查看: 63|回复: 0
[命令和APDL] 输入地震波,谁来帮我解决一下啊
发表于 2012-11-1 21:09:59 | 显示全部楼层 |阅读模式 来自 山东青岛
*** ERROR ***                           CP =      22.620   TIME= 19:19:53
Subscript range error.  Parameter TJY is dimensioned as 2 x 500, but
location 2 x 501 is being requested
*** ERROR ***                           CP =      22.932   TIME= 19:20:11
No data exists for dimensioned parameter TJY with subscripts 2 x 501.
*** ERROR ***                           CP =      22.979   TIME= 19:20:17
Subscript range error.  Parameter TJX is dimensioned as 2 x 500, but
*** ERROR ***                           CP =      23.010   TIME= 19:20:24
No data exists for dimensioned parameter TJX with subscripts 2 x 501.
*** ERROR ***                           CP =      23.041   TIME= 19:20:25
The above error occurred processing field= TJX(2,T)
  Line= acel,tjx(2,t),tjy(2,t).
这是做了一个框架结构,最后施加地震波。进行载荷步的设置及求解时出现这样的问题。我就是定义了500个数据啊,怎么出来的501,location指哪啊?
GMT+8, 2024-4-28 00:34 , Processed in 0.025364 second(s), 11 queries , Gzip On, MemCache On.
