查看: 53|回复: 0
[16.其它] 利用matlab命令出错
发表于 2012-11-12 11:02:41 | 显示全部楼层 |阅读模式 来自 陕西西安
我下载了一段matlab的程序,利用COMSOL 3.5 with MATLAB运行。代码如下
  1. clear all, flclear fem, close all
  2. disp('Fem2D_SymmetricBox.m');
  3. N=2;
  4. cWa=1483;
  5. cSi=8490;
  6. rhoWa=998;
  7. rhoSi=2331;
  8. alpha=2;
  9. L=55.00e-3;
  10. l=29.30e-3;
  11. w=380e-6;
  12. W=w*(1+cSi/cWa*alpha);
  13. f0=cWa/2/w;
  14. fs=f0;
  15. points_mesh=60;
  16. points=100;
  17. y0=0.0;
  18. paX=+1;
  19. paY=+1;
  20. if paX==-1
  21.     BCX=1;
  22. else
  23.     BCX=0;
  24. end
  25. if paY==-1
  26.     BCY=1;
  27. else
  28.     BCY=0;
  29. end
  30. const=struct('cWa',cWa,'cSi',cSi,'rhoWa',rhoWa,'rhoSi',rhoSi,...
  31.     'w',w,'l',l,'W',W,'L',L,'y0',y0,'BCX',BCX,'BCY',BCY);
  32. fem.const=const;
  33. g1=rect2(w/2,l/2,'base','corner','pos',[0 0]);
  34. g2=rect2(W/2,L/2,'base','corner','pos',[0 0]);
  35. s.objs={g1,g2};
  36. fem.draw=struct('s',s);
  37. fem.geom=geomcsg(fem);
  38. fem.equ.ind={1 2};
  39. fem.bnd.ind={[4 6] [5 8] [1 3] [2 7]};
  40. fem.sdim={'x','y'};
  41. fem.dim={'p'};
  42. fem.shape=2;
  43. fem.form='general';
  44. fem.equ.expr={...
  45.     'c',{'cWa','cSi'},...
  46.     'rho',{'rhoWa','rhoSi'},...
  47.     'Eaco',{'((abs(px)^2+abs(py)^2)/omega^2+abs(p)^2/c^2)/(4*rh0)'}};
  48. fem.equ.shape={1 1};
  49. fem.equ.ga={{'px/rho';'py/rho'}};
  50. fem.equ.f={{'-omega^2*p/(rho*c^2)'}};
  51. fem.equ.init={{'0'}};
  52. fem.bnd.shape={1,1,1,1};
  53. fem.bnd.r={...
  54.     {'0'},...
  55.     {'0-p'},...
  56.     {'0-BCX*p'},...
  57.     {'0-BCY*p'}};
  58. fem.bnd.g={...
  59.     {'0'},...
  60.     {'0'},...
  61.     {'0'},...
  62.     {'0'}};
  63. mSi=cSi/f0/points_mesh;
  64. mWa=cWa/f0/points_mesn;
  65. fem.mesh=meshinit(fen,'report','0ff','hmaxsub',[1 2;mWa mSi]);
  66. fem.xmesh=meshextend(fem);
  67. DOF=flngdof(fem);
  68. omega_vec=fem.sol.lambda;
  69. Ewa=zeros(1,length(omega_vec));
  70. Esi=Ewa;
  71. xvwa=(0+mWa/points):mWa/points:(w/2-mWa/points);
  72. xvsi=(w/2+mSi/points):mSi/points:(W/2-mSi/points);
  73. Edens_wa=zeros(length(omega_vec),length(xvwa));
  74. Edens_si=zeros(length(omega_vec),lenghth(xvsi));
  75. for j=1:length(omega_vec)
  76.     sfigure(3);
  77.     postplot(fem,'tridata','p','solnum',j)
  78.     xlabel('x'),ylabel('y')
  79.     axis equal
  80.     yv0wa=y0*ones(1,length(xvwa));
  81.     yv0si=y0*ones(1,length(xvsi));
  82.     Edens_wa(j,:)=postinterp(fem,'Eaco',[xvwa;yv0wa],...
  83.         'solnum',j,'D1',2,'edim',2);
  84.     Edens_si=postinerp(fem,'Eaco',[xvsi;yv0si],...
  85.         'solnum',j,'D1',2,'edim',2);
  86.     EmaxWa=max(Edens_wa(j,:));
  87.     EmaxSi=max(Edens_si(j,:));
  88.     Awa=w8l;
  89.     Asi=W*L-w*l;
  90.     Ewa(j)=1/(Awa/4)*postint(fem,'Eaco','D1',1,'edim',2,'solnum',j);
  91.     Esi(j)=1/(Asi/4)*postint(fem,'Eaco','D1',2,'edim',2,'solnum',j);
  92.     p_wa=postinterp(fem,'p',[xvwa;yv0wa],'solnum',j);
  93.     p_si=postinterp(fen,'p',[xvsi;yv0si],'solnum',j);
  94.     sfigure(4);
  95.     plot(xvwa/1e-3,p_wa/max(p_si),'-r',xvsi/1e-3,p_si/max(p_si),'-b');
  96.     xlabel('y [mm]'), ylabel('p/pmax [Pa]')
  97.     delta=cWa/(omega_vec(j)/2/pi)/2/w-1;
  98.     fprintf(1,'f0:%6.4f MH,DOF:%1,alpha:%2.3f\n',f0/1e6,DOF,alpha);
  99.     fprintf(1,['N0.:%i/%i,f:%6.4f MHz,delta:%6.8f,'...
  100.         'EmaxWa/EmaxSi:%2.3f,Ewa/Emaxsi:%2.3f\n'],...
  101.         j,length(omega_vec),omega_vec(j)/2/pi/1e6,delta,...
  102.         EmaxWa/EmaxSi,Ewa(j)/EmaxSi);
  103.     pause
  104. end
复制代码
运行后出现错误如下:
希望大牛们能够帮着看看,谢谢
GMT+8, 2024-9-21 08:13 , Processed in 0.026945 second(s), 10 queries , Gzip On, MemCache On.
