101,108,1,0,0,8.5,2000
kgen,2,1,8,1,0,0,11,3000
kgen,2,101,108,1,0,0,11,3000
kgen,2,1,8,1,0,0,13.5,4000
kgen,2,101,108,1,0,0,13.5,4000
kgen,2,1,8,1,0,0,16,5000
kgen,2,101,108,1,0,0,16,5000
kgen,2,1,8,1,0,0,18.5,6000
kgen,2,101,108,1,0,0,18.5,6000
kgen,2,1,8,1,0,0,21,7000
kgen,2,101,108,1,0,0,21,7000
kgen,2,1,8,1,0,0,23.5,8000
kgen,2,101,108,1,0,0,23.5,8000
kgen,2,1,8,1,0,0,26,9000
kgen,2,101,108,1,0,0,26,9000
kgen,2,1,8,1,0,0,28.5,10000
kgen,2,101,108,1,0,0,28.5,10000
kgen,2,1,8,1,0,0,31,11000
kgen,2,101,108,1,0,0,31,11000
k,12001,-0.3,,34!!!!!!!!!!11号截面各点,此处为腹板厚度变化处
k,12002,-3.05,,34
k,12003,-3.75,,34
k,12004,-6.925,,34
k,12005,-6.925,-0.2,34
k,12006,-3.75,-0.9,34
k,12007,-3.05,-0.9,34
k,12008,-0.3,-0.32,34
k,12009,-3.75,-10.295,34
k,12010,-3.05,-10.295,34
k,12011,-3.05,-11.678,34
k,12012,-3.75,-11.678,34
ksymm,x,12001,12012,1,100
kgen,2,12011,12012,1,0,-(11.2/(118**1.8))*((124-37)**1.8)-4.8+11.678,3,1000
kgen,2,12009,12010,1,0,0.348,3,1000
kgen,2,12011,12012,1,0,-(11.2/(118**1.8))*((124-40)**1.8)-4.8+11.678,6,2000
kgen,2,12009,12010,1,0,0.688,6,2000
kgen,2,12011,12012,1,0,-(11.2/(118**1.8))*((124-43)**1.8)-4.8+11.678,9,3000
kgen,2,12009,12010,1,0,1.018,9,3000
kgen,2,12011,12012,1,0,-(11.2/(118**1.8))*((124-46)**1.8)-4.8+11.678,12,4000
kgen,2,12009,12010,1,0,1.338,12,4000
kgen,2,12011,12012,1,0,-(11.2/(118**1.8))*((124-49)**1.8)-4.8+11.678,15,5000
kgen,2,12009,12010,1,0,1.649,15,5000
kgen,2,12011,12012,1,0,-(11.2/(118**1.8))*((124-52)**1.8)-4.8+11.678,18,6000
kgen,2,12009,12010,1,0,1.95,18,6000
kgen,2,12011,12012,1,0,-(11.2/(118**1.8))*((124-55)**1.8)-4.8+11.678,21,7000
kgen,2,12009,12010,1,0,2.241,21,7000
kgen,2,12011,12012,1,0,-(11.2/(118**1.8))*((124-58)**1.8)-4.8+11.678,24,8000
kgen,2,12009,12010,1,0,2.521,24,8000
kgen,2,12011,12012,1,0,-(11.2/(118**1.8))*((124-61)**1.8)-4.8+11.678,27,9000
kgen,2,12009,12010,1,0,2.793,27,9000
kgen,2,12011,12012,1,0,-(11.2/(118**1.8))*((124-64)**1.8)-4.8+11.678,30,10000
kgen,2,12009,12010,1,0,3.054,30,10000
kgen,2,12111,12112,1,0,-(11.2/(118**1.8))*((124-37)**1.8)-4.8+11.678,3,1000
kgen,2,12109,12110,1,0,0.348,3,1000
kgen,2,12111,12112,1,0,-(11.2/(118**1.8))*((124-40)**1.8)-4.8+11.678,6,2000
kgen,2,12109,12110,1,0,0.688,6,2000
kgen,2,12111,12112,1,0,-(11.2/(118**1.8))*((124-43)**1.8)-4.8+11.678,9,3000
kgen,2,12109,12110,1,0,1.018,9,3000
kgen,2,12111,12112,1,0,-(11.2/(118**1.8))*((124-46)**1.8)-4.8+11.678,12,4000
kgen,2,12109,12110,1,0,1.338,12,4000
kgen,2,12111,12112,1,0,-(11.2/(118**1.8))*((124-49)**1.8)-4.8+11.678,15,5000
kgen,2,12109,12110,1,0,1.649,15,5000
kgen,2,12111,12112,1,0,-(11.2/(118**1.8))*((124-52)**1.8)-4.8+11.678,18,6000
kgen,2,12109,12110,1,0,1.95,18,6000
kgen,2,12111,12112,1,0,-(11.2/(118**1.8))*((124-55)**1.8)-4.8+11.678,21,7000
kgen,2,12109,12110,1,0,2.241,21,7000
kgen,2,12111,12112,1,0,-(11.2/(118**1.8))*((124-58)**1.8)-4.8+11.678,24,8000
kgen,2,12109,12110,1,0,2.521,24,8000
kgen,2,12111,12112,1,0,-(11.2/(118**1.8))*((124-61)**1.8)-4.8+11.678,27,9000
kgen,2,12109,12110,1,0,2.793,27,9000
kgen,2,12111,12112,1,0,-(11.2/(118**1.8))*((124-64)**1.8)-4.8+11.678,30,10000
kgen,2,12109,12110,1,0,3.054,30,10000
kgen,2,12001,12008,1,0,0,3,1000
kgen,2,12101,12108,1,0,0,3,1000
kgen,2,12001,12008,1,0,0,6,2000
kgen,2,12101,12108,1,0,0,6,2000
kgen,2,12001,12008,1,0,0,9,3000
kgen,2,12101,12108,1,0,0,9,3000
kgen,2,12001,12008,1,0,0,12,4000
kgen,2,12101,12108,1,0,0,12,4000
kgen,2,12001,12008,1,0,0,15,5000
kgen,2,12101,12108,1,0,0,15,5000
kgen,2,12001,12008,1,0,0,18,6000
kgen,2,12101,12108,1,0,0,18,6000
kgen,2,12001,12008,1,0,0,21,7000
kgen,2,12101,12108,1,0,0,21,7000
kgen,2,12001,12008,1,0,0,24,8000
kgen,2,12101,12108,1,0,0,24,8000
kgen,2,12001,12008,1,0,0,27,9000
kgen,2,12101,12108,1,0,0,27,9000
kgen,2,12001,12008,1,0,0,30,10000
kgen,2,12101,12108,1,0,0,30,10000
!!!!!22号截面各点
k,23001,-0.3,,68
k,23002,-3.15,,68
k,23003,-3.75,,68
k,23004,-6.925,,68
k,23005,-6.925,-0.2,68
k,23006,-3.75,-0.9,68
k,23007,-3.15,-0.9,68
k,23008,-0.3,-0.32,68
k,23009,-3.75,-6.91,68
k,23010,-3.15,-6.91,68
k,23011,-3.15,-7.728,68
k,23012,-3.75,-7.728,68
ksymm,x,23001,23012,1,100
kgen,2,23011,23012,1,0,-(11.2/(118**1.8))*((124-72)**1.8)-4.8+7.728,4,1000
kgen,2,23009,23010,1,0,0.314,4,1000
kgen,2,23011,23012,1,0,-(11.2/(118**1.8))*((124-76)**1.8)-4.8+7.728,8,2000
kgen,2,23009,23010,1,0,0.608,8,2000
kgen,2,23011,23012,1,0,-(11.2/(118**1.8))*((124-80)**1.8)-4.8+7.728,12,3000
kgen,2,23009,23010,1,0,0.884,12,3000
kgen,2,23011,23012,1,0,-(11.2/(118**1.8))*((124-84)**1.8)-4.8+7.728,16,4000
kgen,2,23009,23010,1,0,1.14,16,4000
kgen,2,23011,23012,1,0,-(11.2/(118**1.8))*((124-88)**1.8)-4.8+7.728,20,5000
kgen,2,23009,23010,1,0,1.377,20,5000
kgen,2,23011,23012,1,0,-(11.2/(118**1.8))*((124-93)**1.8)-4.8+7.728,25,6000
kgen,2,23009,23010,1,0,1.644,25,6000
kgen,2,23111,23112,1,0,-(11.2/(118**1.8))*((124-72)**1.8)-4.8+7.728,4,1000
kgen,2,23109,23110,1,0,0.314,4,1000
kgen,2,23111,23112,1,0,-(11.2/(118**1.8))*((124-76)**1.8)-4.8+7.728,8,2000
kgen,2,23109,23110,1,0,0.608,8,2000
kgen,2,23111,23112,1,0,-(11.2/(118**1.8))*((124-80)**1.8)-4.8+7.728,12,3000
kgen,2,23109,23110,1,0,0.884,12,3000
kgen,2,23111,23112,1,0,-(11.2/(118**1.8))*((124-84)**1.8)-4.8+7.728,16,4000
kgen,2,23109,23110,1,0,1.14,16,4000
kgen,2,23111,23112,1,0,-(11.2/(118**1.8))*((124-88)**1.8)-4.8+7.728,20,5000
kgen,2,23109,23110,1,0,1.377,20,5000
kgen,2,23111,23112,1,0,-(11.2/(118**1.8))*((124-93)**1.8)-4.8+7.728,25,6000
kgen,2,23109,23110,1,0,1.644,25,6000
kgen,2,23001,23008,1,0,0,4,1000
kgen,2,23101,23108,1,0,0,4,1000
kgen,2,23001,23008,1,0,0,8,2000
kgen,2,23101,23108,1,0,0,8,2000
kgen,2,23001,23008,1,0,0,12,3000
kgen,2,23101,23108,1,0,0,12,3000
kgen,2,23001,23008,1,0,0,16,4000
kgen,2,23101,23108,1,0,0,16,4000
kgen,2,23001,23008,1,0,0,20,5000
kgen,2,23101,23108,1,0,0,20,5000
kgen,2,23001,23008,1,0,0,25,6000
kgen,2,23101,23108,1,0,0,25,6000
!!!!!29号截面各点
k,30001,-0.3,,98
k,30002,-3.25,,98
k,30003,-3.75,,98
k,30004,-6.925,,98
k,30005,-6.925,-0.2,98
k,30006,-3.75,-0.9,98
k,30007,-3.25,-0.9,98
k,30008,-0.3,-0.32,98
k,30009,-3.75,-5.031,98
k,30010,-3.25,-5.031,98
k,30011,-3.25,-5.536,98
k,30012,-3.75,-5.536,98
ksymm,x,30001,30012,1,100
kgen,2,30011,30012,1,0,-(11.2/(118**1.8))*((124-103)**1.8)-4.8+5.536,5,1000
kgen,2,30009,30010,1,0,0.202,5,1000
kgen,2,30011,30012,1,0,-(11.2/(118**1.8))*((124-108)**1.8)-4.8+5.536,10,2000
kgen,2,30009,30010,1,0,0.368,10,2000
kgen,2,30011,30012,1,0,-(11.2/(118**1.8))*((124-113)**1.8)-4.8+5.536,15,3000
kgen,2,30009,30010,1,0,0.497,15,3000
kgen,2,30011,30012,1,0,-(11.2/(118**1.8))*((124-118)**1.8)-4.8+5.536,20,4000
kgen,2,30009,30010,1,0,0.586,20,4000
kgen,2,30011,30012,1,0,-(11.2/(118**1.8))*((124-123)**1.8)-4.8+5.536,25,5000
kgen,2,30009,30010,1,0,0.629,25,5000
kgen,2,30011,30012,1,0,-(11.2/(118**1.8))*((124-124)**1.8)-4.8+5.536,26,6000
