查看: 67|回复: 0
[其他] creat model出错是什么原因?
发表于 2012-12-10 14:01:04 | 显示全部楼层 |阅读模式 来自 云南昆明
                    =                         EXCITE 7.0 (4)    Jan 25 2008  =
                    =  OS   Company   :                           Microsoft  =
                    =  OS   Name      :                        Windows 2000  =
                    =  OS   Version   :           6.0.6002 (Service Pack 2)  =
                    =  CPU  Model     :               Processor 586 Level 6  =
                    =  Bit Mode       :                              32 bit  =
                    =  Number of CPUs :                                   8  =
                    =  Host Name      :                             KG01-PC  =
                    =  User Name      :                                kg01  =
$ Name of the instruction file:  $ Name of the output file < Return = "model.out" >:
$ EXCITE-7.0 - start
$ General information:
$ Date: 10-Dec-2012  - Time: 13:54:40
$ Available memory -> 1000.000 MB
$ Instruction file -> model.exc
% SYSTEM UNIT 2
% SYSTEM MNAM 12-10-4102-ehd
% SYSTEM PIOL 1
% BODY DEF 1@ ANCH 1 0
% NAME 1@ Generic UB01
% READI _tmp_ 1@.T
% BODY PRO 1@ DOFT _tmp_
$ BPRO      Default data: [Not available]
Error:       Cannot open error file.
User action: Set the environment variable EXCITE_ERROR.
Syntax:      setenv EXCITE_ERROR <Path to EXCITE error file>
Licensing Warning: bulk key [(null)] validation failed, process does not qualify for bulk licensing!
GMT+8, 2024-9-23 00:28 , Processed in 0.026740 second(s), 10 queries , Gzip On, MemCache On.
