这个ansys模型和fluent一起算。算出来的结果始终是错误的!不知道模型哪里错了
求高手给看看
个人感觉solid95和shell93的处理上有点问题
/BATCH
! /COM,ANSYS RELEASE 11.0SP1 UP20070830 21:23:52 11/06/2012
/input,menust,tmp,'',,,,,,,,,,,,,,,,1
! /GRA,POWER
! /GST,ON
! /PLO,INFO,3
! /GRO,CURL,ON
! /CPLANE,1
! /REPLOT,RESIZE
WPSTYLE,,,,,,,,0
/PREP7
ET,1,SOLID95
ET,2,SHELL93
R,1,1e-10,1e-10,1e-10,1e-10, , ,
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,1e8
MPDATA,PRXY,1,,0.49
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,1,,1000
BLOCK,-0.001,0.001,-0.022,0.026,-0.024,0.024,
! /USER, 1
! /VIEW, 1, 0.631978449000 , 0.121777850131 , 0.765358344318
! /ANG, 1, 3.00273654080
! /REPLO
FLST,5,8,4,ORDE,5
FITEM,5,1
FITEM,5,3
FITEM,5,6
FITEM,5,8
FITEM,5,-12
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,20, , , , ,1
FLST,5,4,4,ORDE,4
FITEM,5,2
FITEM,5,4
FITEM,5,-5
FITEM,5,7
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,2, , , , ,1
MSHAPE,0,3D
MSHKEY,1
CM,_Y,VOLU
VSEL, , , , 1
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
FLST,5,5,5,ORDE,4
FITEM,5,1
FITEM,5,-3
FITEM,5,5
FITEM,5,-6
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT, 1, 1, 2, 0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
MSHAPE,0,2D
FLST,5,5,5,ORDE,4
FITEM,5,1
FITEM,5,-3
FITEM,5,5
FITEM,5,-6
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
/UI,MESH,OFF
ANTYPE,4
TRNOPT,FULL
LUMPM,0
*SET,deltatime,1
FLST,5,5,5,ORDE,4
FITEM,5,1
FITEM,5,-3
FITEM,5,5
FITEM,5,-6
ASEL,S, , ,P51X
NSLA,S,1
CM,nsurface,NODE
ESEL,S,TYPE,,2
CM,wallsurface,ELEM
! /MREP,EPLOT
NSEL,ALL
! NPLOT
! /VIEW,1,,,1
! /ANG,1
! /REP,FAST
! /VIEW,1,1,2,3
! /ANG,1
! /REP,FAST
! /VIEW,1,1
! /ANG,1
! /REP,FAST
FLST,2,165,1,ORDE,8
FITEM,2,1
FITEM,2,42
FITEM,2,-45
FITEM,2,171
FITEM,2,211
FITEM,2,-214
FITEM,2,486
FITEM,2,-640
/GO
D,P51X, , , , , ,UX,UY,UZ, , ,
CMSEL,S,WALLSURFACE
FLST,3,1,9,ORDE,1
FITEM,3,2
CM,_Y,ELEM
CMSEL, ,P51X
CM,_Y1,ELEM
CMSEL,S,_Y
CMDELE,_Y
/GO
SFE,_Y1,1,PRES, ,1, , ,
! SAVE, file,db,E:\
/CWD,'E:\'
! SAVE, file,db,
FINISH
! /EXIT,MODEL
! /COM,ANSYS RELEASE 11.0SP1 UP20070830 21:31:14 11/06/2012
! LGWRITE,'file','lgw','E:\',COMMENT