kgen,2,30009,30010,1,0,0.631,26,6000
kgen,2,30111,30112,1,0,-(11.2/(118**1.8))*((124-103)**1.8)-4.8+5.536,5,1000
kgen,2,30109,30110,1,0,0.202,5,1000
kgen,2,30111,30112,1,0,-(11.2/(118**1.8))*((124-108)**1.8)-4.8+5.536,10,2000
kgen,2,30109,30110,1,0,0.368,10,2000
kgen,2,30111,30112,1,0,-(11.2/(118**1.8))*((124-113)**1.8)-4.8+5.536,15,3000
kgen,2,30109,30110,1,0,0.497,15,3000
kgen,2,30111,30112,1,0,-(11.2/(118**1.8))*((124-118)**1.8)-4.8+5.536,20,4000
kgen,2,30109,30110,1,0,0.586,20,4000
kgen,2,30111,30112,1,0,-(11.2/(118**1.8))*((124-123)**1.8)-4.8+5.536,25,5000
kgen,2,30109,30110,1,0,0.629,25,5000
kgen,2,30111,30112,1,0,-(11.2/(118**1.8))*((124-124)**1.8)-4.8+5.536,26,6000
kgen,2,30109,30110,1,0,0.631,26,6000
kgen,2,30001,30008,1,0,0,5,1000
kgen,2,30101,30108,1,0,0,5,1000
kgen,2,30001,30008,1,0,0,10,2000
kgen,2,30101,30108,1,0,0,10,2000
kgen,2,30001,30008,1,0,0,15,3000
kgen,2,30101,30108,1,0,0,15,3000
kgen,2,30001,30008,1,0,0,20,4000
kgen,2,30101,30108,1,0,0,20,4000
kgen,2,30001,30008,1,0,0,25,5000
kgen,2,30101,30108,1,0,0,25,5000
kgen,2,30001,30008,1,0,0,26,6000
kgen,2,30101,30108,1,0,0,26,6000
!!!!!边跨合龙端截面各点(123米到125米)
k,37001,-0.3,,125
k,37002,-3.25,,125
k,37003,-3.75,,125
k,37004,-6.925,,125
k,37005,-6.925,-0.2,125
k,37006,-3.75,-0.9,125
k,37007,-3.25,-0.9,125
k,37008,-0.3,-0.32,125
k,37009,-3.75,-4.4,125
k,37010,-3.25,-4.4,125
k,37011,-3.25,-4.8,125
k,37012,-3.75,-4.8,125
ksymm,x,37001,37012,1,100
!!!!!边跨现浇段截面各点(125米到128.72米)
k,38001,-0.3,,126.92
k,38002,-3.25,,126.92
k,38003,-3.75,,126.92
k,38004,-6.925,,126.92
k,38005,-6.925,-0.2,126.92
k,38006,-3.75,-0.9,126.92
k,38007,-3.25,-0.9,126.92
k,38008,-0.3,-0.32,126.92
k,38009,-3.75,-4.4,126.92
k,38010,-3.25,-4.4,126.92
k,38011,-3.25,-4.8,126.92
k,38012,-3.75,-4.8,126.92
ksymm,x,38001,38012,1,100
kgen,2,38001,38012,1,0,0,1.8,1000
kgen,2,38101,38112,1,0,0,1.8,1000
!!!!!!!!!通过循环生成个单元
* do,i,1000,39000,1000
v,1+i-1000,i-1000+8,i-1000+108,i-1000+101,1+i,8+i,108+i,101+i
v,1+i-1000,i-1000+2,i-1000+7,i-1000+8,1+i,2+i,7+i,8+i
v,2+i-1000,i-1000+3,i-1000+6,i-1000+7,2+i,3+i,6+i,7+i
v,3+i-1000,i-1000+4,i-1000+5,i-1000+6,3+i,4+i,5+i,6+i
v,7+i-1000,i-1000+6,i-1000+9,i-1000+10,7+i,6+i,9+i,10+i
v,10+i-1000,i-1000+9,i-1000+12,i-1000+11,10+i,9+i,12+i,11+i
v,10+i-1000,i-1000+11,i-1000+111,i-1000+110,10+i,11+i,111+i,110+i
v,101+i-1000,i-1000+102,i-1000+107,i-1000+108,101+i,102+i,107+i,108+i
v,102+i-1000,i-1000+103,i-1000+106,i-1000+107,102+i,103+i,106+i,107+i
v,103+i-1000,i-1000+104,i-1000+105,i-1000+106,103+i,104+i,105+i,106+i
v,107+i-1000,i-1000+106,i-1000+109,i-1000+110,107+i,106+i,109+i,110+i
v,110+i-1000,i-1000+109,i-1000+112,i-1000+111,110+i,109+i,112+i,111+i
* enddo
!!!将零号块定义成实心
v,7,10,110,107,1007,1010,1110,1107
v,7,107,108,8,1007,1107,1108,1008
!!!!!通过镜像创建另一半悬臂(开始有470个体,镜像后有了中跨合龙端,总共915个体,4642条线,39112个点)
vsel,all
vsymm,z,1,445,1
!!!!!!!!!!!创建T预应力钢束线
!!!!!!!!T1钢束(该预应力钢束的线号是4643)
lsel,none
k,40000,-3.05,-0.53,-11
k,40001,-2.75,-0.53,0
k,40002,-3.05,-0.53,11
l,40000,40001
l,40001,40002
lcomb,all
!!!!!!!!T2钢束
lsel,none
k,40003,-3.85,-0.53,-13.5
k,40004,-4.15,-0.53,0
k,40005,-3.85,-0.53,13.5
l,40003,40004
l,40004,40005
lcomb,all
!!!!!!!!T3钢束
lsel,none
k,40006,-3.05,-0.53,-16
k,40007,-2.55,-0.53,0
k,40008,-3.05,-0.53,16
l,40006,40007
l,40007,40008
lcomb,all
!!!!!!!!T4钢束
lsel,none
k,40009,-3.85,-0.53,-18.5
k,40010,-4.35,-0.53,0
k,40011,-3.85,-0.53,18.5
l,40009,40010
l,40010,40011
lcomb,all
!!!!!!!!T5钢束
lsel,none
k,40012,-3.05,-0.53,-21
k,40013,-2.8,-0.364,-17.827
k,40014,-2.75,-0.35,0
k,40015,-2.8,-0.364,17.827
k,40016,-3.05,-0.53,21
l,40012,40013
l,40013,40014
l,40014,40015
l,40015,40016
lcomb,all
!!!!!!!!T6钢束
lsel,none
k,40017,-3.85,-0.53,-23.5
k,40018,-4,-0.364,-20.327
k,40019,-4.15,-0.35,0
k,40020,-4,-0.364,20.327
k,40021,-3.85,-0.53,23.5
l,40017,40018
l,40018,40019
l,40019,40020
l,40020,40021
lcomb,all
!!!!!!!!T7钢束
lsel,none
k,40022,-3.05,-0.53,-26
k,40023,-2.8,-0.364,-22.827
k,40024,-2.55,-0.35,0
k,40025,-2.8,-0.364,22.827
k,40026,-3.05,-0.53,26
l, 40022, 40023
l, 40023, 40024
l, 40024, 40025
l, 40025, 40026
lcomb,all
!!!!!!!!T8钢束
lsel,none
k, 40027,-3.85,-0.53,-28.5
k, 40028,-4.1,-0.364,-25.327
k, 40029,-4.35,-0.35,0
k, 40030,-4.1,-0.364,25.327
k, 40031,-3.85,-0.53,28.5
l, 40027, 40028
l, 40028, 40029
l, 40029, 40030
l, 40030, 40031
lcomb,all
!!!!!!!!T9钢束(非连续性线段)
lsel,none
k, 40032,-3.05,-0.53,-31
k, 40033,-2.6,-0.364,-27.827
k, 40034,-2.35,-0.35,0
k, 40035,-2.6,-0.364,27.827
k, 40036,-3.05,-0.53,31
l, 40032, 40033
l, 40033, 40034
l, 40034, 40035
l, 40035, 40036
lcomb,all
!!!!!!!!T10钢束
lsel,none
k, 40037,-3.85,-0.53,-34
k, 40038,-4.25,-0.364,-30.827
k, 40039,-4.55,-0.35,0
k, 40040,-4.25,-0.364,30.827
k, 40041,-3.85,-0.53,34
l, 40037, 40038
l, 40038, 40039
l, 40039, 40040
l, 40040, 40041
lcomb,all
!!!!!!!!T11钢束
lsel,none
k, 40042,-3.05,-0.53,-37
k, 40043,-2.6,-0.364,-33.827
k, 40044,-2.15,-0.35,0
k, 40045,-2.6,-0.364,33.827
k, 40046,-3.05,-0.53,37
l, 40042, 40043
l, 40043, 40044
l, 40044, 40045
l, 40045, 40046
lcomb,all
!!!!!!!!T12钢束
lsel,none
k, 40047,-3.85,-0.53,-40
k, 40048,-4.3,-0.364,-36.827
k, 40049,-4.75,-0.35,0
k, 40050,-4.3,-0.364,36.827
k, 40051,-3.85,-0.53,40
l, 40047, 40048
l, 40048, 40049
l, 40049, 40050
l, 40050, 40051
lcomb,all
!!!!!!!!T13钢束
lsel,none
k, 40052,-3.05,-0.53,-43
k, 40053,-2.5,-0.364,-39.827
k, 40054,-1.95,-0.35,0
k, 40055,-2.5,-0.364,39.827
k, 40056,-3.05,-0.53,43
l, 40052, 40053
l, 40053, 40054
l, 40054, 40055
l, 40055, 40056
lcomb,all
!!!!!!!!T14钢束
lsel,none
k, 40057,-3.85,-0.53,-46
k, 40058,-4.45,-0.364,-42.827
k, 40059,-4.95,-0.35,0
k, 40060,-4.45,-0.364,42.827
k, 40061,-3.85,-0.53,46
l, 40057, 40058
l, 40058, 40059
l, 40059, 40060
l, 40060, 40061
lcomb,all
!!!!!!!!T15钢束
lsel,none
k, 40062,-3.05,-0.53,-49
k, 40063,-2.4,-0.364,-45.827
k, 40064,-1.75,-0.35,0
k, 40065,-2.4,-0.364,45.827
k, 40066,-3.05,-0.53,49
l, 40062, 40063
l, 40063, 40064
l, 40064, 40065
l, 40065, 40066
lcomb,all
!!!!!!!!T16钢束
lsel,none
k, 40067,-3.85,-0.53,-52
k, 40068,-4.5,-0.364,-48.827
k, 40069,-5.15,-0.35,0
k, 40070,-4.5,-0.364,48.827
k, 40071,-3.85,-0.53,52
l, 40067, 40068
l, 40068, 40069
l, 40069, 40070
l, 40070, 40071
lcomb,all
!!!!!!!!T17钢束
lsel,none
k, 40072,-3.05,-0.53,-55
k, 40073,-2.3,-0.364,-51.827
k, 40074,-1.55,-0.35,0
k, 40075,-2.3,-0.364,51.827
k, 40076,-3.05,-0.53,55
l, 40072, 40073
l, 40073, 40074
l, 40074, 40075
l, 40075, 40076
lcomb,all
!!!!!!!!T18钢束
lsel,none
k, 40077,-3.85,-0.53,-58
k, 40078,-4.6,-0.364,-54.827
k, 40079,-5.35,-0.35,0
k, 40080,-4.6,-0.364,54.827
k, 40081,-3.85,-0.53,58
l, 40077, 40078
l, 40078, 40079
l, 40079, 40080
l, 40080, 40081
lcomb,all
!!!!!!!!T19钢束(结束非线性线段)
lsel,none
k, 40082,-3.05,-0.53,-61
k, 40083,-3,-0.184,-54.392
k, 40084,-2.95,-0.17,0
k, 40085,-3,-0.184,54.392
k, 40086,-3.05,-0.53,61
l, 40082, 40083
l, 40083, 40084
l, 40084, 40085
l, 40085, 40086
