- 8
- 2007-5-27
在abaqus/explicit显式求解器中,也有子循环的方法,能够提高显示分析的效率。据说可以提高20%的计算速度,没比较过,但是确实快了。
原理是:单元尺度小的单元采用较小的时间增量,而单元尺度大的单元则采用较大的时间增量。如果不采用子循环,则左右单元都按照最小的时间增量进行计算。
详见abaqus analysis user's manual 11.8.1 Selective subcycling.
使用方法,在*step 关键字之前最后一行,增加如下关键字:
*Elset, elset=subcycle, instance=plate-mesh-1
833, 834, 835, 836, 837, 838, 839, 840, 841, 842, 843, 844, 845, 846, 847, 848
*Subcycling, ELSET=subcycle
** STEP: Step-1
*Step, name=Step-1
其中,subcycle是自己建好的子循环单元集,里面存储的是模型中直接影响稳定时间增量的单元。
开始计算之后,在status file里面会提示,子循环内单元的稳定时间增量和子循环外的稳定时间增量:
Most critical elements in subcycling zones:
Element number Rank Time increment Increment ratio
(Instance name)
2340 1 1.593618E-08 1.000000E+00
PLATE-MESH-1
6372 2 1.593618E-08 1.000000E+00
PLATE-MESH-1
9060 3 1.593618E-08 1.000000E+00
PLATE-MESH-1
13092 4 1.593618E-08 1.000000E+00
PLATE-MESH-1
15108 5 1.593618E-08 1.000000E+00
PLATE-MESH-1
19140 6 1.593618E-08 1.000000E+00
PLATE-MESH-1
21828 7 1.593618E-08 1.000000E+00
PLATE-MESH-1
25860 8 1.593618E-08 1.000000E+00
PLATE-MESH-1
2341 9 1.593939E-08 9.997984E-01
PLATE-MESH-1
6373 10 1.593939E-08 9.997984E-01
PLATE-MESH-1
Most critical elements in non-subcycling zone:
(Instance name)
229 1 3.837396E-07 4.152862E-02
TANK1-1
2745 2 4.098517E-07 3.888280E-02
TANK1-1
2413 3 4.123782E-07 3.864457E-02
TANK1-1
2744 4 4.179116E-07 3.813290E-02
TANK1-1
2389 5 4.207705E-07 3.787380E-02
TANK1-1
3682 6 4.298889E-07 3.707046E-02
TANK1-1
1 7 4.301034E-07 3.705197E-02
JIAOHE-1-1
545 8 4.301039E-07 3.705193E-02
JIAOHE-1-1
67 9 4.301041E-07 3.705192E-02
JIAOHE-3-1
3 10 4.301041E-07 3.705192E-02
JIAOHE-4-1