lcomb,all
!!!!!!!!T20钢束
lsel,none
k, 40087,-3.85,-0.53,-64
k, 40088,-3.9,-0.184,-57.392
k, 40089,-3.95,-0.17,0
k, 40090,-3.9,-0.184,57.392
k, 40091,-3.85,-0.53,64
l, 40087, 40088
l, 40088, 40089
l, 40089, 40090
l, 40090, 40091
lcomb,all
!!!!!!!!T21钢束
lsel,none
k, 40092, -3.05,-0.53,-68
k, 40093, -2.9,-0.184,-61.392
k, 40094, -2.75,-0.17,0
k, 40095, -2.9,-0.184,61.392
k, 40096, -3.05,-0.53,68
l, 40092, 40093
l, 40093, 40094
l, 40094, 40095
l, 40095, 40096
lcomb,all
!!!!!!!!T22钢束
lsel,none
k, 40097,-3.85,-0.53,-72
k, 40098,-4,-0.184,-65.392
k, 40099,-4.15,-0.17,0
k, 40100,-4,-0.184,65.392
k, 40101,-3.85,-0.53,72
l, 40097, 40098
l, 40098, 40099
l, 40099, 40100
l, 40100, 40101
lcomb,all
!!!!!!!!T23钢束
lsel,none
k, 40102,-3.05,-0.53,-76
k, 40103,-2.8,-0.184,-69.392
k, 40104,-2.55,-0.17,0
k, 40105,-2.8,-0.184,69.392
k, 40106,-3.05,-0.53,76
l, 40102, 40103
l, 40103, 40104
l, 40104, 40105
l, 40105, 40106
lcomb,all
!!!!!!!!T24钢束
lsel,none
k, 40107,-3.85,-0.53,-80
k, 40108,-4.1,-0.184,-73.392
k, 40109,-4.35,-0.17,0
k, 40110,-4.1,-0.184,73.392
k, 40111,-3.85,-0.53,80
l, 40107, 40108
l, 40108, 40109
l, 40109, 40110
l, 40110, 40111
lcomb,all
!!!!!!!!T25钢束
lsel,none
k, 40112,-3.05,-0.53,-84
k, 40113,-2.7,-0.184,-77.392
k, 40114,-2.35,-0.17,0
k, 40115,-2.7,-0.184,77.392
k, 40116,-3.05,-0.53,84
l, 40112, 40113
l, 40113, 40114
l, 40114, 40115
l, 40115, 40116
lcomb,all
!!!!!!!!T26钢束
lsel,none
k, 40117,-3.85,-0.53,-88
k, 40118,-4.2,-0.184,-81.392
k, 40119,-4.55,-0.17,0
k, 40120,-4.2,-0.184,81.392
k, 40121,-3.85,-0.53,88
l, 40117, 40118
l, 40118, 40119
l, 40119, 40120
l, 40120, 40121
lcomb,all
!!!!!!!!T27钢束
lsel,none
k, 40122,-3.05,-0.53,-93
k, 40123,-2.6,-0.184,-86.392
k, 40124,-2.15,-0.17,0
k, 40125,-2.6,-0.184,86.392
k, 40126,-3.05,-0.53,93
l, 40122, 40123
l, 40123, 40124
l, 40124, 40125
l, 40125, 40126
lcomb,all
!!!!!!!!T28钢束
lsel,none
k, 40127,-3.85,-0.17,-98
k, 40128,-4.3,-0.184,-91.392
k, 40129,-4.75,-0.17,0
k, 40130,-4.3,-0.184,91.392
k, 40131,-3.85,-0.53,98
l, 40127, 40128
l, 40128, 40129
l, 40129, 40130
l, 40130, 40131
lcomb,all
!!!!!!!!T29钢束
lsel,none
k, 40132,-3.05,-0.53,-103
k, 40133,-2.5,-0.184,-96.392
k, 40134,-1.95,-0.17,0
k, 40135,-2.5,-0.184,96.392
k, 40136,-3.05,-0.53,103
l, 40132, 40133
l, 40133, 40134
l, 40134, 40135
l, 40135, 40136
lcomb,all
!!!!!!!!T30钢束
lsel,none
k, 40137,-3.85,-0.53,-108
k, 40138,-4.45,-0.184,-101.392
k, 40139,-4.95,-0.17,0
k, 40140,-4.45,-0.184,101.392
k, 40141,-3.85,-0.53,108
l, 40137, 40138
l, 40138, 40139
l, 40139, 40140
l, 40140, 40141
lcomb,all
!!!!!!!!T31钢束
lsel,none
k, 40142,-3.05,-0.53,-113
k, 40143,-2.4,-0.184,-106.392
k, 40144,-1.75,-0.17,0
k, 40145,-2.4,-0.184,106.392
k, 40146,-3.05,-0.53,113
l, 40142, 40143
l, 40143, 40144
l, 40144, 40145
l, 40145, 40146
lcomb,all
!!!!!!!!T32钢束
lsel,none
k, 40147,-3.85,-0.53,-113
k, 40148,-4.5,-0.184,-106.392
k, 40149,-5.15,-0.17,0
k, 40150,-4.5,-0.184,106.392
k, 40151,-3.85,-0.53,113
l, 40147, 40148
l, 40148, 40149
l, 40149, 40150
l, 40150, 40151
lcomb,all
!!!!!!!!T33钢束
lsel,none
k, 40152,-3.05,-0.53,-118
k, 40153,-2.3,-0.184,-111.392
k, 40154,-1.55,-0.17,0
k, 40155,-2.3,-0.184,111.392
k, 40156,-3.05,-0.53,118
l, 40152, 40153
l, 40153, 40154
l, 40154, 40155
l, 40155, 40156
lcomb,all
!!!!!!!!T34钢束
lsel,none
k, 40157,-3.85,-0.53,-118
k, 40158,-4.6,-0.184,-111.392
k, 40159,-5.35,-0.17,0
k, 40160,-4.6,-0.184,111.392
k, 40161,-3.85,-0.53,118
l, 40157, 40158
l, 40158, 40159
l, 40159, 40160
l, 40160, 40161
lcomb,all
!!!!!!!!T35钢束
lsel,none
k, 40162,-3.05,-0.53,-123
k, 40163,-2.2,-0.184,-116.392
k, 40164,-1.35,-0.17,0
k, 40165,-2.2,-0.184,116.392
k, 40166,-3.05,-0.53,123
l, 40162, 40163
l, 40163, 40164
l, 40164, 40165
l, 40165, 40166
lcomb,all
!!!!!!!!T36钢束
lsel,none
k, 40167,-3.85,-0.53,-123
k, 40168,-4.7,-0.184,-116.392
k, 40169,-5.55,-0.17,0
k, 40170,-4.7,-0.184,116.392
k, 40171,-3.85,-0.53,123
l, 40167, 40168
l, 40168, 40169
l, 40169, 40170
l, 40170, 40171
lcomb,all
!!!!!!!!W1钢束
lsel,none
k,40172,-3.35,-9.505,-11
k,40173,-3.35,-3.15 ,-0.033
k,40174,-3.35,-3.15,0
k,40175,-3.35,-3.15,0.033
k,40176,-3.35,-9.505,11
l, 40172, 40173
l, 40173, 40174
l, 40174, 40175
l, 40175, 40176
lcomb,all
!!!!!!!!W2钢束
lsel,none
k, 40177,-3.35,-9.217,-13.5
k, 40178,-3.55,-3.15,-2.944
k, 40179,-3.55,-3.15,0
k, 40180,-3.55,-3.15,2.944
k, 40181,-3.35,-9.217,13.5
l, 40177, 40178
l, 40178, 40179
l, 40179, 40180
l, 40180, 40181
lcomb,all
!!!!!!!!W3钢束
lsel,none
k, 40182,-3.35,-8.935,-16
k, 40183,-3.35,-2.95,-3.491
k, 40184,-3.35,-2.95,0
k, 40185,-3.35,-2.95,3.491
k, 40186,-3.35,-8.935,16
l, 40182, 40183
l, 40183, 40184
l, 40184, 40185
l, 40185, 40186
lcomb,all
!!!!!!!!W4钢束
lsel,none
k, 40187,-3.35,-8.658,-18.5
k, 40188,-3.55,-2.95,-6.471
k, 40189,-3.55,-2.95,0
k, 40190,-3.55,-2.95,6.471
k, 40191,-3.35,-8.658,18.5
l, 40187, 40188
l, 40188, 40189
l, 40189, 40190
l, 40190, 40191
lcomb,all
!!!!!!!!W5钢束
lsel,none
k, 40192,-3.35,-8.386,-21
k, 40193,-3.35,-2.75,-9.095
k, 40194,-3.35,-2.75,0
k, 40195,-3.35,-2.75,9.095
k, 40196,-3.35,-8.386,21
l, 40192, 40193
l, 40193, 40194
l, 40194, 40195
l, 40195, 40196
lcomb,all
!!!!!!!!W6钢束
lsel,none
k, 40197,-3.35,-8.12,-23.5
k, 40198,-3.55,-2.75,-10.211
k, 40199,-3.55,-2.75,0
k, 40200,-3.55,-2.75,10.211
k, 40201,-3.35,-8.12,23.5
l, 40197, 40198
l, 40198, 40199
l, 40199, 40200
l, 40200, 40201
lcomb,all
!!!!!!!!W7钢束
lsel,none
k, 40202,-3.35,-7.859,-26
k, 40203,-3.35,-2.55,-12.842
k, 40204,-3.35,-2.55,0
k, 40205,-3.35,-2.55,12.842
k, 40206,-3.35,-7.859,26
l, 40202, 40203
l, 40203, 40204
l, 40204, 40205
l, 40205, 40206
lcomb,all
!!!!!!!!W8钢束
lsel,none
k, 40920,-3.35,-7.603,-28.5
k, 40921,-3.55,-2.55,-15.89
k, 40922,-3.55,-2.55,0
k, 40923,-3.55,-2.55,15.89
k, 40924,-3.35,-7.603,28.5
l, 40920, 40921
l, 40921, 40922
l, 40922, 40923
l, 40923, 40924
lcomb,all
!!!!!!!!W9钢束
lsel,none
k, 40207,-3.35,-7.352,-31
k, 40208,-3.35,-2.35,-18.499
k, 40209,-3.35,-2.35,0
k, 40210,-3.35,-2.35,18.499
k, 40211,-3.35,-7.352,31
l, 40207, 40208
l, 40208, 40209
l, 40209, 40210
l, 40210, 40211
lcomb,all
!!!!!!!!W10钢束
lsel,none
k, 40212,-3.4,-7.058,-34
k, 40213,-3.55,-2.35,-19.654
k, 40214,-3.55,-2.35,0
k, 40215,-3.55,-2.35,19.654
k, 40216,-3.4,-7.058,34
l, 40212, 40213
l, 40213, 40214
l, 40214, 40215
l, 40215, 40216
lcomb,all
!!!!!!!!W11钢束
lsel,none
k, 40217,-3.4,-6.772,-37
k, 40218,-3.35,-2.15,-22.89
k, 40219,-3.35,-2.15,0
k, 40220,-3.35,-2.15,22.89
k, 40221,-3.4,-6.772,37
l, 40217, 40218
l, 40218, 40219
l, 40219, 40220
l, 40220, 40221
lcomb,all
!!!!!!!!W12钢束
lsel,none
k, 40222,-3.4,-6.495,-40
k, 40223,-3.55,-2.15,-26.652
k, 40224,-3.55,-2.15,0
k, 40225,-3.55,-2.15,26.652
k, 40226,-3.4,-6.495,40
l, 40222, 40223
l, 40223, 40224
l, 40224, 40225
l, 40225, 40226
lcomb,all
!!!!!!!!W13钢束
lsel,none
k, 40227,-3.4,-6.225,-43
k, 40228,-3.35,-1.95,-29.844
k, 40229,-3.35,-1.95,0
k, 40230,-3.35,-1.95,29.844
k, 40231,-3.4,-6.225,43
l, 40227, 40228
l, 40228, 40229
l, 40229, 40230
l, 40230, 40231
lcomb,all
!!!!!!!!W14钢束
lsel,none
k, 40232,-3.4,-5.964,-46
k, 40233,-3.55,-1.95,-33.562
k, 40234,-3.55,-1.95,0
k, 40235,-3.55,-1.95,33.562
k, 40236,-3.4,-5.964,46
l, 40232, 40233
l, 40233, 40234
l, 40234, 40235
l, 40235, 40236
lcomb,all
!!!!!!!!W15钢束
lsel,none
k, 40237,-3.4,-5.711,-49
k, 40238,-3.35,-1.75,-36.707
k, 40239,-3.35,-1.75,0
k, 40240,-3.35,-1.75,36.707
k, 40241,-3.4,-5.711,49
l, 40237, 40238
l, 40238, 40239
l, 40239, 40240
l, 40240, 40241
lcomb,all
!!!!!!!!W16钢束
lsel,none
k, 40242,-3.4,-5.466,-52
k, 40243,-3.55,-1.75,-40.38
k, 40244,-3.55,-1.75,0
k, 40245,-3.55,-1.75,40.38
k, 40246,-3.4,-5.466,52
l, 40242, 40243
l, 40243, 40244
l, 40244, 40245
l, 40245, 40246
lcomb,all
!!!!!!!!W17钢束
lsel,none
k, 40247,-3.4,-5.23,-55
k, 40248,-3.35,-1.55,-43.479
k, 40249,-3.35,-1.55,0
k, 40250,-3.35,-1.55,43.479
k, 40251,-3.4,-5.23,55
l, 40247, 40248
l, 40248, 40249
l, 40249, 40250
l, 40250, 40251
lcomb,all
!!!!!!!!W18钢束
lsel,none
k, 40252,-3.4,-5.005,-58
k, 40253,-3.55,-1.55,-47.096
k, 40254,-3.55,-1.55,0
k, 40255,-3.55,-1.55,47.096
k, 40256,-3.4,-5.005,58
l, 40252, 40253
l, 40253, 40254
l, 40254, 40255
l, 40255, 40256
lcomb,all
!!!!!!!!W19钢束
lsel,none
k, 40257,-3.4,-4.79,-61
k, 40258,-3.35,-1.35,-47.109
k, 40259,-3.35,-1.35,0
k, 40260,-3.35,-1.35,47.109
k, 40261,-3.4,-4.79,61
l, 40257, 40258
l, 40258, 40259
l, 40259, 40260
l, 40260, 40261
lcomb,all
!!!!!!!!W20钢束
lsel,none
k, 40262,-3.4,-4.584,-64
k, 40263,-3.55,-1.35,-50.879
k, 40264,-3.55,-1.35,0
k, 40265,-3.55,-1.35,50.879
k, 40266,-3.4,-4.584,64
l, 40262, 40263
l, 40263, 40264
l, 40264, 40265
l, 40265, 40266
lcomb,all
!!!!!!!!W21钢束
lsel,none
k, 40267,-3.45,-4.32,-68
k, 40268,-3.35,-1.15,-55.118
k, 40269,-3.35,-1.15,0
k, 40270,-3.35,-1.15,55.118
k, 40271,-3.45,-4.32,68
l, 40267, 40268
l, 40268, 40269
l, 40269, 40270
l, 40270, 40271
lcomb,all
!!!!!!!!W22钢束
lsel,none
k, 40272,-3.45,-4.072,-72
k, 40273,-3.55,-1.15,-60.043
k, 40274,-3.55,-1.15,0
k, 40275,-3.55,-1.15,60.043
k, 40276,-3.45,-4.072,72
l, 40272, 40273
l, 40273, 40274
l, 40274, 40275
l, 40275, 40276
lcomb,all
!!!!!!!!W23钢束
lsel,none
k, 40277,-3.45,-3.84,-76
k, 40278,-3.35,-0.95,-64.162
k, 40279,-3.35,-0.95,0
k, 40280,-3.35,-0.95,64.162
k, 40281,-3.45,-3.84,76
l, 40277, 40278
l, 40278, 40279
l, 40279, 40280
l, 40280, 40281
lcomb,all
!!!!!!!!W24钢束
lsel,none
k, 40282,-3.45,-3.625,-80
k, 40283,-3.55,-0.95,-68.964
k, 40284,-3.55,-0.95,0
k, 40285,-3.55,-0.95,68.964
k, 40286,-3.45,-3.625,80
l, 40282, 40283
l, 40283, 40284
l, 40284, 40285
l, 40285, 40286
lcomb,all
!!!!!!!!W25钢束
lsel,none
k, 40287,-3.45,-3.426,-84
k, 40288,-3.35,-0.75,-72.959
k, 40289,-3.35,-0.75,0
k, 40290,-3.35,-0.75,72.959
k, 40291,-3.45,-3.426,84
l, 40287, 40288
l, 40288, 40289
l, 40289, 40290
l, 40290, 40291
lcomb,all
!!!!!!!!W26钢束
lsel,none
k, 40292,-3.45,-3.244,-88
k, 40293,-3.55,-0.75,-77.639
k, 40294,-3.55,-0.75,0
k, 40295,-3.55,-0.75,77.639
k, 40296,-3.45,-3.244,88
l, 40292, 40293
l, 40293, 40294
l, 40294, 40295
l, 40295, 40296
lcomb,all
!!!!!!!!W27钢束
lsel,none
k, 40297,-3.45,-3.038,-93
k, 40298,-3.35,-0.55,-82.661
k, 40299,-3.35,-0.55,0
k, 40300,-3.35,-0.55,82.661
k, 40301,-3.45,-3.038,93
l, 40297, 40298
l, 40298, 40299
l, 40299, 40300
l, 40300, 40301
lcomb,all
!!!!!!!!W28钢束
lsel,none
k, 40302,-3.5,-2.859,-98
k, 40303,-3.55,-0.55,-88.328
k, 40304,-3.55,-0.55,0
k, 40305,-3.55,-0.55,88.328
k, 40306,-3.5,-2.859,98
l, 40302, 40303
l, 40303, 40304
l, 40304, 40305
l, 40305, 40306
lcomb,all
!!!!!!!!W29钢束
lsel,none
k, 40307,-3.5,-2.708,-103
k, 40308,-3.35,-0.35,-93.146
k, 40309,-3.35,-0.35,0
k, 40310,-3.35,-0.35,93.146
k, 40311,-3.5,-2.708,103
l, 40307, 40308
l, 40308, 40309
l, 40309, 40310
l, 40310, 40311
lcomb,all
!!!!!!!!W30钢束
lsel,none
k, 40312,-3.5,-2.585,-108
k, 40313,-3.55,-0.35,-98.605
k, 40314,-3.55,-0.35,0
k, 40315,-3.55,-0.35,98.605
k, 40316,-3.5,-2.585,108
l, 40312, 40313
l, 40313, 40314
l, 40314, 40315
l, 40315, 40316
lcomb,all
!!!!!!!!SB1钢束
local,11,0,0,0,0,0,0,180
lsel,none
k, 40317,-2.65,-3.767,-128.72
k, 40318,-2.65,-4.602,-124.683
k, 40319,-2.65,-4.602,-123.002
k, 40320,-2.65,-4.649,-118
k, 40321,-2.65,-4.734,-111.937
k, 40322,-2.65,-4.04,-108
l, 40317, 40318
l, 40318, 40319
l, 40319, 40320
l, 40320, 40321
l, 40321, 40322
lcomb,all
!!!!!!!!SB2钢束
lsel,none
k, 40323,-2.5,-4.337,-128.72
k, 40324,-2.5,-4.602,-126.32
k, 40325,-2.5,-4.602,-124.683
k, 40326,-2.5,-4.602,-123.002
k, 40327,-2.5,-4.649,-118
k, 40328,-2.5,-4.734,-111.937
k, 40329,-2.5,-4.92,-107.646
k, 40330,-2.5,-4.206,-103
l, 40323, 40324
l, 40324, 40325
l, 40325, 40326
l, 40326, 40327
l, 40327, 40328
l, 40328, 40329
l, 40329, 40330
lcomb,all
!!!!!!!!SB3钢束
lsel,none
k, 40331,-2.85,-4.337,-128.72
k, 40332,-2.85,-4.602,-126.32
k, 40333,-2.85,-4.602,-124.683
k, 40334,-2.85,-4.602,-123.002
k, 40335,-2.85,-4.649,-118
k, 40336,-2.85,-4.734,-111.937
k, 40337,-2.85,-4.92,-107.046
k, 40338,-2.85,-5.11,-101.982
k, 40339,-2.85,-4.407,-98
l, 40331, 40332
l, 40332, 40333
l, 40333, 40334
l, 40334, 40335
l, 40335, 40336
l, 40336, 40337
l, 40337, 40338
l, 40338, 40339
lcomb,all
!!!!!!!!SB4钢束
lsel,none
k, 40340,-2.25,-3.767,-128.72
k, 40341,-2.25,-4.602,-124.683
k, 40342,-2.25,-4.602,-123.002
k, 40343,-2.25,-4.649,-118
k, 40344,-2.25,-4.734,-111.937
k, 40345,-2.25,-4.92,-107.046
k, 40346,-2.25,-5.11,-101.982
k, 40347,-2.25,-5.337,-96.941
k, 40348,-2.25,-4.642,-93
l, 40340, 40341
l, 40341, 40342
l, 40342, 40343
l, 40343, 40344
l, 40344, 40345
l, 40345, 40346
l, 40346, 40347
l, 40347, 40348
lcomb,all
!!!!!!!!SB5钢束
lsel,none
k, 40349,-3.05,-3.767,-128.72
k, 40350,-3.05,-4.602,-124.683
k, 40351,-3.05,-4.602,-123.002
k, 40352,-3.05,-4.649,-118
k, 40353,-3.05,-4.734,-111.937
k, 40354,-3.05,-4.92,-107.046
k, 40355,-3.05,-5.11,-101.982
k, 40356,-3.05,-5.337,-96.941
k, 40357,-3.05,-5.601,-91.918
k, 40358,-3.05,-4.91,-88
l, 40349, 40350
l, 40350, 40351
l, 40351, 40352
l, 40352, 40353
l, 40353, 40354
l, 40354, 40355
l, 40355, 40356
l, 40356, 40357
l, 40357, 40358
lcomb,all
!!!!!!!!SB6钢束
lsel,none
k, 40359,-2.05,-4.337,-128.72
k, 40360,-2.05,-4.602,-126.32
k, 40361,-2.05,-4.602,-124.683
k, 40362,-2.05,-4.602,-123.002
k, 40363,-2.05,-4.649,-118
k, 40364,-2.05,-4.734,-111.937
k, 40365,-2.05,-4.92,-107.046
k, 40366,-2.05,-5.11,-107.982
k, 40367,-2.05,-5.337,-96.941
k, 40368,-2.05,-5.601,-91.918
k, 40369,-2.05,-5.834,-87.9
k, 40370,-2.05,-5.146,-84
l, 40359, 40360
l, 40360, 40361
l, 40361, 40362
l, 40362, 40363
l, 40363, 40364
l, 40364, 40365
l, 40365, 40366
l, 40366, 40367
l, 40367, 40368
l, 40368, 40369
l, 40369, 40370
lcomb,all
!!!!!!!!ST1钢束
lsel,none
k, 40371, -2.35,-0.35,-128.72
k, 40372, -2.35,-0.246,-128.129
k, 40373, -2.35,-0.17,-127.261
k, 40374, -2.35,-0.17,-117.746
k, 40375, -2.35,-0.345,-116.082
k, 40376, -2.35,-1,-113
l, 40371, 40372
l, 40372, 40373
l, 40373, 40374
l, 40374, 40375
l, 40375, 40376
lcomb,all
!!!!!!!!ST2钢束
lsel,none
k, 40377, -1.95,-0.35,-128.72
k, 40378, -1.95,-0.246,-128.129
k, 40379, -1.95,-0.17,-127.261
k, 40380, -1.95,-0.17,-117.746
k, 40381, -1.95,-0.345,-116.082
k, 40382, -1.95,-1,-113
l, 40377, 40378
l, 40378, 40379
l, 40379, 40380
l, 40380, 40381
l, 40381, 40382
lcomb,all
!!!!!!!!ST3钢束
lsel,none
k, 40383, -1.55,-0.35,-128.72
k, 40384, -1.55,-0.246,-128.129
k, 40385, -1.55,-0.17,-127.261
k, 40386, -1.55,-0.17,-117.746
k, 40387, -1.55,-0.345,-116.082
k, 40388, -1.55,-1,-113
l, 40383, 40384
l, 40384, 40385
l, 40385, 40386
l, 40386, 40387
l, 40387, 40388
lcomb,all
!!!!!!!!ST4钢束
lsel,none
k, 40389, -2.35,-0.95,-128.72
k, 40390, -2.35,-0.555,-127.503
k, 40391, -2.35,-0.31,-126.958
k, 40392, -2.35,-0.31,-122.087
k, 40393, -2.35,-0.485,-120.424
k, 40394, -2.35,-1,-118
l, 40389, 40390
l, 40390, 40391
l, 40391, 40392
l, 40392, 40393
l, 40393, 40394
lcomb,all
!!!!!!!!ST5钢束
lsel,none
k, 40395, -1.95,-0.95,-128.72
k, 40396, -1.95,-0.555,-127.503
k, 40397, -1.95,-0.31,-126.958
k, 40398, -1.95,-0.31,-122.087
k, 40399, -1.95,-0.485,-120.424
k, 40400, -1.95,-1,-118
l, 40395, 40396
l, 40396, 40397
l, 40397, 40398
l, 40398, 40399
l, 40399, 40400
lcomb,all
!!!!!!!!ST6钢束(线号:4720)
lsel,none
k, 40401, -1.55,-0.95,-128.72
k, 40402, -1.55,-0.555,-127.503
k, 40403, -1.55,-0.31,-126.958
k, 40404, -1.55,-0.31,-122.087
k, 40405, -1.55,-0.485,-120.424
k, 40406, -1.55,-1,-118
l, 40401, 40402
l, 40402, 40403
l, 40403, 40404
l, 40404, 40405
l, 40405, 40406
lcomb,all
allsel
lsel,s,line,,4643,4720,1!!!!!!4号墩上下河纵向预应力钢束
lsymm,x,4643,4720,1
!!!!!目前有4798根钢束(没有定义竖向预应力钢束和横向预应力钢束)
!!!!!!定义跨中位置的局部坐标系
local,12,0,0,0,-124
!!!!!镜像体和预应力钢束
allsel
vdele,915
vsymm,z,all
lsymm,z,4643,4798,1!!!!!!!! 目前有9588根钢束
!!!!!!定义跨中底板和底板束
!!!!!中跨顶板束(线号9589)
lsel,none
k,41005,-1.55,-0.92,11
k,41006,-1.55,-0.345,8.294
k,41007,-1.55,-0.214,7.467
k,41008,-1.55,-0.17,6.631
k,41009,-1.55,-0.17,0
k,41010,-1.55,-0.17,-6.631
k,41011,-1.55,-0.214,-7.467
k,41012,-1.55,-0.345,-8.294
k,41013,-1.55,-0.92,-11
l,41005,41006
l,41006,41007
l,41007,41008
l,41008,41009
l,41009,41010
l,41010,41011
l,41011,41012
l,41012,41013
lcomb,all
!!!!!定义中跨底板束
!!!!!CB1
lsel,none
K , 41014 ,-2.45,-3.911,11
K , 41015 ,-2.35,-4.663,6.734
K , 41016 ,-2.3,-4.6,0
K , 41017 ,-2.35,-4.663,-6.734
K , 41018 ,-2.45,-3.911,-11
l , 41014 , 41015
l , 41015 , 41016
l , 41016 , 41017
l , 41017 , 41018
lcomb,all
!!!!!CB2
lsel,none
K , 41019 ,-2.45,-4.04,16
K , 41020 ,-2.2,-4.769,11.863
K , 41021 ,-2.05,-4.663,6.734
K , 41022 ,-2.05,-4.6,0
K , 41023 ,-2.05,-4.663,-6.734
K , 41024 ,-2.2,-4.769,-11.863
K , 41025 ,-2.45,-4.04,-16
l , 41019 , 41020
l , 41020 , 41021
l , 41021 , 41022
l , 41022 , 41023
l , 41023 , 41024
l , 41024 , 41025
lcomb,all
!!!!!CB3
lsel,none
K , 41026 ,-2.45,-4.206,21
K , 41027 ,-2.2,-4.92,16.954
K , 41028 ,-2.55,-4.769,11.863
K , 41029 ,-2.55,-4.663,6.734
K , 41030 ,-2.55,-4.6,0
K , 41031 ,-2.55,-4.663,-6.734
K , 41032 ,-2.55,-4.769,-11.863
K , 41033 ,-2.2,-4.92,-16.954
K , 41034 ,-2.45,-4.206,-21
l , 41026 , 41027
l , 41027 , 41028
l , 41028 , 41029
l , 41029 , 41030
l , 41030 , 41031
l , 41031 , 41032
l , 41032 , 41033
l , 41033 , 41034
lcomb,all
!!!!!CB4
lsel,none
K , 41035 ,-2.45,-4.407,26
K , 41036 ,-2.2,-5.11,22.018
K , 41037 ,-1.82,-4.92,16.954
K , 41038 ,-1.8,-4.769,11.863
K , 41039 ,-1.8,-4.663,6.734
K , 41040 ,-1.8,-4.6,0
K , 41041 ,-1.8,-4.663,-6.734
K , 41042 ,-1.8,-4.769,-11.863
K , 41043 ,-1.82,-4.92,-16.954
K , 41044 ,-2.2,-5.11,-22.018
K , 41045 ,-2.45,-4.407,-26
l , 41035 , 41036
l , 41036 , 41037
l , 41037 , 41038
l , 41038 , 41039
l , 41039 , 41040
l , 41040 , 41041
l , 41041 , 41042
l , 41042 , 41043
l , 41043 , 41044
l , 41044 , 41045
lcomb,all
!!!!!CB5
lsel,none
K , 41046 ,-2.45 ,-4.642,31
K , 41047 ,-2.6 ,-5.337,27.059
K , 41048 ,-2.8 ,-5.11,22.018
K , 41049 ,-2.8 ,-4.92,16.954
K , 41050 ,-2.8 ,-4.769,11.863
K , 41051 ,-2.8 ,-4.663,6.734
K , 41052 ,-2.8 ,-4.6,0
K , 41053 ,-2.8 ,-4.663,-6.734
K , 41054 ,-2.8 ,-4.769,-11.863
K , 41055 ,-2.6 ,-4.92,-16.954
K , 41056 ,-2.45 ,-5.11,-22.018
K , 41057 , ,-5.337,-27.059
K , 41058 , ,-4.642,-31
l , 41046 , 41047
l , 41047 , 41048
l , 41048 , 41049
l , 41049 , 41050
l , 41050 , 41051
l , 41051 , 41052
l , 41052 , 41053
l , 41053 , 41054
l , 41054 , 41055
l , 41055 , 41056
l , 41056 , 41057
l , 41057 , 41058
lcomb,all
!!!!!CB6
lsel,none
K , 41059 ,-2.45 ,-4.91,36
K , 41060 ,-2.6 ,-5.601,32.082
K , 41061 ,-1.9 ,-5.337,27.059
K , 41062 ,-1.55 ,-5.11,22.018
K , 41063 ,-1.55 ,-4.92,16.954
K , 41064 ,-1.55 ,-4.76,11.863
K , 41065 ,-1.55 ,-4.663,6.734
K , 41066 ,-1.55 ,-4.6,0
K , 41067 ,-1.55 ,-4.663,-6.734
K , 41068 ,-1.55 ,-4.76,-11.863
K , 41069 ,-1.55 ,-4.92,-16.954
K , 41070 ,-1.55 ,-5.11,-22.018
K , 41071 ,-1.9 ,-5.337,-27.059
K , 41072 ,-2.6 ,-5.601,-32.082
K , 41073 ,-2.45 ,-4.91,-36
l , 41059 , 41060
l , 41060 , 41061
l , 41061 , 41062
l , 41062 , 41063
l , 41063 , 41064
l , 41064 , 41065
l , 41065 , 41066
l , 41066 , 41067
l , 41067 , 41068
l , 41068 , 41069
l , 41069 , 41070
l , 41070 , 41071
l , 41071 , 41072
l , 41072 , 41073
lcomb,all
!!!!!CB7
lsel,none
K , 41074 ,-2.45 ,-5.146,40
K , 41075 ,-2.7 ,-5.834,36.1
K , 41076 ,-2.9 ,-5.601,32.082
K , 41077 ,-3.05 ,-5.337,27.059
K , 41078 ,-3.05 ,-5.11,22.018
K , 41079 ,-3.05 ,-4.92,16.954
K , 41080 ,-3.05 ,-4.769,11.863
K , 41081 ,-3.05 ,-4.663,6.734
K , 41082 ,-3.05 ,-4.6,0
K , 41083 ,-3.05 ,-4.663,-6.734
K , 41084 ,-3.05 ,-4.769,-11.863
K , 41085 ,-3.05 ,-4.92,-16.954
K , 41086 ,-3.05 ,-5.11,-22.018
K , 41087 ,-3.05 ,-5.337,-27.059
K , 41088 ,-2.9 ,-5.601,-32.082
K , 41089 ,-2.7 ,-5.834,-36.1
K , 41090 ,-2.45 ,-5.146,-40
l , 41074 , 41075
l , 41075 , 41076
l , 41076 , 41077
l , 41077 , 41078
l , 41078 , 41079
l , 41079 , 41080
l , 41080 , 41081
l , 41081 , 41082
l , 41082 , 41083
l , 41083 , 41084
l , 41084 , 41085
l , 41085 , 41086
l , 41086 , 41087
l , 41087 , 41088
l , 41088 , 41089
l , 41089 , 41090
lcomb,all
!!!!!CB8(线号11905)
lsel,none
K , 41091 ,-2.45 ,-5.403,44
K , 41092 ,-2.3 ,-6.091,40.098
K , 41093 ,-1.85 ,-5.834,36.1
K , 41094 ,-1.32 ,-5.601,32.082
K , 41095 ,-1.3 ,-5.337,27.059
K , 41096 ,-1.3 ,-5.11,22.018
K , 41097 ,-1.3 ,-4.92,16.954
K , 41098 ,-1.3 ,-4.769,11.863
K , 41099 ,-1.3 ,-4.663,6.734
K , 41100 ,-1.3 ,-4.6,0
K , 41101 ,-1.3 ,-4.663,-6.734
K , 41102 ,-1.3 ,-4.769,-11.863
K , 41103 ,-1.3 ,-4.92,-16.954
K , 41104 ,-1.3 ,-5.11,-22.018
K , 41105 ,-1.3 ,-5.337,-27.059
K , 41106 ,-1.32 ,-5.601,-32.082
K , 41107 ,-1.85 ,-5.834,-36.1
K , 41108 ,-2.3 ,-6.091,-40.098
K , 41109 ,-2.45 ,-5.403,-44
l , 41091 , 41092
l , 41092 , 41093
l , 41093 , 41094
l , 41094 , 41095
l , 41095 , 41096
l , 41096 , 41097
l , 41097 , 41098
l , 41098 , 41099
l , 41099 , 41100
l , 41100 , 41101
l , 41101 , 41102
l , 41102 , 41103
l , 41103 , 41104
l , 41104 , 41105
l , 41105 , 41106
l , 41106 , 41107
l , 41107 , 41108
l , 41108 , 41109
lcomb,all
!!!!!!镜像跨中钢束
lsel,s,line,,9589,9597,1
lsymm,x,9589,9597,1
!!!!!!预应力钢束定义完毕
!!!!!!建立墩柱
k,50001,0,-16,124
k,50002,0,-100,124
l,50001,50002
asel,s,loc,y,-16
vdrag,all,,,,,,9607
!!!!!!定义钢束材料号
!!!!!!纵向预应力钢束材料号(T1-W30)
allsel
lsel , s , line , , 4643 , 4721 , 78
lsel , a , line , , 9433 , 9511 , 78
latt , 2 , 5 , 2
cm , zxgs 1 , line
allsel
lsel , s , line , , 4644 , 4722 , 78
lsel , a , line , , 9434 , 9512 , 78
latt , 2 , 5 , 2
cm , zxgs 2 , line
allsel
lsel , s , line , , 4645 , 4723 , 78
lsel , a , line , , 9435 , 9513 , 78
latt , 2 , 5 , 2
cm , zxgs 3 , line
allsel
lsel , s , line , , 4646 , 4724 , 78
lsel , a , line , , 9436 , 9514 , 78
latt , 2 , 5 , 2
cm , zxgs 4 , line
allsel
lsel , s , line , , 4647 , 4725 , 78
lsel , a , line , , 9437 , 9515 , 78
latt , 2 , 5 , 2
cm , zxgs 5 , line
allsel
lsel , s , line , , 4648 , 4726 , 78
lsel , a , line , , 9438 , 9516 , 78
latt , 2 , 5 , 2
cm , zxgs 6 , line
allsel
lsel , s , line , , 4649 , 4727 , 78
lsel , a , line , , 9439 , 9517 , 78
latt , 2 , 5 , 2
cm , zxgs 7 , line
allsel
lsel , s , line , , 4650 , 4728 , 78
lsel , a , line , , 9440 , 9518 , 78
latt , 2 , 5 , 2
cm , zxgs 8 , line
allsel
lsel , s , line , , 4651 , 4729 , 78
lsel , a , line , , 9441 , 9519 , 78
latt , 2 , 5 , 2
cm , zxgs 9 , line
allsel
lsel , s , line , , 4652 , 4730 , 78
lsel , a , line , , 9442 , 9520 , 78
latt , 2 , 5 , 2
cm , zxgs 10 , line
allsel
lsel , s , line , , 4653 , 4731 , 78
lsel , a , line , , 9443 , 9521 , 78
latt , 2 , 5 , 2
cm , zxgs 11 , line
allsel
lsel , s , line , , 4654 , 4732 , 78
lsel , a , line , , 9444 , 9522 , 78
latt , 2 , 5 , 2
cm , zxgs 12 , line
allsel
lsel , s , line , , 4655 , 4733 , 78
lsel , a , line , , 9445 , 9523 , 78
latt , 2 , 5 , 2
cm , zxgs 13 , line
allsel
lsel , s , line , , 4656 , 4734 , 78
lsel , a , line , , 9446 , 9524 , 78
latt , 2 , 5 , 2
cm , zxgs 14 , line
allsel
lsel , s , line , , 4657 , 4735 , 78
lsel , a , line , , 9447 , 9525 , 78
latt , 2 , 5 , 2
cm , zxgs 15 , line
allsel
lsel , s , line , , 4658 , 4736 , 78
lsel , a , line , , 9448 , 9526 , 78
latt , 2 , 5 , 2
cm , zxgs 16 , line
allsel
lsel , s , line , , 4659 , 4737 , 78
lsel , a , line , , 9449 , 9527 , 78
latt , 2 , 5 , 2
cm , zxgs 17 , line
allsel
lsel , s , line , , 4660 , 4738 , 78
lsel , a , line , , 9450 , 9528 , 78
latt , 2 , 5 , 2
cm , zxgs 18 , line
allsel
lsel , s , line , , 4661 , 4739 , 78
lsel , a , line , , 9451 , 9529 , 78
latt , 2 , 5 , 2
cm , zxgs 19 , line
allsel
lsel , s , line , , 4662 , 4740 , 78
lsel , a , line , , 9452 , 9530 , 78
latt , 2 , 5 , 2
cm , zxgs 20 , line
allsel
lsel , s , line , , 4663 , 4741 , 78
lsel , a , line , , 9453 , 9531 , 78
latt , 2 , 5 , 2
cm , zxgs 21 , line
allsel
lsel , s , line , , 4664 , 4742 , 78
lsel , a , line , , 9454 , 9532 , 78
latt , 2 , 5 , 2
cm , zxgs 22 , line
allsel
lsel , s , line , , 4665 , 4743 , 78
lsel , a , line , , 9455 , 9533 , 78
latt , 2 , 5 , 2
cm , zxgs 23 , line
allsel
lsel , s , line , , 4666 , 4744 , 78
lsel , a , line , , 9456 , 9534 , 78
latt , 2 , 5 , 2
cm , zxgs 24 , line
allsel
lsel , s , line , , 4667 , 4745 , 78
lsel , a , line , , 9457 , 9535 , 78
latt , 2 , 5 , 2
cm , zxgs 25 , line
allsel
lsel , s , line , , 4668 , 4746 , 78
lsel , a , line , , 9458 , 9536 , 78
latt , 2 , 5 , 2
cm , zxgs 26 , line
allsel
lsel , s , line , , 4669 , 4747 , 78
lsel , a , line , , 9459 , 9537 , 78
latt , 2 , 5 , 2
cm , zxgs 27 , line
allsel
lsel , s , line , , 4670 , 4748 , 78
lsel , a , line , , 9460 , 9538 , 78
latt , 2 , 5 , 2
cm , zxgs 28 , line
allsel
lsel , s , line , , 4671 , 4749 , 78
lsel , a , line , , 9461 , 9539 , 78
latt , 2 , 5 , 2
cm , zxgs 29 , line
allsel
lsel , s , line , , 4672 , 4750 , 78
lsel , a , line , , 9462 , 9540 , 78
latt , 2 , 5 , 2
cm , zxgs 30 , line
allsel
lsel , s , line , , 4673 , 4751 , 78
lsel , a , line , , 9463 , 9541 , 78
latt , 2 , 5 , 2
cm , zxgs 31 , line
allsel
lsel , s , line , , 4674 , 4752 , 78
lsel , a , line , , 9464 , 9542 , 78
latt , 2 , 5 , 2
cm , zxgs 32 , line
allsel
lsel , s , line , , 4675 , 4753 , 78
lsel , a , line , , 9465 , 9543 , 78
latt , 2 , 5 , 2
cm , zxgs 33 , line
allsel
lsel , s , line , , 4676 , 4754 , 78
lsel , a , line , , 9466 , 9544 , 78
latt , 2 , 5 , 2
cm , zxgs 34 , line
allsel
lsel , s , line , , 4677 , 4755 , 78
lsel , a , line , , 9467 , 9545 , 78
latt , 2 , 5 , 2
cm , zxgs 35 , line
allsel
lsel , s , line , , 4678 , 4756 , 78
lsel , a , line , , 9468 , 9546 , 78
latt , 2 , 5 , 2
cm , zxgs 36 , line
allsel
lsel , s , line , , 4679 , 4757 , 78
lsel , a , line , , 9469 , 9547 , 78
latt , 2 , 5 , 2
cm , zxgs 37 , line
allsel
lsel , s , line , , 4680 , 4758 , 78
lsel , a , line , , 9470 , 9548 , 78
latt , 2 , 5 , 2
cm , zxgs 38 , line
allsel
lsel , s , line , , 4681 , 4759 , 78
lsel , a , line , , 9471 , 9549 , 78
latt , 2 , 5 , 2
cm , zxgs 39 , line
allsel
lsel , s , line , , 4682 , 4760 , 78
lsel , a , line , , 9472 , 9550 , 78
latt , 2 , 5 , 2
cm , zxgs 40 , line
allsel
lsel , s , line , , 4683 , 4761 , 78
lsel , a , line , , 9473 , 9551 , 78
latt , 2 , 5 , 2
cm , zxgs 41 , line
allsel
lsel , s , line , , 4684 , 4762 , 78
lsel , a , line , , 9474 , 9552 , 78
latt , 2 , 5 , 2
cm , zxgs 42 , line
allsel
lsel , s , line , , 4685 , 4763 , 78
lsel , a , line , , 9475 , 9553 , 78
latt , 2 , 5 , 2
cm , zxgs 43 , line
allsel
lsel , s , line , , 4686 , 4764 , 78
lsel , a , line , , 9476 , 9554 , 78
latt , 2 , 5 , 2
cm , zxgs 44 , line
allsel
lsel , s , line , , 4687 , 4765 , 78
lsel , a , line , , 9477 , 9555 , 78
latt , 2 , 5 , 2
cm , zxgs 45 , line
allsel
lsel , s , line , , 4688 , 4766 , 78
lsel , a , line , , 9478 , 9556 , 78
latt , 2 , 5 , 2
cm , zxgs 46 , line
allsel
lsel , s , line , , 4689 , 4767 , 78
lsel , a , line , , 9479 , 9557 , 78
latt , 2 , 5 , 2
cm , zxgs 47 , line
allsel
lsel , s , line , , 4690 , 4768 , 78
lsel , a , line , , 9480 , 9558 , 78
latt , 2 , 5 , 2
cm , zxgs 48 , line
allsel
lsel , s , line , , 4691 , 4769 , 78
lsel , a , line , , 9481 , 9559 , 78
latt , 2 , 5 , 2
cm , zxgs 49 , line
allsel
lsel , s , line , , 4692 , 4770 , 78
lsel , a , line , , 9482 , 9560 , 78
latt , 2 , 5 , 2
cm , zxgs 50 , line
allsel
lsel , s , line , , 4693 , 4771 , 78
lsel , a , line , , 9483 , 9561 , 78
latt , 2 , 5 , 2
cm , zxgs 51 , line
allsel
lsel , s , line , , 4694 , 4772 , 78
lsel , a , line , , 9484 , 9562 , 78
latt , 2 , 5 , 2
cm , zxgs 52 , line
allsel
lsel , s , line , , 4695 , 4773 , 78
lsel , a , line , , 9485 , 9563 , 78
latt , 2 , 5 , 2
cm , zxgs 53 , line
allsel
lsel , s , line , , 4696 , 4774 , 78
lsel , a , line , , 9486 , 9564 , 78
latt , 2 , 5 , 2
cm , zxgs 54 , line
allsel
lsel , s , line , , 4697 , 4775 , 78
lsel , a , line , , 9487 , 9565 , 78
latt , 2 , 5 , 2
cm , zxgs 55 , line
allsel
lsel , s , line , , 4698 , 4776 , 78
lsel , a , line , , 9488 , 9566 , 78
latt , 2 , 5 , 2
cm , zxgs 56 , line
allsel
lsel , s , line , , 4699 , 4777 , 78
lsel , a , line , , 9489 , 9567 , 78
latt , 2 , 5 , 2
cm , zxgs 57 , line
allsel
lsel , s , line , , 4700 , 4778 , 78
lsel , a , line , , 9490 , 9568 , 78
latt , 2 , 5 , 2
cm , zxgs 58 , line
allsel
lsel , s , line , , 4701 , 4779 , 78
lsel , a , line , , 9491 , 9569 , 78
latt , 2 , 5 , 2
cm , zxgs 59 , line
allsel
lsel , s , line , , 4702 , 4780 , 78
lsel , a , line , , 9492 , 9570 , 78
latt , 2 , 5 , 2
cm , zxgs 60 , line
allsel
lsel , s , line , , 4703 , 4781 , 78
lsel , a , line , , 9493 , 9571 , 78
latt , 2 , 5 , 2
cm , zxgs 61 , line
allsel
lsel , s , line , , 4704 , 4782 , 78
lsel , a , line , , 9494 , 9572 , 78
latt , 2 , 5 , 2
cm , zxgs 62 , line
allsel
lsel , s , line , , 4705 , 4783 , 78
lsel , a , line , , 9495 , 9573 , 78
latt , 2 , 5 , 2
cm , zxgs 63 , line
allsel
lsel , s , line , , 4706 , 4784 , 78
lsel , a , line , , 9496 , 9574 , 78
latt , 2 , 5 , 2
cm , zxgs 64 , line
allsel
lsel , s , line , , 4707 , 4785 , 78
lsel , a , line , , 9497 , 9575 , 78
latt , 2 , 5 , 2
cm , zxgs 65 , line
allsel
lsel , s , line , , 4708 , 4786 , 78
lsel , a , line , , 9498 , 9576 , 78
latt , 2 , 5 , 2
cm , zxgs 66 , line
allsel
!!!!!!!!!!!!!!!!边跨纵向底板束材料号定义
lsel , s , line , , 4709 , 4787 , 78
lsel , a , line , , 9499 , 9577 , 78
latt , 2 , 2 , 2
cm , zxgs 67 , line
allsel
lsel , s , line , , 4710 , 4788 , 78
lsel , a , line , , 9500 , 9578 , 78
latt , 2 , 2 , 2
cm , zxgs 68 , line
allsel
lsel , s , line , , 4711 , 4789 , 78
lsel , a , line , , 9501 , 9579 , 78
latt , 2 , 2 , 2
cm , zxgs 69 , line
allsel
lsel , s , line , , 4712 , 4790 , 78
lsel , a , line , , 9502 , 9580 , 78
latt , 2 , 2 , 2
cm , zxgs 70 , line
allsel
lsel , s , line , , 4713 , 4791 , 78
lsel , a , line , , 9503 , 9581 , 78
latt , 2 , 2 , 2
cm , zxgs 71 , line
allsel
lsel , s , line , , 4714 , 4792 , 78
lsel , a , line , , 9504 , 9582 , 78
latt , 2 , 2 , 2
cm , zxgs 72 , line
allsel
!!!!!!!!!!!!!!!!边跨纵向顶板束材料号定义
lsel , s , line , , 4715 , 4793 , 78
lsel , a , line , , 9505 , 9583 , 78
latt , 2 , 3 , 2
cm , zxgs 73 , line
allsel
lsel , s , line , , 4716 , 4794 , 78
lsel , a , line , , 9506 , 9584 , 78
latt , 2 , 3 , 2
cm , zxgs 74 , line
allsel
lsel , s , line , , 4717 , 4795 , 78
lsel , a , line , , 9507 , 9585 , 78
latt , 2 , 3 , 2
cm , zxgs 75 , line
allsel
lsel , s , line , , 4718 , 4796 , 78
lsel , a , line , , 9508 , 9586 , 78
latt , 2 , 3 , 2
cm , zxgs 76 , line
allsel
lsel , s , line , , 4719 , 4797 , 78
lsel , a , line , , 9509 , 9587 , 78
latt , 2 , 3 , 2
cm , zxgs 77 , line
allsel
lsel , s , line , , 4720 , 4798 , 78
lsel , a , line , , 9510 , 9588 , 78
latt , 2 , 3 , 2
cm , zxgs 78 , line
allsel
!!!!!!!!!!竖向预应力钢束材料号定义
!!!!!!!!!!横向预应力钢束材料号定义
!!!!!!!!!中跨顶板和底板束钢束材料号定义
allsel
lsel , s , line , , 9589 , 9598 , 9
latt , 2 , 2 , 2
cm , zkgs 114 , line
allsel
lsel , s , line , , 9590 , 9599 , 9
latt , 2 , 6 , 2
cm , zkgs 115 , line
allsel
lsel , s , line , , 9591 , 9600 , 9
latt , 2 , 6 , 2
cm , zkgs 116 , line
allsel
lsel , s , line , , 9592 , 9601 , 9
latt , 2 , 6 , 2
cm , zkgs 117 , line
allsel
lsel , s , line , , 9593 , 9602 , 9
latt , 2 , 6 , 2
cm , zkgs 118 , line
allsel
lsel , s , line , , 9594 , 9603 , 9
latt , 2 , 6 , 2
cm , zkgs 119 , line
allsel
lsel , s , line , , 9595 , 9604 , 9
latt , 2 , 6 , 2
cm , zkgs 120 , line
allsel
lsel , s , line , , 9596 , 9605 , 9
latt , 2 , 6 , 2
cm , zkgs 121 , line
allsel
lsel , s , line , , 9597 , 9606 , 9
latt , 2 , 6 , 2
cm , zkgs 122 , line
allsel
!!!!!!!!!!按照块件号分钢束
allsel
cmsel , s , zxgs 1
cmsel , a , zxgs 37
cm , gs 1 , line
allsel
cmsel , s , zxgs 2
cmsel , a , zxgs 38
cm , gs 2 , line
allsel
cmsel , s , zxgs 3
cmsel , a , zxgs 39
cm , gs 3 , line
allsel
cmsel , s , zxgs 4
cmsel , a , zxgs 40
cm , gs 4 , line
allsel
cmsel , s , zxgs 5
cmsel , a , zxgs 41
cm , gs 5 , line
allsel
cmsel , s , zxgs 6
cmsel , a , zxgs 42
cm , gs 6 , line
allsel
cmsel , s , zxgs 7
cmsel , a , zxgs 43
cm , gs 7 , line
allsel
cmsel , s , zxgs 8
cmsel , a , zxgs 44
cm , gs 8 , line
allsel
cmsel , s , zxgs 9
cmsel , a , zxgs 45
cm , gs 9 , line
allsel
cmsel , s , zxgs 10
cmsel , a , zxgs 46
cm , gs 10 , line
allsel
cmsel , s , zxgs 11
cmsel , a , zxgs 47
cm , gs 11 , line
allsel
cmsel , s , zxgs 12
cmsel , a , zxgs 48
cm , gs 12 , line
allsel
cmsel , s , zxgs 13
cmsel , a , zxgs 49
cm , gs 13 , line
allsel
cmsel , s , zxgs 14
cmsel , a , zxgs 50
cm , gs 14 , line
allsel
cmsel , s , zxgs 15
cmsel , a , zxgs 51
cm , gs 15 , line
allsel
cmsel , s , zxgs 16
cmsel , a , zxgs 52
cm , gs 16 , line
allsel
cmsel , s , zxgs 17
cmsel , a , zxgs 53
cm , gs 17 , line
allsel
cmsel , s , zxgs 18
cmsel , a , zxgs 54
cm , gs 18 , line
allsel
cmsel , s , zxgs 19
cmsel , a , zxgs 55
cm , gs 19 , line
allsel
cmsel , s , zxgs 20
cmsel , a , zxgs 56
cm , gs 20 , line
allsel
cmsel , s , zxgs 21
cmsel , a , zxgs 57
cm , gs 21 , line
allsel
cmsel , s , zxgs 22
cmsel , a , zxgs 58
cm , gs 22 , line
allsel
cmsel , s , zxgs 23
cmsel , a , zxgs 59
cm , gs 23 , line
allsel
cmsel , s , zxgs 24
cmsel , a , zxgs 60
cm , gs 24 , line
allsel
cmsel , s , zxgs 25
cmsel , a , zxgs 61
cm , gs 25 , line
allsel
cmsel , s , zxgs 26
cmsel , a , zxgs 62
cm , gs 26 , line
allsel
cmsel , s , zxgs 27
cmsel , a , zxgs 63
cm , gs 27 , line
allsel
cmsel , s , zxgs 28
cmsel , a , zxgs 64
cm , gs 28 , line
allsel
cmsel , s , zxgs 29
cmsel , a , zxgs 65
cm , gs 29 , line
allsel
cmsel , s , zxgs 30
cmsel , a , zxgs 66
cm , gs 30 , line
allsel
cmsel , s , zxgs 31
cmsel , a , zxgs 32
cm , gs 31 , line
allsel
cmsel , s , zxgs 33
cmsel , a , zxgs 34
cm , gs 32 , line
allsel
cmsel , s , zxgs 35
cmsel , a , zxgs 36
cm , gs 33 , line
allsel
cmsel , s , zxgs 67
cmsel , a , zxgs 68
cmsel , a , zxgs 69
cmsel , a , zxgs 70
cmsel , a , zxgs 71
cmsel , a , zxgs 72
cm , gs 34 , line
allsel
cmsel , s , zxgs 73
cmsel , a , zxgs 74
cmsel , a , zxgs 75
cmsel , a , zxgs 76
cmsel , a , zxgs 77
cmsel , a , zxgs 78
cm , gs 35 , line
allsel
cmsel , s , zkgs 114
cmsel , a , zkgs 115
cmsel , a , zkgs 116
cm , gs 36 , line
allsel
cmsel , s , zkgs 117
cmsel , a , zkgs 118
cm , gs 37 , line
allsel
cmsel , s , zkgs 119
cmsel , a , zkgs 120
cm , gs 38 , line
allsel
cmsel , s , zkgs 121
cmsel , a , zkgs 122
cm , gs 39 , line
allsel
allsel
!!!!!!定义块件号
vsel , s , loc , z , 115.5 , 132.5
vsel , a , loc , z , -132.5 , -115.5
vsel , u , loc , y , -16 , -100
cm , kuai 0 , volu
allsel
vsel , s , loc , z , 132.5 , 135
vsel , a , loc , z , 115.5 , 113
vsel , a , loc , z , -115.5 , -113
vsel , a , loc , z , -132.5 , -135
cm , kuai 1 , volu
allsel
vsel , s , loc , z , 135 , 137.5
vsel , a , loc , z , 113 , 110.5
vsel , a , loc , z , -113 , -110.5
vsel , a , loc , z , -135 , -137.5
cm , kuai 2 , volu
allsel
vsel , s , loc , z , 137.5 , 140
vsel , a , loc , z , 110.5 , 108
vsel , a , loc , z , -110.5 , -108
vsel , a , loc , z , -137.5 , -140
cm , kuai 3 , volu
allsel
vsel , s , loc , z , 140 , 142.5
vsel , a , loc , z , 108 , 105.5
vsel , a , loc , z , -108 , -105.5
vsel , a , loc , z , -140 , -142.5
cm , kuai 4 , volu
allsel
vsel , s , loc , z , 142.5 , 145
vsel , a , loc , z , 105.5 , 103
vsel , a , loc , z , -105.5 , -103
vsel , a , loc , z , -142.5 , -145
cm , kuai 5 , volu
allsel
vsel , s , loc , z , 145 , 147.5
vsel , a , loc , z , 103 , 100.5
vsel , a , loc , z , -103 , -100.5
vsel , a , loc , z , -145 , -147.5
cm , kuai 6 , volu
allsel
vsel , s , loc , z , 147.5 , 150
vsel , a , loc , z , 100.5 , 98
vsel , a , loc , z , -100.5 , -98
vsel , a , loc , z , -147.5 , -150
cm , kuai 7 , volu
allsel
vsel , s , loc , z , 150 , 152.5
vsel , a , loc , z , 98 , 95.5
vsel , a , loc , z , -98 , -95.5
vsel , a , loc , z , -150 , -152.5
cm , kuai 8 , volu
allsel
vsel , s , loc , z , 152.5 , 155
vsel , a , loc , z , 95.5 , 93
vsel , a , loc , z , -95.5 , -93
vsel , a , loc , z , -152.5 , -155
cm , kuai 9 , volu
allsel
vsel , s , loc , z , 155 , 158
vsel , a , loc , z , 93 , 90
vsel , a , loc , z , -93 , -90
vsel , a , loc , z , -155 , -158
cm , kuai 10 , volu
allsel
vsel , s , loc , z , 158 , 161
vsel , a , loc , z , 90 , 87
vsel , a , loc , z , -90 , -87
vsel , a , loc , z , -158 , -161
cm , kuai 11 , volu
allsel
vsel , s , loc , z , 161 , 164
vsel , a , loc , z , 87 , 84
vsel , a , loc , z , -87 , -84
vsel , a , loc , z , -161 , -164
cm , kuai 12 , volu
allsel
vsel , s , loc , z , 164 , 167
vsel , a , loc , z , 84 , 81
vsel , a , loc , z , -84 , -81
vsel , a , loc , z , -164 , -167
cm , kuai 13 , volu
allsel
vsel , s , loc , z , 167 , 170
vsel , a , loc , z , 81 , 78
vsel , a , loc , z , -81 , -78
vsel , a , loc , z , -167 , -170
cm , kuai 14 , volu
allsel
vsel , s , loc , z , 170 , 173
vsel , a , loc , z , 78 , 75
vsel , a , loc , z , -78 , -75
vsel , a , loc , z , -170 , -173
cm , kuai 15 , volu
allsel
vsel , s , loc , z , 173 , 176
vsel , a , loc , z , 75 , 72
vsel , a , loc , z , -75 , -72
vsel , a , loc , z , -173 , -176
cm , kuai 16 , volu
allsel
vsel , s , loc , z , 176 , 179
vsel , a , loc , z , 72 , 69
vsel , a , loc , z , -72 , -69
vsel , a , loc , z , -176 , -179
cm , kuai 17 , volu
allsel
vsel , s , loc , z , 179 , 182
vsel , a , loc , z , 69 , 66
vsel , a , loc , z , -69 , -66
vsel , a , loc , z , -179 , -182
cm , kuai 18 , volu
allsel
vsel , s , loc , z , 182 , 185
vsel , a , loc , z , 66 , 63
vsel , a , loc , z , -66 , -63
vsel , a , loc , z , -182 , -185
cm , kuai 19 , volu
allsel
vsel , s , loc , z , 185 , 188
vsel , a , loc , z , 63 , 60
vsel , a , loc , z , -63 , -60
vsel , a , loc , z , -185 , -188
cm , kuai 20 , volu
allsel
vsel , s , loc , z , 188 , 192
vsel , a , loc , z , 60 , 56
vsel , a , loc , z , -60 , -56
vsel , a , loc , z , -188 , -192
cm , kuai 21 , volu
allsel
vsel , s , loc , z , 192 , 196
vsel , a , loc , z , 56 , 52
vsel , a , loc , z , -56 , -52
vsel , a , loc , z , -192 , -196
cm , kuai 22 , volu
allsel
vsel , s , loc , z , 196 , 200
vsel , a , loc , z , 52 , 48
vsel , a , loc , z , -52 , -48
vsel , a , loc , z , -196 , -200
cm , kuai 23 , volu
allsel
vsel , s , loc , z , 200 , 204
vsel , a , loc , z , 48 , 44
vsel , a , loc , z , -48 , -44
vsel , a , loc , z , -200 , -204
cm , kuai 24 , volu
allsel
vsel , s , loc , z , 204 , 208
vsel , a , loc , z , 44 , 40
vsel , a , loc , z , -44 , -40
vsel , a , loc , z , -204 , -208
cm , kuai 25 , volu
allsel
vsel , s , loc , z , 208 , 212
vsel , a , loc , z , 40 , 36
vsel , a , loc , z , -40 , -36
vsel , a , loc , z , -208 , -212
cm , kuai 26 , volu
allsel
vsel , s , loc , z , 212 , 217
vsel , a , loc , z , 36 , 31
vsel , a , loc , z , -36 , -31
vsel , a , loc , z , -212 , -217
cm , kuai 27 , volu
allsel
vsel , s , loc , z , 217 , 222
vsel , a , loc , z , 31 , 26
vsel , a , loc , z , -31 , -26
vsel , a , loc , z , -217 , -222
cm , kuai 28 , volu
allsel
vsel , s , loc , z , 222 , 227
vsel , a , loc , z , 26 , 21
vsel , a , loc , z , -26 , -21
vsel , a , loc , z , -222 , -227
cm , kuai 29 , volu
allsel
vsel , s , loc , z , 227 , 232
vsel , a , loc , z , 21 , 16
vsel , a , loc , z , -21 , -16
vsel , a , loc , z , -227 , -232
cm , kuai 30 , volu
allsel
vsel , s , loc , z , 232 , 237
vsel , a , loc , z , 16 , 11
vsel , a , loc , z , -16 , -11
vsel , a , loc , z , -232 , -237
cm , kuai 31 , volu
allsel
vsel , s , loc , z , 237 , 242
vsel , a , loc , z , 11 , 6
vsel , a , loc , z , -11 , -6
vsel , a , loc , z , -237 , -242
cm , kuai 32 , volu
allsel
vsel , s , loc , z , 242 , 247
vsel , a , loc , z , 6 , 1
vsel , a , loc , z , -6 , -1
vsel , a , loc , z , -242 , -247
cm , kuai 33 , volu
allsel
vsel , s , loc , z , 249 , 253.72
vsel , a , loc , z , -249 , -253.72
cm , biankua xiaojiao , volu
allsel
vsel , s , loc , z , 247 , 248
vsel , a , loc , z , -247 , -248
cm , biankua helong , volu
allsel
vsel , s , loc , z , 1 , 0
vsel , a , loc , z , -1 , 0
cm , zhongkua helong , volu
allsel
vsel,s,loc,y,-100,-16
cm,qiaodun,volu
!!!!!生成钢束有限元
allsel
esize,1.5
vdele,469,470,1
vdele,1384,1385,1
vmesh,all
allsel
lsel , s , , , gs 1
lsel , a , , , gs 2
lsel , a , , , gs 3
lsel , a , , , gs 4
lsel , a , , , gs 5
lsel , a , , , gs 6
lsel , a , , , gs 7
lsel , a , , , gs 8
lsel , a , , , gs 9
lsel , a , , , gs 10
lsel , a , , , gs 11
lsel , a , , , gs 12
lsel , a , , , gs 13
lsel , a , , , gs 14
lsel , a , , , gs 15
lsel , a , , , gs 16
lsel , a , , , gs 17
lsel , a , , , gs 18
lsel , a , , , gs 19
lsel , a , , , gs 20
lsel , a , , , gs 21
lsel , a , , , gs 22
lsel , a , , , gs 23
lsel , a , , , gs 24
lsel , a , , , gs 25
lsel , a , , , gs 26
lsel , a , , , gs 27
lsel , a , , , gs 28
lsel , a , , , gs 29
lsel , a , , , gs 30
lsel , a , , , gs 31
lsel , a , , , gs 32
lsel , a , , , gs 33
lsel , a , , , gs 34
lsel , a , , , gs 35
lsel , a , , , gs 36
lsel , a , , , gs 37
lsel , a , , , gs 38
lsel , a , , , gs 39
esize,1.5
lmesh,all
nummrg,all
numcmp,all
!!!!!施加墩底约束
nsel,s,loc,y,-100
d,all,all
allsel
/solu
eqslv,pcg,,2.5
!!!!!定义施工阶段
!施工桥墩
tim,6
nlgeom,on
nropt,full
estif,1e-5 !指定矩阵系数
allsel
ekill,all
allsel
vsel , s , volu , , qiaodun
vsel , a , volu , , kuai 0
vsel , a , volu , , kuai 1
vsel , a , volu , , kuai 2
vsel , a , volu , , kuai 3
vsel , a , volu , , kuai 4
eslv , s
ealive , all
allsel
lsel , s , line , , gs 1
lsel , a , line , , gs 2
lsel , a , line , , gs 3
lsel , a , line , , gs 4
esll , s
ealive , all
ddele , all , all
esel , s , live
nsle , s
nsel , inve
d , all , all , 0
allsel
nsel , s , loc , y , -100
d , all , all
allsel
solve
save
